Fabia maxidot settings
Hello,
I just bought the new Fabia, with the ambition setup,
How can I access to the maxidot settings?
I dont have a multifunctional steeling wheel.
Are you sure the car even has Maxidot? its not standard across the range, and as you are in Hungary the specification may vary from what we have here in the UK.
Perhaps take a picture of the instrument cluster with engine running and post here.
Edited by mannyo
Somehow I need to change the time, etc..
But don't know how to access to the settings.. I found how to set the speed alert, but thats all..
The dashboard :
http://i.imgur.com/FjKzfCu.jpg
One more thing.. There is an option that after the speed of 15mph, the doors are lock automatically..
That function can be edited on that screen(if its possible)?
Thanks for your reply.
Does your car have a " Car " button on the radio,  settings can be done via the Radio. ?
Edited by Auric Goldfinger
The dashboard :
You don't have a maxidot display. This one is just standard segment display.
To change the clock you have two options:
1. In the settings on the infotainment (radio)
2. or using the ''0.0/SET'' button in the following order:
› Switch on the ignition.
› Press and hold the button until the Time is shown in the display.
› Release the button and the system switches to the hour setting function.
› Press the button again and set the hours.
› Wait around 4 seconds - the system switches to the minutes setting.
› Press the button again and set the minutes.
› Wait around 4 seconds - the system switches to the start setting.
The autolock feature can be turned on using the ''Car'' settings menu on the infotainment.
Thank you for all your help!
I will try.
