Adaptive Lights (AFL) question?
3 minutes ago, BAJM said:
there was a campaign mod carried out on the vehicle assist (SOS callout) function, campaign number is 91R2
What does that fix - obviously SOS related but what doesn't work without 91R2?
Service reception said that the fix improved connectivity on the SOS system, the unit with 3 buttons above the rear view mirror.
Not tried pressing any of those yet :) Maybe I should try the red SOS button to test it works.
SOS Button (scratches head and wonders why I have not recognised this) is this on all models?
 I am going out to have a look around my headlining switches now :mmm:
This was introduced in August /September 2017 I have a September registered SEL.
I think the three buttons are on MY18 cars. SOS, info and a service button - they're very obvious and not something you could miss. Someone told me they are going to be legally necessary on all new cars soon. The SOS is a red button but the car can also automatically send your location in an accident to the emergency services. So, at least if your headlights aren't fixed they'll find you at the first corner you didn't see - quite reassuring really! Haha
OK mine's too early then :speechless:
Are any services required for SOS, service button etc required? On my 3 series I had SOS and info call options (like telstar I'm US)  where I could callamd ask for directions to a nearby hotel, nearest Italian restaurant etc but all this required active contract with BMW connect, free for three years then a paid subscription...
Yes although I suspect SOS is free for life so to speak. Other services like remote access to vehicle data, POI, etc. will be chargeable after 12 months.
Yes my understanding is SOS for life of car and other services are annual subscription.
Thanks @rtj70 and @BAJM - will bring it up with the dealer when I collect on Friday!
I was told to improve connectivity as there was a loss of service in certain areas of the country.
Repeating a post on the other page regarding this:
OK, just back from the dealership having had my car in for this issue. Beautifully, the headlights pointed at the ground when I started it from cold this morning at dusk so I was able to get the technician to plug it in before I switched it off. I'm not sure if it revealed an error but they have applied  the software update. Apparently their technician had to fill in an extra report for Skoda than he would normally have to do as this is an issue they are monitoring more closely than others.
I don't doubt that something has changed. As was mentioned previously, the dance of the headlights is now much more varied and reminiscent of the old system in my Superb II with more left/right movements than before. I'll try it again in the morning from cold but it's definitely different. Also, and I could be wrong, I think that they don't do a full reset pattern now on a single ignition press. I'm pretty sure they did before. Fingers crossed!
Seesh, how difficult is it just to point lights in the right direction? Is it rocket science?
If the lights were none adaptive this would never be an issue. But Xenons (non adaptive) still have to move up and down to avoid dazzle. AFS means they can move side to side to follow steering.
The problem it seems is calibration on startup.. Never had a problem over 6 years for AFS in the two VW group cars (Passat CC and A3 saloon). And not a problem for standard Xenons in the Mazda6.
Touch wood.... not had a problem in the Superb yet.
