Amundsen MIB2 Firmware Update
Update installed fine, now trying it out to see what differences there are, if any.
  • Replies 4.6k
  • Views 769.5k
Hi . I need update from 5L0035680E SW0353 , HW H30 . Many thanks in advance
Hi, do you have a newer firmware version available ?
Thanks in advance!
I would be grateful ih you could send me a new update.
Hi @pab567,
Please can belatedly join the bandwagon too?
you let me know if I have the latest version?
device: 5Q0035874A
HW: H25
SW: 0245
thanks
Chris
On 24/09/2021 at 12:59, MX-5 said:
Hi - would appreciate link to update, if one exists. Many thanks in advance.
There is no update available for your unit.
All others check your PMs
Thanx pab !
Thanks a lot @pab567
At the same time to ask if i am violating the car warranty with this. The car is still under warranty.
Nope - Skoda dealer won't rise an eyebrow.  You will be fixing issues, not breaking them!  If it makes you feel happier, then make sure you perform the firmware checksum on the MIB software version.  That way, they definately won't know!!! 🙂
Hello,
can anyone send me a link where to download or check newest firmware version for Amundsen?
Part number: 5Q0035874B
SW version: 0359
9 minutes ago, Vasilek91 said:
Hello,
SW version: 0359
Please have a look at that post:
Hello,
I have the following part
MST2_EU_SK_ZR_P0359T
ref 5Q0035864B
SW version : H28.28.133_STD2Nav_EU
Does it exist any update ?
And does this version is fully compatible with mine MST2_EU_SK_ZR_P0367T ?
Thanks !
Hi @pab567
Is there an update to my system ?
Thank you in advance !
All check PMs
And for me ? Thank u
0369 firmware download?
Hey!
Is my firmware the latest or do I require an update?
Thanks guys!
Salut
je souhaiterais changer la version de mon logiciel  est passer sur la dernière possible.
Auriez vous un lien avec comment le faire .
Merci par avance.
Skoda octavia rs 184cv de 2015 autoradio colombus MIB2
47 minutes ago, octaviavrs5e said:
Salut @pab567
je souhaiteais changer la version de mon logiciel est passer sur la dernière possible.
Merci d'avance.
My 2015 Yeti Amundsen is having freeze probem. Dhe dealer says there is no newer firmware, but, let me try here...
does @pab567 have a big help for me?
9 hours ago, octaviavrs5e said:
Salut
Merci par avance.
First of all - pls be so kind to use English.
This is not MIB2 but MIB1 Columbus.
All check your PMs
suite à la mise a jour ce jour j ai des default  de version en passant sur le vcds  pourriez vous m'aider pour solutionner ca
Merci
Hi Pab, any chance of any updates for my Columbus MIB2 2016 too please?
Thanks in advance. :)
