Have ordered obdeleven for my '16 190 TDI
Adaptation
    Control unit: 08 Air Conditioning
    Name: Target temperature of A/C - heater function via remote control
    Values:
            Old value: 22.0 °C
            New value: 25.0 °C
    Mileage: 7598 km
    Date: 2017-04-05 21:39
On 2017-04-08 at 19:23, Mico01 said:
Will this preset temperature override temp-settings made in personalisation when activating diesel heater with remote?
On 2017-04-08 at 19:25, grenness said:
I'm not sure :-)
I hope so, but haven't tested it yet.
Hi,
Tried this adaption, it was accepted in obdeleven but temperature doesn´t change in a/c display when starting heater with remote.
Did you get this working? @grenness
  • 7 months later...
  • Replies 96
  • Views 27.4k
  • Ok, received the obdeleven dongle. And it looks promising :-)   Here are the first things I did with it today:   First, I ran a complete error scan of my car:   It
  • Too eager to leave it until the weekend...   So this morning I did one 'app' (cost me 10 credits) and one normal adaption/configuration 'VCDS style' :   First I did the app/script
  • New mod:     (9) Central Electronics -> Security Access -> 31347   Left: Adaptation -> Channel: (4) Leuchte16BLK SLB35BLK SL KC9 Lichtfunktion A16: Set = Bli
Hi, Has anyone tried following with obdeleven?
I have ordered mine but 2 weeks delivery time so waiting to try above options...
i've got 65 plate superb 150ps dsg se&l
1. open/close boot lid from center button or from remote key
2. close all windows when car locked through remote
3. close all windows when raining?
V
This requires a new file to be flashed to the control unit.
Thanks, so not a straight solution from obdeleven? As the open lid button very close to break switch and accidental open is a nightmare because you need to get out of car to close it which is a pain.
V
No, depending on the controller VCP may be able to do it.
Just be careful with obdeleven as if you use their ‘one click’ function then some things are not reversible.
Close the boot from remote when inside the car by pressing the boot close button (on the remote) twice in quick sucession and holding it down on the second press. Only one caveat - ignition has to be switched off.
Edited by TerryMcK
quick succession press of lid button on remote and holding it just opens the lid... to close the lid i need to press the close button on the lid itself which is the pain when you accidentally open the lid while sitting on the driving seat.
This method (double press-hold) definitely works on my MY2017 Kessy equipped car. Sorry it didn't work for you.
Yep, it's Kessy-only I think.
1. you can already close via the remote.  via the centre console - apparently is possible with certain controllers, however u need a VCP tool.  OBDeleven or VCDS can't do it.
2. u can open or close all windows via the remote.  as long as ur "convenience opening" for Windows is set to "All Windows".  see pic below.
3. not possible as the rain sensor module/hardware in the mk3 won't allow this feature.  something to do with the power usage.
Edited by JR RS
I see from jaggafredde's post in this thread that it's possible to deactivate the tailgate button on the remote using the Carista OBD2 adapter. Does anyone know if you can do this with OBDeleven now?
On 22/03/2017 at 09:24, grenness said:
I think these are my screenshots from when I did this, the first one is the VCDS instructions, the two others are from when I actually did it in obdeleven:
Remember that you can just click on where it says Hex 01 in the top right, and edit the value like I did here:
@grennessthanks for the post, but I am asked for security access code (mines an Octavia '18 plate). Any ideas?
On 21/03/2017 at 14:24, Mico01 said:
Did you notice any improvement with the AUDI throttle response mod? Will try this coming weekend when i recieve dongle from obdeleven.
@Mr Grump @Mico01 did you get it working - using obdeleven I am asked for a security code - any ideas?
Edited by 877
On 30/03/2017 at 23:15, grenness said:
New mod:
Left:
Lichtfunktion A16: Set = Blinken links Dunkelphase
Right:
Adaptation -> Channel: (4) Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
Lichtfunktion A17: Set = Blinken rechts Dunkelphase
This one is awsome! Love it.
But this mod works only on auto, right?
Possible to enable it even when switch is on "0"?
u need SLA headlights for this, as it uses the eye-lashes when alternating.
SLA headlights...?
I got an L&K with the eyelashes
4 minutes ago, mrBira said:
SLA headlights...?
well if u got eyelashes working, then yes, u have Smart-Light Assist (SLA) headlights :thumbup:
Hi guys! I have a october 2017 Superb Mk III . Yesterday I received my dongle. I did some modifications, start/stop, drl, etc. but throttle response isn't possible. Like other guys, I have 0C at first place. Neither is the rest of the bits the same, that's why I do not have security in making the change. Does anyone have a configuration similar to mine?
This is my configuration.
  • 2 months later...
Hi guys,
today I received my OBDeleven dongle and did the TSR. It works in MFA but now I don´t Have the road signs in my Columbus Navi. Any thoughts or is this normal?
(MY 2017,  L+K, 140kw)  I used the instructions given on page 3 of this thread (Thanks for this great resource!).
No that’s certainly not normal.
Thanks for your answer, I just came back in and now everything is working flawlessly. I redid the changes regarding the menu list and restarted. Maybe I should Have tested this before posting...but thans again for all the effort you put in helping people coding!
Hey, any tips what you can activate if you don't have the center windscreen camera ? I did not want to many assists in the car, but just asking if i can active something for free without the camera.
