Fog light stuck on - won't switch off
Recently picked up a 2007 Fabia, and figured out that fogs and spotlights are switched by the headlight switch being pulled or pushed.
Irrespective of where the switch is - In, Halfway or Out - the fog lamp is on, when the headlights are switched on (irrespective of speed and direction, so no connection to cornering or reversing)
Anybody know if this is an easy fix - presume the switch fascia needs to come off?
Thanks for any hints/tips
I would think its a switch problem. I think its probably easy to pop the switch out with the bit of trim its mounted on.
You could always pull the fuse as a quick fix.
Edited by xman
Thanks man, is the fuse readily identifiable? Don't generally look under bonnets unless the washer or oil need topping, but since not working got to become more DIY active ;)
Thanks, I just swapped bulb for a new one, and that's resolved it...seems a bit odd, but works.
N
Hum, I agree, I like to find a reason for things failing, not good, this might not be the end of this tale?
Have you examined the bulb that you took out and checked if it was still "okay" looking or damaged internally?  If you had the inclination it might have been a good idea to refit that original bulb and see if that fault came back immediately, sounds like being the thing I would have done (sitting in my nice warm house drinking a mug of tea!!).
Probably wrong bulb was previously fitted single/double filament offset/non offset pins or fitted/forced in wrong and shorting parking circuit and fog circuits.
Ah, my brain had told me it was a front fog light!  Now that makes a lot more sense if it was a rear one!
