Skoda approved lowering springs for a MK3 VRS?
6 minutes ago, z klasse said:
Front Spring:  5Q0411105GK
5Q0411105GK is a standard ride height front spring. This spring is colour coded with one blue dot and one green dot.
  • Replies 106
  • Views 39.5k
  • Both Rieger rieger-tuning.biz
  • I asked the same question many moons ago when I got my Mk3 VRS and there wasnt any, nor was they any springs for the vRS at that time. Whether its changed since Im not sure as it was 4 years ago.
  • JohnnyType2
    JohnnyType2
    got mine done, but im in Ulster so the roads are marginally better, although i thought you had much better surfaces now? anyway heres my vRS with TUV approved H&R springs 40mm over standard a
Ok so now I am on a bilstein set up but I am removing the spring and I want to go with H&R but not the 30 or 40mm drop. Do you have the part number for the 20 - 25mm OE Sport Spring?
I don't have part numbers for H&R but Eibach sport springs are more popular than H&R springs, because you get a better ride. H&R springs are well know to make the ride very hard.
Whatever you go for, you need to make sure that the rear springs are for the multilink rear suspension that the VRS uses. Most Octavia MK3 front wheel drive cars up to and including about 150PS don't use multilink rear suspension.
Edited by Carlston
Yes I am searching for this. Eibach are also popular. Any idea what’s the drop in eibach and part number? Appreciate the inputs that you have given.
autodoc.co.uk are listing these Eibach springs for the Octavia MK3 VRS, but you would need to do further research to find out which ones if any are suitable. Perhaps use google to search briskoda.net for owners who have previously fitted them. There are often problems such as the front or back being too high or too low, etc.
Eibach Pro-Kit springs E10-79-010-02-22 kit comprises the following front and rear springs
F11-15-021-02-VA front springs
Lowering 20mm
Wire diameter 11.75mm
Length 254mm
Number of coil turns 4.8
Axle load 1075kg
F11-15-007-15-HA rear springs (10mm lowering)
Lowering 10mm
Wire diameter 13.5mm
Length 296mm
Number of coil turns 8
Axle load 1150kg
https://www.ebay.co.uk/itm/186138388710
https://www.amazon.co.uk/Eibach-Pro-kit-E10-79-010-02-22-lowering-springs/dp/B00J2SIDRS/ref=sr_1_1
Eibach Sportline springs E20-15-021-05-22 kit comprises the following front and rear springs
F21-15-021-02-VA front springs
Lowering 25mm-30mm
Length 255mm
Number of coil turns 5.2
Axle load 1100kg
F21-15-021-05-HA rear springs
Lowering 25mm
Wire diameter 13mm
Length 281mm
Number of coil turns 8.2
Axle load 1150kg
https://www.ebay.co.uk/itm/156064438336
https://www.amazon.de/-/en/E20-15-021-05-22/dp/B0154YYDKO/ref=sr_1_1
Eibach catalogue
https://www.eibach.de/de/
Edited by Carlston
Eibach front springs
F21-15-021-02-VA
F11-15-021-02-VA
Eibach rear springs
F21-15-021-05-HA
F11-15-007-15-HA
Thank you brother. Will do my research.
F11-15-021-02-VA front springs (20mm lowering)
F21-15-021-02-VA front springs (25mm-30mm lowering)
F21-15-021-05-HA rear springs (25mm lowering)
Eibach catalogue
So I found the springs I am looking for.
E10790100222 is the set for 20mm front and 10mm rear.
https://www.eibach-shop.com/eibach-springs-skoda-octavia-combi-5e5-2.0-tsi-rs-2.0-tdi-rs-p-422868.html?number=E10790100222
This matches the axle load as well. Hopefully should work well with the Bilstein B6 and bring down the height to a better level to avoid the front end going off..
