Amundsen MIB2 Firmware Update
28 minutes ago, pab567 said:
Maps you showed on picture (1410) are NOT the latest version - on th ewebsite I linked you will find 1520
Now that makes sense. Thanks a lot. Sorry for taking your time, I understand that discover media is amundsen level, but why beetle ones and not passat? Just to understand more for future updates?
  • Replies 4.7k
  • Views 935.6k
Because maps are the same and with Beetle you cannot make an error (there is ONLY Discover Media = Amundsen) whil with Passat there are multiple options.
Matte you're "a head of the game", good to have you here. :)
Hello,
I have H41 with 0472 software.
There are few annoying bugs especially with volume that goes only down...
Can You please share link for newest 0478 firmware?
Tanks in advance.
Hey Good afternoon,
I have a passat b8 and need to update the fw mib2 discovery pro could I pass the last available FW to this MIB?
8 hours ago, pab567 said:
These are the same maps... there is no "Skoda" and "VW" and "SEAT" version, it's exactly the same set of files...
Mate just updated the latest maps from vw portal. The problem stays the same.
Hello good afternoon, I have a passat b8 and need to update the fw mib2 discovery pro. Can I pass the last available FW to this MIB? Upgrading from the current FW MHI2_ER_VWG11_P3301_MU0814 -> MHI2_ER_VWG11_K3332_MU1187 What would change or improve?
Unfortunately I have no idea hot to help you :(
@Fernandoberracoso why do you want to upgrade? Are there any problems with your unit?
You already did a lot. Cheers!!!
20 minutes ago, pab567 said:
Infelizmente, não tenho nenhuma ideia quente para ajudá-lo :(
@Fernandoberracoso por que você quer atualizar? Há algum problema com sua unidade?
hello good night, I enabled some functions but they are not showing up in the mib, the seat option for example does not appear and is enabled with vcds.
thanks for the reply so brief
Then make an update... and pls do not use such big font...
thank you very much, I will update and thank you for your support ... I apologize for the large font. hugs from Brazil to everyone.
Hi, can I get update files for 0478 version?
Thank you!
Hello,
I managed to update my maps and i tried to call VW to update my firmware and they said they do not do that in no way. So long story short i am here asking for help updating my device
Hi there, I'm wondering if pab you could please send me the info I need to update my firmware?
Also, is the install simply putting it on to sd card, into the car, then updating?
If yes, would I confuse the car if I also put the navigation update on the same sd card? Maybe I should do them separate?
Thanks in advance!
Paul
hello,
I posted my request under a new topic :
sorry for that double post.
I have this configuration :
Ref : 5Q0035864C
Hardware : H41
Software : 0472
I wanted to update for Android Auto troubles and so I am looking for a link of the lastest version (apparently 0478?).
Thanks for your help.
Hi pab567. Please can you provide the latest software update available for my device? Thank you.
I would also like to ask for an update review:
PN: 5Q0035874C
HW: H41
SW: 0472
Any catches?
Many thanks,
@pab567 can you check if there is a possibility to do any updates here ? Also there's no update button, maybe when i stick a sd card in?
@pab567Hi , can i also ask to check the new fw? Amundsen and Skoda Octavia.And possibly if I can ask for the update procedure. Thank you very much
I've already written up an article on how to upgrade the firmware on the Bolaro and Amunsden systems:
Hi, thanks, I guess I was wrong. I read your post even though it is on the 2.5 system, I am mainly interested in which file to download and possibly if it is possible to update in a few steps to the higher version, since the system was probably never updated. Still, thank you for your answer
Im on 478.
Anyone also having issues that Android 11 mobile is not properly working as a mobile Hotspot for the Amundsen?
