I need Bolero Update :-)
24 minutes ago, Cayman85 said:
What about change the entire system? If i change mib1 to mib2. Beacuse i have to plan drive this car for the next 6 years or more. Maybe is cheaper to change the phone but still...
@pab567might be able to recommend you a possible replacement, or indeed be able to supply you one to fit.
  • Replies 1.2k
  • Views 216k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Glove box unit must be replaced, from approx. 200 GBP up for fully reworked (unlocked and activated) unit.
On 21/11/2022 at 15:27, varooom said:
You can try MSTD_EU_SK_P6230
MU 0490
Will PM you a link over
Thank you very much. Got it done from a USB stick no problem :)
noticed some UI differences, smoother and feels like some volume changes also.
Hallo Ich brauche auch Bolero update, kann jemand mir helfen?
Vielen Dank
Vielen Dank
You should write in English in the forum, I cannot read what you are asking.
This is the current version for your software train, so no update available.
MST2_EU_SK_ZR_P0138T
Hold your Menu/Setup button for ten seconds to enter engineering menu and find this value to verify.
Thank you for the information,
there is absolutely no way to update, attached is my version
Thanks a lot
Thanks a lot
There's no official way to update, as only exist 0138 version.
There are...
01xx
02xx
03xx
04xx
05xx SEAT
Software train values.
You can update from say 02xx to 04xx, but this is not the forum and process is dangerous (also you may miss features)
It's best you keep existing version.
Last choice is to purchase a replacement unit with new firmware say in 04xx range, you may also need different screen too.
my problem is that I can't use Mirorr link, my phone has Android 12, Android auto unfortunately not available
Mine has latest 0253 version, I can enable... but it won't talk to my phone regardless.
So I just use bluetooth for calls.
I suspect that you could load any of the software versions (dangerous as mentioned) and still your mirrorlink will not function if your phone is not on the 'list' inside the unit of tested phones.
Nevertheless, many thanks for your help, very fast and competent.
I have 2016 Fabia 1.2 TSI Style Manuel.
I'd like to update my swing radio please, could you send me an update link please ?
I live in Turkey. I use the multimedia language Turkish. Thank you very much in advance.
/cdn-cgi/mirage/7f3a4109b7c9db5275ba0696e58b3cb7d9ae65c743ad6ace706caf7e66e199cc/1280/https://www.briskoda.net/forums/uploads/monthly_2023_01/unnamed.thumb.jpg.056b6040c96a2105fd34fd83dc12bfdc.jpg
Hold down your menu/setup button for about 10 seconds to enter the engineering menu.
Look for Software Train information.
Post back an image.
Post back an image.
Ok
2 minutes ago, varooom said:
I will send 0369 soon, and the above image is your update location.
5-10 minutes.
I found version "mst2_eu_sk_zr_p0478t" from internet. Do you think I should install it?
Nope, the latest in 04xx version is 0480, but you have big risk to break your radio.
So if you have 01xx 02xx 03xx and so on, you need to stick with your correct series.
Yes it is possible, but not recommended by me.
1 minute ago, varooom said:
Hayır, 04xx sürümündeki en son sürüm 0480'dir, ancak radyonuzu bozma riskiniz yüksektir.
Dolayısıyla, 01xx 02xx 03xx vb. varsa, doğru serinize bağlı kalmanız gerekir.
Evet mümkün, ancak benim tarafımdan tavsiye edilmiyor.
Ok, I'm waiting for version 0369 from you.
5-10 minutes.
I downloaded and installed version 0369. It took 17 minutes. Everything is great at the moment.
thanksssss
Hi, hello.
Could there be any updates to my  Bolero ?☺️
Thank you :)
6 minutes ago, darkan7 said:
Hi, hello.
Thank you /cdn-cgi/mirage/7f3a4109b7c9db5275ba0696e58b3cb7d9ae65c743ad6ace706caf7e66e199cc/1280/https://www.briskoda.net/forums/uploads/emoticons/emoticon-0100-smile.gif
/cdn-cgi/mirage/7f3a4109b7c9db5275ba0696e58b3cb7d9ae65c743ad6ace706caf7e66e199cc/1280/https://www.briskoda.net/forums/uploads/monthly_2023_01/Clipboard01.thumb.jpg.66adf96b12faefd4dc690629eadd54b5.jpg
You will need to update in engineering menu, so hold your menu/setup button down for about 10 seconds to find Software Train information.
Anyhow, I will send you what I think you need.
Hello,
Do you have a new firmware for my system ?
Thanks for your help.
1 hour ago, Gonzague145 said:
Hello,
MST2_EU_SK_ZR_P0138T is available if you still want it.
Can you send me it by pm ?
Yes of course
Hello, is there an update for my bolero? Can someone help me. Thanks.
SW Train             MEN3_EU_SK370_P0113P
MU SW                0469
ItemNumber      654035869B
Hardware           032
Software             0469
