Amundsen MIB2 Firmware Update
Hi , could you help me please if there is a new firmware ..
Best Regards
  • Replies 4.7k
  • Views 898.4k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
problem with this Screenshot_20210217-192540_WhatsApp.thumb.jpg.e1c31dcb898d1333e84fa45140b940b9.jpg
Hi, could you please help with new firmware for my octavia '18, thanks!
Hi @pab567,
I havethis device on Octavia 3 :
Device part number: 5Q0035874C
Hardware: H41
Software: 0475
Is there a newer version available?
Thanks in advance
Hello @pab567 :-)
I need also your help please.
I have a Yetii with this :
Software is 245, I have teardown the module
Do you have a newer version ?
Thanks a lot
Ivan
All check your PMs
Can you help me too :-)
Hi, I have a problem after the update.  SWAP codes are no longer active and I can't longer use Bluetooth, Smartlink, Navi ...
Does anyone have any idea what I can do?
Hi, hope you all are safe and well. I am looking for firmware for Below
Hi Pab,
I went through a lot of this pages here seeing you helped so many guys with firmware. I really appreciate your work and serving the community. Thank you so much.
I am having issues with CarPlay stability. So I went looking for a firmware upgrade and I found you here.
So I am kindly also asking you to check for my radio:
Thank you so much!
Christoph
Hi @pab567!
I am as well looking for an update due to serious problems with CarPlay functionality and some other things.
Could you please have a look to see if there’s an update for this:
Best regards!
Hi @pab567
can you tell me, if there is a newer software available for 5e0035043c, h42, currently running 0411? Thanks in advance.
On 22/02/2021 at 15:44, hagel60 said:
Hello I have this unit MST2_EU_ PQ_P0138T 5L0 035 680   is the new firmware version ... can the Romanian language install ?
Unfortunately there is no newer version for your unit :(
If your unit was factory installed then it should not have happened. Or is it retrofitted hacked unit?
19 hours ago, Chris_muc said:
Hi Pab,
Thank you so much!
Christoph
Unfortunately I don't have firmware update for your unit - although I have seen units with newer version (0363).
10 hours ago, SuperbSwe said:
Hi @pab567!
Best regards!
Firmware you have is the most recent I know :( so if you have any issues I recommend to raise complaint (as I expect your car is still under warranty). But first try another cable between USB port and your phone.
Edited by pab567
8 hours ago, gerstemann said:
Hi @pab567
No... 0411 is the lates one.
All others pls check your PMs.
yes, it has been retroffed.
I solved it and now it's ok.
Thanks!
thanks to cd01101 for helping me activate android auto respect
Dear Sir, please would you help to share a link for update my amundsen to latest software . Thank you.
carradio.jfif
Sorry Here is picture.
please help me to udpate my amundsen to latest software . Thank you.
Hardware:H30
Software:0359
Hi!
Can I have FW/SW update to my 2018 Octavia Canton system?
Thanks and kind regards
JSo
Hi @pab567  is there any chance i can get software update for my device?  Part no. is 5Q0035874B, Hardware is H30 and the current software version is 0361. You seem to be the go to person to ask any help is greatly appreciated thanks
Hi
Update for this??
Ovtavia 3 ,  2019.
I have management problems
Hi
Update for this??
Ovtavia 3 ,  2019.
I have problems
