Battery drain, and refusal of engine to even turn over
Just a tip: - The light in the glove box takes 0,250 Ampere. The ECU takes about 3 mA after 30 minute, and before that 120 mA. 370 mA the first 30 minute, also, and 0,250 Ah after that. I got fooled...
My measure on My Fabia 1,2 comfort.
Something to think about?
That emptied my battery in 4-5 days... My other Fabia, Classic, dont have the little "devel light"...
Edited by Torbo
  • Replies 51
  • Views 9.4k
  • So you have a problem. It could be a) Dodgy battery,not holding a charge Drain on battery.   First stop -identify problem ( called diagnosis). Simplest way is to fully charge battery, replace in(
  • sepulchrave
    sepulchrave
    Brutal scotchblockery, hateful to mine eyes.
  • wiredsoftware
    wiredsoftware
    What Flapperjack7 meant to say was I think "Speaker connector is the brown block (i.e. all the speaker wires are on the brown block). The Black BLOCK is everything else (e.g. power cables, earth cable
To the OP the correct wiring (car side) for that stereo should be as per my thread & guide here:-
http://www.briskoda.net/forums/topic/196288-oem-wiring-loom-colours-pins-for-stereos/
You will need to google the wiring diagram pin out for that JVC stereo also.
Now that loom with the connectors on, look at it going back into the dash, does it have other connectors/blocks on it? If not then that is the car factory loom, just that you can get adaptor looms to plug in between the stereo & the car wiring which look like car wiring.
