Electrical system
One more thing. The most effective solution would be to tin all tracks too. The copper tracks are so thin that they develop micro-cracks visible under high magnification only. They are responsible for all those intermittent faults so hard to diagnose. In other words, the PCB might look well, yet under the slightest vibration continuity is lost.
  • Replies 65
  • Views 16.3k
  • Fuse 21 is for turn signal lights (left and right) and reverse lights. There is a short circuit in the tail lamps, probably from corrosion.   1) Disconnect negative battery terminal.
  • So what was the cause for fuse 21 burning repeatedly? Previous superficial repairs and poor insulation of the wiring? I have assumed that you know about bad wiring made by previous owners or by y
  • Well, that could certainly cause electrical problems. I would suggest removing this non-original alarm system.   Also, on your English, the only thing that doesn't show up as a typographic e
yes but you need to remove green solder mask first
I renewed my solders.
Tried with 12v 2a adapter no problem.(of course only clock and lights)
As you said, we will look at what will happen with the vibrations in the vehicle.
I hope the "PCB" is ok.
Otherwise it will be a much more difficult process. 😊
Edited by mturgut
You can test the board by tapping it in various places before installing it back in the dashboard. Of course, while the power supply is connected.
Good advice,
I will try tomorrow thanks
Hello there,
What is the green piece found here?
one side is broken
I soldered again
That is a power resistor. I can't remember now what is its role but I will tell you exactly later today.
No problem after 1 hour of usage.
I hope it won't be a problem anymore
Thanks a lot for your help 😍
It is a 82 Ohms / 2 Watt resistor. Its purpose is to protect the charging alert lamp when there is a fault of the alternator regulator and the voltage goes high.
  • 4 months later...
Hello again,
I want to renew the (-) cable of the car battery,
but one cable has two different ports (indicated by red and green shapes)
and I can't find the (L) shaped terminal marked in red,
Maybe if I pull two separate wires from the place marked blue instead, will it do the same job?Battery2.thumb.jpg.cd06408fcd4d39b0e93c1f64c2fdb0a5.jpg
is there someone who can offer ideas?
the terminal in red is THE MAIN chassis groung  you can run a beefy cable from the battery to there and you would be good to go
I will try your advice,
and in turn I'll rebuild all the cables.
I replaced the old one with a 25mm two-piece cable.
The temperature gauge has been working properly since I changed the cable,
It looked different before, more than it should be,
When I turned on the lights, the temperature indicator was rising while the radiator or heater fan was running.
Now everything works fine
you see proper grounding is a reallyyyy big deal
