Ste's Detailing Advent Calendar 2015
Hi All,
So a little bit of festive fun going on in our new house for Christmas 2015.
Thought to share with you folks - you might enjoy it along the way..... :happy:
SWMBO has taken a real interest in detailing this year and my indepth research on different products/releases.
So - bravely - she has designed a nice little Advent Calendar for me to open every day up to Xmas itself.
Anyway - thought I would start this thread and i'll post up daily updates, and a bit of blurb on the product.
Some of you may have reviews/comments to add.... good or bad, so join in - but let's try keep it positive and upbeat OK. :thumbup:
So as of last night.... my selection of goodies on the left, stuff for the kids..... and choccies for SWMBO at the back! :giggle:
Cheers,
Ste.
12310516_10153105622025303_7138215225827
  • Replies 183
  • Views 12.1k
  • DAY 15: Adam's Invisible Undercarriage Spray     Website Blurb.... Don't let ugly, soiled wheel wells ruin your beautiful detail job. After you have finishing cleaning, claying, polishing and waxi
  • What a cracking idea & girlfriend you have. My wife has done exactly the same for me...but I have a small piece of cheap chocolate behind each door!!   I'm getting into cleaning, got an Octavia
  • The Gtechniq QD is a fantastic product and I've used it since shortly before it was released to the public. It's great for a quick detail or as a drying aid. Basically a sealant with a cleaning actio
That is an absolutely cracking idea! Well done to SWMBO!! Enjoy buddy!
Sent from my SM-G925F using Tapatalk
Yeah - it now makes sense..... I get what she has been upto for the past few months now! :clap:
DAY 1: Gtechniq W5 Citrus APC
Blurb....
pH Neutral Biodegradable All Purpose Cleaner
New biodegradable pH neutral formula removes road grime and bug splatter with ease. It can be used for many cleaning routines from engine bay degreasing to carpet stain removal and is specifically formulated to provide very effective cleansing without removing coatings, waxes, sealants, or delicate trim and chrome parts.
Features & Benefits:
  • Removes oil and grime with ease
  • Will not remove wax or ceramic coatings
  • 100% biodegradable
  • pH neutral
  • Can be used on a variety of substrates including carpets, alloy wheels & engine bays
Directions for use:
  • Use neat for heavy soiling and up to 100 parts water to 1 part product for light soiling
  • Spray neat or diluted directly onto the surface and allow to dwell for 5-10 minutes
  • Rinse residue and repeat if necessary. In extreme cases agitate surface with a clean microfiber
12299231_10206495356517347_8166259969891
Top SWMBO............must send this pointer to mine!!
DAY 1: Gtechniq W5 Citus APC
Blurb.... pH Neutral Biodegradable All Purpose Cleaner
  • pH neutral
Directions for use:
A great APC! I use this a lot! Never needed to try anything else. Nicely priced in 500ml. 20:1 is my preferred ratio & works on almost everything! Great first day present!
Thanks for the feedback Karl - I had no idea you were using Gtechniq APC.
Glad to see you approve and rate it highly as well :thumbup:
Looking forward to trying it out for sure..... an interesting 1st choice indeed...
DAY 2:  50cal Ambush Superfoam
50cal Website Blurb....
Developed with the latest surfactant technology available and sourced from naturally derived precursors when available, this new long cling foam is unsurpassed by its dwell time and cleaning ability. It is optimised by use through a dedicated foaming lance head at the highest pressure setting available on the pressure washer. When calibrated correctly it will produce a thick mousse like foam which adheres to vertical surfaces for up to 30 minutes. This is as close to a ‘touch less’ wash as you will get and it will not degrade any prior surface treatments.
It has a built in wax and dewatering aid to further help the rinsing of the product from the vehicle. It works extremely efficiently on the removal of break dust and road film on wheels thus potentially rendering the need to use a secondary alloy wheel cleaner unnecessary. We recommend using a starting dilution of 2-3 inches into a 1lt wash bottle, topped up with ideally deionised water that’s attached to the foaming lance. The air intake and pressure should be set to the maximum settings available. The product is also enhanced with a rich Bubblegum smell and for the real enthusiasts, we will be offering options to have the foam coloured, in due course.
In Short:
  • Unsurpassed cleaning performance
  • Market beating foaming characteristics
  • Unrivalled product dwell time on vehicle
  • Excellent alloy wheel cleaning performance
  • Wax and dewatering additives
  • LSP (Last Step Product) safe
  • Extremely economical dilution rates
  • Manufactured, using where available naturally derived raw materials
  • Rich Bubblegum smell
  • Developed in conjunction with the highest professional requirements
  • Not for amateurs!
12299122_10206500274000281_7550994903133
In Short:
  • Not for amateurs!
Interesting gift! Be nice to see how you get on with it! The write up sounds promising. Not one I've used myself although here some good things and see good reviews on 50cal! Enjoy! Roll on day 3!
Cheers Karl - it's a brand I have been dying to try since Mark (O.C.D.) recommended them and he rated them very high indeed.
I now have the SF, Glaze and Wax from 50cal as a sample pack to test out - so pretty happy with that!  :thumbup:
That'll be a good mornings testing for you!
I'm getting into cleaning, got an Octavia & 2 push bikes which need a lot of attention this time of year, so it will be good to see what samples you get. Might give me some idea's on what to buy as it seems a bit of a minefield as to what is "best".
Hello there.... thanks for the comment and thanks for getting involved in the detailing section
Plenty knowledge here and generally a friendly bunch. :thumbup:
The girlfriend does follow my detailing exploits well enough and is interested in the products/suppliers.
We have a good little detailing community locally as well and folk are always dropping by the house.
So - she has done her research and found a couple of dozen products I haven't tried or do not currently
form part of my detailing arsenal - so I'm really enjoying this Advent Calendar idea :rock:
Plenty knowledge here and generally a friendly bunch. [emoji106]
Sooo.. what was behind door 3 today buddy? Anything special ;)
Busy this morning mate - but i will be at home this afternoon and get updates done.
A few nice deliveries due today - if all goes to plan :happy:  ;)  :thumbup:
A few nice deliveries due today - if all goes to plan :happy:;) [emoji106]
Good stuff! I'm far to intrigued in your advent calender haha!
Can't beat delivery day!
DAY 3:  Gtechniq W8 Bug Remover
Website Blurb...
Powerful pH Neutral Bug Remover
Bug splatter is one of the hardest contaminants to remove. Gtechniq W8 Bug Remover is a 100% biodegradable and has a pH neutral formula. It makes light work of removing bug splatter without the use of aggressive caustic ingredients.
  • Removes bug splatter with ease
  • Will not remove / damage wax or sealant coatings
  • pH neutral
Directions for use:
  • Store in a cool dry place out of the reach of children
  • Spray W8 onto bug splatter and allow to dwell for 5-10 minutes
  • Rinse and repeat if necessary
  • In extreme cases, agitate the surface with a clean dry microfibre
12346370_10206505623894025_2939961170272
Website Blurb...
  • pH neutral
Directions for use:
Nice! Not one I've tried from them yet! Be an interesting review!
DAY 4: Gtechniq Quick Detailer
Website blurb....
Gtechniq Quick Detailer is designed to be super easy to use as the very last step in your regular wash routine.
Use Gtechniq Quick Detailer to remove annoying water traces often left behind during the drying process or to remove finger prints and dust from an otherwise pristine finish.
Based around Gtechniq's Smart Surface Science technology, Quick Detailer (QD) is fully compatible with all of Gtechniq's range of paint and glass coatings.
Directions For Use:
  • Gtechniq QD can be used with any Nano-Quartz Sealant or natural carnauba wax
  • Spray onto surface and buff off with a Microfibre Buffing cloth
  • Can be layered to further enhance gloss, slickness of finish and durability
12342849_10206511331836720_7755162738472
Website blurb....
Directions For Use:
Another review I'll be looking forward to! Another one I've not tried from Gtechniq but as all their stuff gets decent reviews I'm sure you won't be disappointed!
Seems that I may have mentioned Gtechniq at some point? :giggle:
I've had a few people ask about using ceramic paint coatings this past year...
So I best give them a try!!! :thumbup:
Haha its looking that way mate!
The coatings look very good. I'd be interested to try one myself at some point!
Well - i'll definitely have a play with ceramic coatings before my new car turns up and decide...
Hearing great things about SiRamik though plus the SC mist maintenance detailer as well.
Then play with some show waxes - just for fun!!! :thumbup:
Then play with some show waxes - just for fun!!! [emoji106]
The SiRamik products sound really appealing & very easy to use aswell.
Watched a few videos on ceramic application and some look quite a challenge!
Although the Gtechniq ceramic coatings are very well spoke of by a lot of top detailers & the accredited bunch too!
Well - Shaun has given me enough info on SiRamik to convince me - that's for sure.
His new car was fully sealed when new and looks absolutely stunning everytime I see it!
I did get some info from a friendly local detailer that Gtechniq have been more troublesome.
Seemingly, to keep up with production capacity, the manufacturing process has changed a bit.
Therefore.... some of the paint coatings have "allegedly" become a bit more problematic.
In saying that - I haven't used them extensively - so can't comment/confirm for sure.
