Amundsen MIB2 Firmware Update
Can I update this unit ?
  • Replies 4.6k
  • Views 849.7k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
Next is 0478.
On 09/08/2021 at 20:42, pab567 said:
@Stevejd58 use SD card. ALWAYS.
Opps, finally had time to do it, successfully updated, fixed the nav button issue that prompted my request
13 minutes ago, cliner said:
Next is 0478.
this is last ? and were i can get this ???
@Zephyrus unfortunately I don't have newer version for you unit. All others pls check PMs.
thx you .. just need to copy this zip on sd ? or need to inzip
So Android Auto has recently been updated to become included into Google maps. What Skoda Octavia infotainment systems will be updated to amd will they work with Octavia MK3?
Unzip and put unzipped in main SD folder.Formatting SD card with FAT32 before.
THX
I think you've miss understood what's happening...
It's the standalone mobile app that Google are no longer supporting.
Android Auto will continue to work as normal when connected to a car with AA support :thumbup:
Dear pab567,
You replied that unfortunately it is not. But I don't know if you wrote this to me and or someone else :) And the others check their PM's.
Cold you please confirm their is or not any update for my MIB.
5Q0035864A , Hardware : H24, SW: 0241.
I have another MIB, : 565035021E, Hardware :H55, SW : 1440
Thank you for your all kind help and answer!
BR,
didn't get a pm :(
  •  Hi can you send me the link  for new Firmware?
  • I have here
  •  H24
  • 0252
  • 5Q0035874A
  • Thanks.
Check PMs - no link means I have no update
Hello,
Is there newer firmware for my amundsen?
On 20/08/2021 at 11:57, pab567 said:
Unfortunately not
Ok, could you send me the link for update 480? If my android auto continues to bother me I will update ...
Thanks in advance,
Dany
Check your PMs
Hi Pab,
All was working fine on my MIB2 retrofit. The battery was disconnected for longer period and now I have same issue described below with the clock on the unit. it is no longer syncs  - it's now always displaying 00:00, with occasional flashes of 6:28.
https://forums.ross-tech.com/index.php?threads/21954/
could you please advise? do you have newer fw ?
Thanks!
Hi @pab567
I would be very grateful if you could send a link for the latest version for mine as well please.
many many thanks
Hi @pab567
many many thanks 🙏
5 hours ago, mcsolle said:
Hi Pab,
Thanks!
Unfortunately there is no newer SW version available for your unit. A solution MIGHT be to reflash your instruments cluster with newer SW however this does not always help.
@Scoutboycheck your PM
I'd be forever grateful for a link for version 0480.
My data:
Device: 5Q0035842C
H/W: 041
Software: 0478
Media Codec: 4101.0.0.0
Hi @pab567if you would have an up to date version for this it would be much appreciated:
Part no: 5QA035358B
Hardware: H41
Software: 0468
Many thanks!
Check your PMs.
Please note I will not be available until September 6th so the requests for SW update will be on hold.
