ARB bush clonk issue. Newish bushes
The brand that I bought from ECP is Lemforder, which along with TRW are ZF brands.
Now ECP sell a cheaper brand as well, but first time round I bought Lemforder and so this time I did the same.  VW Group parts seemed a bit expensive for me, I have never replaced these bellows and would not expect to need to unless they had got damaged for some reason prior to this repair.
When I bought these parts for my wife’s 2002 Polo many years ago I bought the complete assembly, ie rod and TRE and locking nut as that was cheaper than buying an inner rod and a TRE, when buying these same parts for my daughter’s late 2009 Ibiza I found that for ECP, the complete assembly was out of stock as far as the Lemforder version was concerned so I had to spend slightly more and buy the individual parts.
EDit:- as said previously, TRW supplied the complete steering gear to your car - unless it is a very early car with Koto steering system, but without looking back, I think that your car is new enough to have to be TRW.
Another Edit:- right, your car is a 2007 so must have TRW steering system.
Edited by rum4mo
  • Replies 161
  • Views 14.4k
  • 32mm crows foot spanner and two extension bars worked well for me.
  • @bmbmdmb  Given the angle-tightening after torqueing, get a suitable spanner and measure its length in metres. Convert this length to a vulgar fraction (eg a 0.333m spanner becomes 1/3). Get a spring
  • I got a reply from Powerflex, which will be useful for anyone going for PU Powerflex . I just don't want to have to mess around changing parts on the car more than twice. Time. Cold, etc. It ha
I had one spilt completely in half on my Fabia so I'd definitely recommend replacing them. I used Febi branded ones. There are two different types of bellows but they will both fit as I found out by buying the wrong ones.
Quote
It's Koyo not Koto.
Edited by TMB
Bother, Koyo - sorry, I'm sure that it used to have two names like To?? Koyo - but I can find nothing now to back that up, not even on Koyo's website!
I think they might have been called Sona Koyo, or maybe that name came later.
I've found it now, they used to be known as SMI-KOYO, all I need to do now is to remember that!
Update:
Nearside was clunking / twanging after large speed bump.
I decided to change the inner track rod, having previously done outer track rod along with ball joint, shocks, spring and ARB, droplinks.
It appears it is not inner track rod end. There is no play in the ball joint.
Anyone replacing this, the gaiter you need will need a 5cm exactly diameter at steering rack end. I had to use original which was more plastic than rubber. The replacement I was assured would fit was mainly rubber.
The tool I used was a 30 to 45mm diameter neilsen inner track rod end tool, the toilet plunger like tool. It worked a treat. Torque is 80nm.
There is an octagon after tapered joint but access is limited. Crows foot spanner possible , but getting sufficient torque difficult.
I'll post Borg and Beck part number as there were 3 possible part numbers for my car, luckily I had part off car to check in shop.
I've yet to do driver's side, might as well. Apparently, both inner track rods are identical and interchangeable.
Next job is the console bushes. I bought Cupra ones.
What did you use as a clamp for the rack gaiter at the rack end?
Jubilee clip. Screwdriver could access from diagonal. I had a 30cm long flat ended screwdriver to hand.
There is a rubber flat ring that wraps around steering rack tube under gaiter to help seal when jubilee compressed. Not shown in pic.
Could driver's side be loose and cause noise on nearside or is it likely to be console bush? BTW just bought Cupra bush
I used hose clips too :thumbup:
Yes I noticed that flat rubber ring on mine.
Driver's side wouldn't cause noise on the passenger side but noises on cars can be deceptive. See what it's like after you fit your Cupra bushes.
The rear wishbone, console bush looks knackered. After removing wishbone I put crowbar in and with little effort there is alot of play.
The camber figures on nearside of last computerised alignment showed it out of range. Would this bush cause this?
As for Cupra bush. Has anyone had to replace these. I forgot about the nightmare of cutting out old bushes. I think I will go powerflex and return the Cupra ones. Also pressing in the Cupra bushes will require dropping of subframe, possibly.
I got the front wishbone bush out. Set it alight and then drilled out rubber and twisted metal tube with large pliers.
Cupra bushes will last slightly longer than the solar system itself. They're just as good as PU but trickier to fit.
Okay thanks, I'll sleep on it, not the Cupra bush BTW
Only the Cupra bushes have a metal outer shell so am confused when you say you removed yours and it had metal on it?
  • Sponsor
No.
What were the figures?
Camber can be evened up if one wheel is too upright and the other too leany-inny, by adjusting the positions of the consoles relative to the body/chassis. The holes in the consoles are 17mm and the bolts that go through into the chassis are M12, so there's +/-2.5mm adjustment possible side-to-side for camber evening, or fore-and-aft for caster, or combinations of both.
Trouble is it's going to be a case of lots of small changes, and multiple careful measurements and markings to make any sort of improvement.
The consoles are also bolted to the subframe/steering rack, so that forces them to move together in the side-to-side plane, hence only being able to even up camber rather than increase or decrease both sides.
Having loosened off the consoles from the chassis on both sides, it would be quite easy to lose track of your starting point and really stuff things up, so don't go there unless you are confident.
No, the early standard void bushes had a metal shell as well, my old 2000 1.4 had them.
^ Really? Wow, didn't know that!
  • Sponsor
OP is referring to the front bush with his burning and tube twisting, no?
Ah, I think you're right there. Waste of time touching those but each to their own.
11 hours ago, TMB said:
metal outer shell
Front wishbone bush. Centre tube is metal surrounded by just rubber with a lip over wishbone at both ends. This is the bush that doesn't wear out. Lots of wd40 and gt85 helped get it out.
10 hours ago, TMB said:
Yes
Going back to refitting the steering rack bellows on the LHS ie NS of the car, that rubber sealing sleeve really really annoyed me as it kept sneaking out and so the plastic bellows could not be tightened, then I remembered how I did this job last time (quite a few years ago) and fitted a plastic cable tie over the section of rack housing that the rubber sleeve escapes across to - then pushed the bellows on, that worked well, then after clamping the bellows, I used wire cutters to remove the first cable tie. I do confess to just using cable ties over the bellows and they seem to have worked, bellows are both tight enough and don't rotate when adjusting the toeing.
bmbmdmb, you say that the inner knuckle you replaced was not slack/loose - same for the late 2009 Ibiza I changed both steering rods and TREs on, but I think that the spring plate that keeps these knuckles tight enough while allowing articulation, at least in my case, had started not being effective and so it could be allowing that knuckle to rattle while the car was being driven, certainly the Ibiza I was working on has lost the knocking that I could feel while rocking the steering wheel back and forth.
I might still try to fit the correct Oitiker clips and tighten them in the future - though I will not guarantee that I will, I tried most methods of tightening the driver's side originally including fitting tube extensions to a pair of heavy duty wire cutters with the cutting faces blunted - I must remember that the next time I try to use a couple of wire cutters, or resharpen them!
Edit:- just another comment, I bought a pair of Sachs rear dampers from ECP last weekend while a "good" discount rate was being offered, though worried slightly that a better deal might come along at Easter, but I needed to finish this job by tomorrow as my daughter returns from holiday, for curiosity, when my latest ECP flier came in with an even better, ie "great" discount rate, I just had to check up on how much money I had lost by buying last week - I had saved £1.76 by buying while the lesser discount rate was being given! Not everything is what it pretends to be sometimes!
Edited by rum4mo
metal outer shell
Yes
Quick question about Cupra bush orientation.
https://www.darksidedevelopments.co.uk/products/ibiza-cupra-uprated-console-bushes-for-vw-polo-skoda-fabia-and-seat-ibiza.html
I was told to fit the recessed towards rear of car by Dark side.
I just read the DIY guide on Briskly and it states flush side of Cupra bush to rear of car/ console.
Now I'm in doubt...
New aftermarket bellows that don't fit came with tie wraps, plastic.
The outer clamp was a spring clamp requiring only compression.
The inner metal clamp tie had an opening for flat screwdriver. The 30cm long Aldi screwdriver I got in allowed me to twist and break it in one go. So, much easier job than expected. Some folks have removed battery etc and come in from above to access this.
10 minutes ago, rum4mo said:
spring plate
Is this in the inner tie rod tampered joint? I'm changing them both at mo, as I've splashed out on tools. All good fun. The inner tie rod threads were starting to corrode anyhow. Both sides cost £30 so not major outlay.
Part number for inner tie rod is BTR5646. Borg and Beck. One side is now fitted and is same size in all dimensions.
Yes
Now I'm in doubt...
Well, from memory, back in 2007 when I got a very good VW Group Indie to fit Cupra solid rear bushes to my wife's 2002 Polo, they fitted one one way and the other the other way, so I got back to them and supplied a new bush to get fitted in what I thought was the correct way, which is flushed/flat ends to the rear of the car - and that looked better and worked okay for many years - that car was sold on  in August 2015. The design looks like in both cases that the recess is only there to allow the TCA peg and the transition from that into the box section of the TCA to fit into the position correctly.
