Skoda approved lowering springs for a MK3 VRS?
36 minutes ago, Esseesse200 said:
Hi mate. Mine was on H&R 40mm and it was awesome. Even loaded it was still good. Just go for it
In what way is it awesome lol
  • Replies 106
  • Views 39.5k
  • Both Rieger rieger-tuning.biz
  • I asked the same question many moons ago when I got my Mk3 VRS and there wasnt any, nor was they any springs for the vRS at that time. Whether its changed since Im not sure as it was 4 years ago.
  • JohnnyType2
    JohnnyType2
    got mine done, but im in Ulster so the roads are marginally better, although i thought you had much better surfaces now? anyway heres my vRS with TUV approved H&R springs 40mm over standard a
Yes much more sure footed. Looks boss as well.
Hi mate so u think I should lower and my car doesn't handle that well  so lower should help and I don't want to be sitting in a go cart lol
I just felt a lot better, less jiggly and harsh and much more planted.
So apart of looking well the ride is much the same is it and handles alot better
ride is actually less 'crashy' over potholes and uneven road.
Is 40 mm good then with h r springs all round mate
Is it a smooth ride or is it  like a go cart to sit in and does it handle far better and look better mate
you can up and get a drive in mine if you want. where are you?
Are the VW Racingline lowering springs as close to an OEM+ upgrade as you can get (I suspect they are a reboxed H&R item)
Hi mate am in northern Ireland I was pricing h&r springs on eBay about 170 pounds and they want to know the ankle weight which I don't know it
northern ireland is about 100 miles top to bottom and 100 wide... where are you in northern ireland?
Sion mills
Will mk7 1.6tdi golf lowering springs fit in my mk3 octivia vrs.. there h&r in the box my brother got them.. thanks
  • 3 years later...
Does any have have the part number for the OE Sport spring for the MK3 VRS? I am on B6 shocks and B3 springs but I find the ride height a bit too tall. I want to drop it a bit further. OE Sport Spring is 0.75in all 4's so was wondering if its the same part as the Golf MK7 as here https://www.ecstuning.com/b-h-and-r-parts/oe-sport-spring-set/54787-55~hr/
Car stance with B6 + B3 attached.
Edited by z klasse
For the Octavia MK3 VRS, I suggest 5Q0411105HC front springs if you have a manual gearbox, or 5Q0411105HD front springs if you have an automatic gearbox.
  5Q0411105HC Front coil spring
1 paint mark
1 paint mark
green
Grey
  L16
  5Q0411105HD Front coil spring
1 paint mark
1 paint mark
brown
white
  L17
Edited by Carlston
1 minute ago, Carlston said:
Here's a list of front springs for the Octavia MK3.
You will probably want either 5Q0411105HC or 5Q0411105HD if you have a manual gearbox, and either 5Q0411105HD, 5Q0411105HE, or 5Q0411105HF, if you have an automatic gearbox.
Some front springs for the "Octavia MK3 2.0TSI 220PS/230PS/245PS" with sports/lowered ride height.
1 paint mark
1 paint mark
green
Grey
  L16
1 paint mark
1 paint mark
brown
white
  L17
  5Q0411105HE Front coil spring
1 paint mark
1 paint mark
brown
yellow
  L18
  5Q0411105HF Front coil spring
1 paint mark
1 paint mark
brown
orange
  L19
I meant I wanted the H&R Part number for the OE Sport Spring which has 0.75 inch drop. Not sure if its the same part as the Golf MK7 which is 54787-55
On 02/10/2017 at 23:28, Robfab said:
Thats mine with 20mm front and rear. Albeit pre facetlift, I did wish Id of gone smaller if i remember correctly but this was 3 and a half years ago.D6987087-6E44-4BD2-9115-37903A94A899.jpeg.3f530e95452327ace0682d9d8b77c778.jpeg73526922-410E-4856-8823-95F422BF0C1E.thumb.jpeg.139144e2bf446d1447c2d3b43bd3012c.jpeg
What is the part number for this Spring? I have the MK3 Hatch 2017 model Face Lift with the Twin headlights 230hp. I am looking at the OE Sport Spring with my current B6 shocks. Drop is suppose to be 0.75in or 19-20mm.
The Octavia MK3 2.0TSI VRS facelift came out in 2017 with 245PS. It was the pre-facelift models that had either 220PS or 230PS. The petrol VRS facelift model also has 310x22mm ventilated rear brakes, whereas the pre-facelift VRS model has smaller 272x10mm solid/non-ventilated rear brakes.
This information applies to Skodas manufactured and sold in Europe.
Edited by Carlston
Just now, Carlston said:
The Octavia MK3 2.0TSI VRS facelift came out in 2017 with 245PS not 230PS. This petrol VRS facelift model also has 310x22mm ventilated rear brakes.
So we had the 230ps facelift sold to us in 2017 in India and then the 245ps came out after 2 years. The 310 brake was in the 245. we had the 270mm brake. Either way I assume the part number for the 230 and the 245 lowering spring will be the same for the MQB chassis correct?
Yes, the front and rear springs for sports/lowered ride height cars should be the same for all 220PS/230PS/245PS models.
Are you sure your VRS left the factory with sports/lowered ride height springs? I suspect VRS cars sold in India might have left the factory with standard ride height springs due to their poor roads.
You really need your car's build codes to find out what parts the car left the factory with...otherwise you're just involved in a guessing game.
Edited by Carlston
You really need your car's build codes to find out what parts were fitted in the factory...otherwise you're just involved in a guessing game.
Hi
The car came with a rough road package and the car came with 15mm lower set up. That is out of the car as of now. I am on Bilstein B6 + B3 (also known as Euro spring) and even though the spring is shorter than the OEM in the front and the back, the car still feels a bit high at the front and does feel a bit nervous around corners. B6 with H&R with 20mm drop seems to be a good solution.
What Bilstein B3 front springs do you have fitted?
These might be standard ride height springs.
Do you have manual or automatic gearbox? The automatic gearbox versions tend to use slightly stiffer front springs than the manual gearbox car...because the automatic gearbox is heavier than the manual gearbox.
Octavia MK3 (probably on standard ride height springs)
https://en.wikipedia.org/wiki/Škoda_Octavia#/media/File:2016_Skoda_Octavia_SE_L_TSi_Estate_1.4_Rear.jpg
Octavia MK3 VRS (probably on sports/lowered ride height springs)
https://en.wikipedia.org/wiki/Škoda_Octavia#/media/File:2015_Skoda_Octavia_VRS_TDi_CR_2.0_Rear.jpg
Edited by Carlston
Automatic gear box.
Bilstein B3 Springs are the same as Euro Springs that came in the EU octavia. Here is a pic for comparison.. OEM (india) Vs B3 (new one)
uuid=00000000-0000-0000-0000-000000003B11&library=1&type=1&mode=2&loc=true&cap=true.jpeg
uuid=00000000-0000-0000-0000-000000003B15&library=1&type=1&mode=2&loc=true&cap=true.jpeg
uuid=00000000-0000-0000-0000-000000003B1A&library=1&type=1&mode=2&loc=true&cap=true.jpeg
Part number for OEM
Front Shock: 5Q0413031LH
Front Spring:  5Q0411105GK
Rear Shock: 5Q0513029ND
Rear Spring: 5Q0511115D
