Have ordered obdeleven for my '16 190 TDI
46 minutes ago, grenness said:
You can't expect that every adaption for the Octavia will work on the Superb, and not all Octavia modules are the same in the Superb...
So if you can't find it when connected to the Superb, I guess that particular adaption either is not possible, or has different steps.
Automass has an Octavia :-)
Edited by tigermad
  • Replies 96
  • Views 26.7k
  • Ok, received the obdeleven dongle. And it looks promising :-)   Here are the first things I did with it today:   First, I ran a complete error scan of my car:   It
  • Too eager to leave it until the weekend...   So this morning I did one 'app' (cost me 10 credits) and one normal adaption/configuration 'VCDS style' :   First I did the app/script
  • New mod:     (9) Central Electronics -> Security Access -> 31347   Left: Adaptation -> Channel: (4) Leuchte16BLK SLB35BLK SL KC9 Lichtfunktion A16: Set = Bli
Ahh :-)
Then I suppose he should try to find any obdeleven-users in the Octavia forum :-)
19 minutes ago, grenness said:
Ahh :-)
I figured out now how to do coding and adaptation...don't worry about me greeness.
4 hours ago, grenness said:
Long coding
    Control unit: 01 Engine
    Old value:
        011D003A047601083000
    New value:
        021D003A047601083000
    Mileage: 6557 km
    Date: 2017-03-09 14:03
I made the same change and experience increased fuel consumption by about 10%. Has anyone more noticed the same increase?
Did I mess anything? On the display (17) I was checking the list of the coding and then I have seen Tire pressure monitoring was No but I have this option in my car..so I did change it to yes...and select the tick option and it was succefully accepted but after that I can see that my TPM erroe light is on on the display..I have reverted everything that I did,but still its on the dash..
I followed the procedure of the manual (disconnect the battery, reconnect and drive sometime)..but still it is on the dash..any help from any body...do I need to enter any security code to do the coding?
I have changed two opoptions from ccoding...these were
Tire ppressure monitoring and Average consumption
 I have changed them back as they were
Now getting two fault codes
Control module incorrect coding (U101400) and
Database missing message (U112100).
Edited by automass
On 22/03/2017 at 09:24, grenness said:
I think these are my screenshots from when I did this, the first one is the VCDS instructions, the two others are from when I actually did it in obdeleven:
Remember that you can just click on where it says Hex 01 in the top right, and edit the value like I did here:
This didnt seem to work . Either says revs to high or not supported on my 2017 superb  dsg se l executive
Sorry posted on wrong place
Edited by automass
On 2017-04-06 at 13:54, grenness said:
My coding history so far:
OBDeleven vehicle history log
Date: 2017-04-05 21:57
Adaptation
    Control unit: 08 Air Conditioning
    Name: Target temperature of A/C - heater function via remote control
    Values:
            Old value: 22.0 °C
            New value: 25.0 °C
    Mileage: 7598 km
    Date: 2017-04-05 21:39
Will this preset temperature override temp-settings made in personalisation when activating diesel heater with remote?
I'm not sure :-)
I hope so, but haven't tested it yet.
Can I ask - do you need the OBD11 dongle for this or will any OBD Bluetooth dongle work with the 11 a
pp?
pp?
You need the proprietary dongle.
On 4/6/2017 at 13:54, grenness said:
Adaptation
    Control unit: 76 Parking Assistance
    Name: Distance to curb
    Values:
            Old value: 15 cm
            New value: 5 cm
    Mileage: 7598 km
    Date: 2017-04-05 21:56
I think I'm going to revert this back to its original setting... ;-)
Used the parking assistance today for the first time since the modification, almost touched the sidewalk with the rims:
Thats a bit too close for comfort!
9 hours ago, grenness said:
I think I would be tweaking that to about 74.9mm;)
Edited by Bud
:-D
I set it to 20cm now.
@Kpsmithuk
PM me if you want this done, along with any other VCDS / VCP coding.
On 2017.03.31. at 00:15, grenness said:
New mod:
Left:
Lichtfunktion A16: Set = Blinken links Dunkelphase
Right:
Adaptation -> Channel: (4) Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
Lichtfunktion A17: Set = Blinken rechts Dunkelphase
This feature is not working on my Superb... Are there some specific prerequisites that is necessary to have or to change more in the system in order to start working this mod? I did the following steps but nothing changed
Adaptation
    Control unit: 09 Central Electrics
    Name: Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
    Values:
        Lichtfunktion A 17:
            Old value: nicht aktiv
            New value: Blinken rechts Dunkelphase
    Mileage: 25836 km
    Date: 2017-05-08 18:10
Adaptation
    Name: Leuchte16BLK SLB35BLK SL KC9
    Values:
        Lichtfunktion A 16:
            New value: Blinken links Dunkelphase
    Mileage: 25836 km
    Date: 2017-05-08 18:09
I can't get the eyelashing working either
On 30/03/2017 at 22:15, grenness said:
New mod:
Left:
Right:
Just be warned that I coded an Octavia similarly at the owners request (DRL flashed with the indicator) and in the UK it’s an MOT fail.
I was on 03 when i check the setting. no idea what it is. but i changed to 02 audi anyway. nothing noticeable
has anyone got instruction how to enable TSR on MY17 superb ?
The vcds instuctions got us 3/4 through but we could not find the last part !
OK, thanks to Gizmo's patience and help TSR is go :)
So with OBDeleven I have done:
DRL on/off on Infotainment.
Audi throttle pedal
Fan (blower) speed display on auto
Refuel quantity in maxidot
TSR enabled
I have dry run through lane assist, and can find all relevant parts from VCDS instructions, but as I wouldn't use it anyway, I decided not to bother. :blush:
Awesome gadget, ordered it and works like a chram out of the box. Enabled Audi Throttle Response which transformed the car (190 DSG) + TSR.
I looked at this but couldn't work out if I needed dongle plus the app? Circa £60+
Yes.  You can't use one without the other.
