Retro fit Auto Headlights!
1 hour ago, fabiamk2SE said:
Ive ordered some H7 Autobeam LED’s and they didnt fit. Could get the metal clip around them.
Returned them and had to hassle them for about 2 weeks for a refund which i got slowly in bits and bobs. Had to keep doing the maths for them until i got the full amount.
They didnt want to refund me postage or return postage even though it says on their site that they should fit my car. Got there in the end...
You need adaptors for leds to fit.
  • Replies 150
  • Views 30k
Ah okay. I did send pictures to them and what not but they didnt know either.
Happen to have a link to adaptors mate?
22 hours ago, fabiamk2SE said:
EPC i think is the code for a failed brake light switch.
I had it on a Polo. VW wanted £70 just to disgnose even though its a common problem. So i took a punt on a £15 switch and won.
Thats the kiddie! You were the lucky one then, I paid the money to get it done, prior to the information!
Those clips AMD87 showed, look neater and better then mine. I paid about that price as in a hurry but could have paid around half for my slightly flimsy looking ones but they do the job. Those ones look like they will be easier to fix into place.
fabiamk2se, you also have to slide off the circular, three-pronged thing that SHOULD come with the bulbs... Slide it off, slide the adapter rings on and re-fit the ring. That holds the adapter in, sort of. You can also twist the bulbs to get your preferred angle of beam, as they light top and bottom, so to speak. Might make the output nicer.
Live and learn mate. I didnt really know, just googled and gambled before i had VCDS.
Brill. Might be worth another try then. What do you think to them?
Ive got leds on the bike and theyre ace. Always had hids in projectors but new to retrofitting leds.
Would prefer them though? If similar output?
Hello there, i bought the kit above for my Fabia Mk2 Vrs MY2012
http://www.cars-equipment.com/en/shop/multifunction-switches-buttons-7/auto-headlight-switch-light-sensor-for-2/
in the package not included manual for installation or instructions for everything
i ve install this kit in my Car but as other members fuse 35 (5A) went off , and  no dash lights
the Auto switch is not in Right dimension , can not be fited in my Fabia , and the worst of all 110 euros for this carbage..........
I have send 2 emails to the super duper seller and now I am waiting for his response
About fuse 35 , is there any solution ?
Best regards
VV
4WDDSG have you got HIDs installed?
I changed fuse 35 for a 7.5A but that didn’t help, I then changed fuses 36/57/58 to 20A fuses but that didn’t help either, it still blew fuse35, so I returned the item.
however, when reading someone else’s instructions, I believe I should have changed fuse 23 (sidelights) to a 20A fuse.
So try changing fuse 23 to a 20A fuse and see how what happens.
No my friend oem halogen I have in my Fabia vrs
Perhaps the changing of sidelight fuses is due to when you set them to come on with the indicator stalk, (Key out, left or right signal on) BOTH sides light up not just one.
Although this is from a different supplier, I would have thought it would slot in... Have you pushed/twisted the unit properly? (As in method for fitting or removing from dashboard).
It is not possible my friend , the only way to fit the auto light switch is to increase the diameter of the switch hole in dash board, not good idea.
Or get a yeti one
When I fitted my auto light kit all worked ok except the front side lights. They don’t work at all.
If I return it back to factory fix everything works as it should.
Not sure if it’s the switch or auto control box just behind it.
Hello again, the biggest problem of all is the behaviour of the seller , he ignored me the same in both messages that I have send him.
I’m not sure the Skoda forum is the place to resolve your buying problem though.
there are different sizes of switch for the VAG, from memory the Fabia is a round one, others have an oval shape.
i would suggest you create a dispute via eBay or Paypal and let them know it is not correct/as described and you wish to return it for a full refund.
Do you think that i want Skoda Forum to resolve my problem?
I bought this carbage no with pay pal but with another way of payment .
Payment method CSOB bank - Pay Online
no dispute , no anything i  can do to protect my self
Edited by 4WDDSG6
I am loving them! I am about to try getting some H4 Foglight ones now! I did put up some pictures so I'll Try adding them again. Got LED tail-lights and sidelights, too.
Have a look under the thread   HEADLIGHT BULB REPLACEMENT. On the 3rd page, (Last posts), I have piccies of my car with the LED sides and headlights. Planning the fogs now as they look too yellow!
  • 6 years later...
Hello,
I realise this thread is rather old but I'm wanting to retrofit auto lights, preferably without VCDS.
Does anyone know if the following items would be plug and play (plus a fuse change)?
https://www.ebay.co.uk/itm/162770388031?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=747cIYBHQzm&sssrc=4429486&ssuid=7jHjgA_FRCK&var=&widget_ver=artemis&media=COPY
https://www.ebay.co.uk/itm/196256961076?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=jUS2SSVBRoy&sssrc=4429486&ssuid=7jHjgA_FRCK&var=&widget_ver=artemis&media=COPY
If it does need coding and anyone can do it for me, I'm in Livingston, Scotland.
I have a Skoda Fabia Elegance Estate.
Reg is SM11KDO if that helps at all.
Edited by Panels123
2 hours ago, Panels123 said:
Hello,
This is what I see when I remove my light control. Unfortunately, I think I'll need mine coded.
You just need to unplug the connector from the switch and fit the new Auto one, then feed the light sensor near the front windscreen. There is nothing to code.
This is the first reply I've ever had on here so thank you so much!
I'm really confused about what part I need.
I have a 2011 Fabia Elegance TDI CR 105.
Both Ebay and the seller say this won't fit, for example:
If a component for a 2007-14 Fabia won't work then what will?
The Yeti one has got the small plug, the other is the large plug like yours.
Just pull the switch out and compare the pin outs in the picture. On the pins you will see the abbreviations for the various light switch functions.
