1 hour ago, MarioVrs said:
Very nice 👍🏻 i like it a lot 😊 would you be kind enough to share link to it?
Looks like ECS tuning one but with a different sticker like here
  • Replies 5.6k
  • Views 733.2k
  • Well this was something else....   Not bad for 14 hours work.
  • rob_g_clarkson
    rob_g_clarkson
    Had the wheels refurb'd... and new centre caps and new tyres all round. Much much nicerer. Before and after
  • BriskodaJeff
    BriskodaJeff
    Chucked a bucket of water over it. Three hours later this is the result.         Happy with that
23 hours ago, MarioVrs said:
Sehr schön 👍🏻 Mir gefällt es sehr 😊 Wären Sie so freundlich, den Link dazu zu teilen?
Search for ECS Tuning, as previously posted. I just wrapped over the decal because I didn't want the advertising. You need to look in the Golf 7 section.
Great thank you 👍🏻
Changed the front brake discs and pads this morning to try and finally cure the brake wobble. Seems ok so far but let’s give it 200 miles or so to reappear like it did before. All went without drama using the excellent @Bap33 guide Here.
I also swapped back to my standard wheel without paddles. For the small amount of instances that I used the paddles I would rather have an airbag that fits properly!
So if anyone wants a round leather wheel without DSG paddles that fits the newer style airbag, I have one for sale!
Left tail gate strut failed - lots of beeping not much moving.
Popped it off to find the wires have broken. Quick + dirty repair to make it work again whilst I order replacements.
New struts purchased and installed. £80 for a pair on ebay shipped next day from the UK.
Popped old ones off, popper new ones on. Job done.
Will give away the old struts if anyone wants them and can do a better repair job than me.
Nick,
Can I ask where is the connector is located for the strut and how do you access it to dis/reconnect it?
36 minutes ago, numskull said:
Nick,
The connection is inside the rear pillar. You pop off the trim in the car, unplug, pull off grommet, pull cable through.
See this Youtube video I used
One of my rear parking sensors had started to corrode in the centre.
I had a spare that came with the car when I bought it so swapped that over today. Managed to get to it by just loosening off the under tray and working by feel. Straight plug and play swap and all tested working.
Kept the old one as a backup spare it still works.
Had new ECS tuning steel oil pan and Racing Line oil filter housing installed and new oil put in 💪🏻
An aluminum oil pan is nicer. I had a steel one for a year, but the threads for the drain plug weren't good. Then again, it wasn't from ECS
Very true about being nicer but for me it's more of a practical mod, car is getting lowered next month not much but where i live there is awful lot of speed bumps
Today I started the blind spot detection project. Trying out a basic AliExpress kit for £50 rather than OEM for £500.
Bumper is a pain to remove thanks to two awkwardly angled torx screws under the wheel arch which requires the car jacked up to access.
First problem after that was that the OEM radar brackets I bought from eBay to make mounting the radars easier didn’t fit. Turns out I had bought hatchback ones rather than estate so they didn’t fit!
A bit of fettling and the brackets that came with the kit were made to fit, mounted onto one of the studs that holds the plastic trim on. All set to the correct angle.
Cables routed into the car through a couple of grommets. Bumper back on and that’s the first stage done.
In that case, I'd rather have OEM control units than the AliExpress knock-offs
You’re more than welcome to for your car.
This is my project to pass the time as my hobby on my car.
If it works great. If not then I haven’t wasted a lot of money. It’s a nice to have. All of it is reversible.
Edited by Binx1310
And 2 Warning LED each Side ^^
Plan is to loosely fit the led that came with the kit near the a pillar inside. Then if it works well enough I’ll replace with led in the mirror housings for OEM look.
That is, provided the control units can actually drive the OEM LEDs. Since it’s not the OEM control unit, you don’t know how the LED is powered
2 hours ago, Binx1310 said:
Gerne können Sie Ihr Auto abholen.
Dies ist mein Projekt, um mir als Hobby die Zeit mit meinem Auto zu vertreiben.
Wenn es super klappt. Wenn nicht, dann habe ich nicht viel Geld verschwendet. Es ist schön zu haben. Alles davon ist reversibel.
They can do whatever they want. I’m still entitled to my opinion, though.
I upgraded from the OEM 5Q0 to the 2Q0 myself, so I know exactly what the job entails
OEM led are 5v 2 wire. Ali express kit is 5v 2 wire. I’ve bought a spare set of plugs and will plug them in and see how it goes.
Yes of course. Difficult to judge tone through text. 😃
I took a judgement on cost and hassle vs reward and chose to try out a cheap option. If the brackets had fit, it would have meant I ended up with OEM brackets and lights and if I wanted to upgrade to OEM I would add radars and wiring loom. Chatted it through with @Cairus and seeing others who have done it I think the coding for OEM is beyond my remit.
Next project is all OEM! 😉
14 minutes ago, Binx1310 said:
OEM-LEDs sind 5V 2-Draht. Ali Express Kit ist 5V 2-Draht. Ich habe einen Satz Ersatzstecker gekauft und werde sie einstecken und sehen, wie es funktioniert.
It depends on the LED. But 5V works—that's correct
OEM is just a neat solution, I think.
Yes. If it works mine will look the same.
That looks very different to what is OEM for the liftback/sedan.
Nonetheless, good luck with the project.
This is how they look.....
Oh the old 5Q0 Interface... 😜
Recently Browsing 2
