 Replaced cabin filter, I think this is the first time it has been replaced in its 20k mile life. Manky...
Replaced air filter, cleaned up some foreign objects blocking the turning vanes in the intake. Probably gained 5hp now... Lol
  • Replies 5.4k
  • Views 659.2k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
1 hour ago, UndertheRadar said:
Try some APC with a drill fitted carpet brush and if needed steam it first if you can.
What’s APC?
23 minutes ago, MICKSVRS said:
What’s APC?
I use this one as it’s cheaper to buy in the long run, but there are many different ones from the likes of meguiars or valet pro etc as well.
just realised you can’t tell, but that’s a 20 litre drum. Makes the above easier to understand.
Edited by UndertheRadar
Thanks for that 👍
This, replace the missing accelerator pedal cover. Which is a job I never want to have to do again
And this, which totally changes the look of the front end considering what a small detail it is 👍
Well done 👍
If you ever happen to do it on a future car, slip some washing up liquid on the underside and it slides on much more easily.
27 minutes ago, boydeee said:
Well done 👍
After dicking around with it for what seemed like hours I ended up cutting a chamfer on the lip and it snapped straight on, didn't want to cut it as it was OEM, but needs must lol
Needs must indeed! I spent ages doing it on a previous car and then tried lubing her up this time for the Superb 😉
On 26/07/2020 at 20:44, newbie69 said:
Sure, it's just gonna take a few months before I attempt this so stick around till next year please just in case :D
Regarding brake fluid, I plan on putting together a better/bigger brake kit for my 272 soon. I am in the process of finalizing the components (actually I'll open a thread for input, never hurts) and I have questions regarding the bleeding process of the brakes. Might PM you then!
@newbie69 Hi, coming back to this discussion:
I've released the tutorial for brake fluid change: Enjoy! ;)
The technique I employed when fitting mine was to gradually increase the vulgarity of the swear words I aimed at it until it gave in.
Eventually worked although the neighbours did get an ASBO served on me 😁
7 hours ago, lowey said:
I’m pleased with the results 👌 Custom Stage 1 tune by a local company.
Assuming that was a 280?
Well the later 272 with gpf
On 12/09/2020 at 18:10, thousandsons said:
Gloss Metallic Chameleon Purple Blue wrap using Teckwrap USA .
The metallic chameleon finish brings out the muscular lines of the Superb and accentuates the side profile spectacularly as well.
Love that.   Chromaflair always reminds me of one of my primeras
Yes. Does look stunning. Takes it out of 'sleeper' for me though. Primera, forgotten about them, I was thinking TVR. Either way i imagine wrap will be cheaper to redo than the paint on either.
Your standard engine was very similar to my figures of 283bhp and 369nm.:)
Busy week this week, car has been in the workshop again today for some more work....theirs numerous threads regards retrofit of the rear view camera but i wasn't confident enough to buy the kit and give it a go myself like some have so i took it to a local guy and in under 2 hours i was on my way home and another box ticked
@lowey how much did they charge as I see you are fairly local to me and a job I would like doing sooner rather than later?
 Just down the M42 junction 2 in Redditch https://www.vw-retrofit.co.uk/
cost me £380 inc
2 hours ago, lowey said:
 cost me £380 inc
Good price. I bought mine from TPS, fitted it myself, and got Skoda to code and calibrate. Cost me about £350 all in. Plus the best part of a day of agro for me and a mate! (Having not done it before it took a lot longer than it should have. Learning how to to overcome problems etc).
You definitely made the right decision. £30 for no agro!
On 12/09/2020 at 11:12, Mexico75 said:
Yeah but it's not as easy, floss wasn't really up to the job, I ended up breaking mine to get it off which left a lot of adhesive that needed cleaning off.
There’s not a chance in China that dental floss (with a heat gun) will get the new emblems off. Plus you were spot on with the amount of adhesive left behind.
only managed the bonnet as it was getting dark but will do the rest tomorrow evening.
Okay, I'll definitely do those badges tomorrow morning.
Had a sh1te day that started with a kerb.....
did some boot and rear seat deadenings today, you can notice some improvements
Recently Browsing 1
