Amundsen MIB2 Firmware Update
Greetings @pab567, Could you please send me the latest SW for MIB?  5E0035020C HW:H42 SW:0411
Thanks !
  • Replies 4.7k
  • Views 936.2k
Thanks !
Your tag didn't form correctly @pab567
Hi @varooom ,  a long time ago I asked for help on this forum, so I used the same tag... I have a MIB where after a while the touch freezes, I hope a firmware will solve the problem, can you help me?
You already have th elatest SW version 😞
Hi I have tried many different cables and have connectivity issues with Android Auto although Apple Carplay is working good.
Could anyone tell me if there is any FW updates for my unit please?
You have latest firmware at 0253
Maps could be updated to 2010 (from your indicated 1810)
Hi! I'm new in the forum and I didn't found where to post about bolero update.
Where I can found the firmwares to Bolero and there are any post about what it change with the firmware.
Thanks to Varoom I get this picture of my unit.
/cdn-cgi/mirage/ca74ccc0c958c90dcfb1f2893c53ba68e43e63c06f0ba81c9f9acb2c1959ac8e/1280/https://www.briskoda.net/forums/uploads/monthly_2023_02/20230207_232755.thumb.jpg.407cb8a990704aaf99d37ec8827b96e7.jpg
I know a guy who can supply firmware 😁
Thanks Again. 🤩
Hi, this is my first post on this forum.
I need new firmware for my Skoda Superb III Amudsen system.
Would you mind sending me the latest firmware release? Much appreciated
Hello, yes I can send you a new firmware to 0253 version
Also you can grab new maps from this post here...
You have "1910" and is available "2010" version
Thank you.
Now I have problem with installing the firmware. It starts, but after starting again there is error message which says, Error: cannot access file, Faultcode 15, Cannot find the correct medium.
Files are on USB stick which is FAT32 format.
Any advices?
2 minutes ago, JPRaceman said:
Thank you.
Any advices?
/cdn-cgi/mirage/ca74ccc0c958c90dcfb1f2893c53ba68e43e63c06f0ba81c9f9acb2c1959ac8e/1280/https://www.briskoda.net/forums/uploads/monthly_2023_02/Updating.thumb.jpg.4e9782b82134c709b5b49a9fec8a3a4a.jpg
I have same firmware in my car, I had to use SD Card, not USB to update firmware.
Does it has to be on official Skoda SD card or can I use any I do have?
Any card will work, brand not important
Thanks, I will test it tomorrow.
Good day friends. I would like to have a new version of my infotainment in my car Skoda Octavia III 1.6 tdi 77kw Greentec 11/2013. Thanks for help and sending the newest firmware to me🤝.
I shall send this via Private Message
MHIG_EU_SK_K1552
MU Version 0411
Hi  guys
I have a problem with my infotainment as it has run into some kind of boot loop. It's happened without any reason. Just after normal ignition on and connect Android Auto device with USB cable.
There was stock firmware no updates before etc. So obviously i don't have any firmware backup to restore. Maybe flashing the device with fresh firmware could help to repair it but i don't have any. I cannot also provide you what was installed before.
https://www.youtube.com/watch?v=9g83QmeuCJw
You are welcome with any advice how to proceed with this issue.
Thank you,
Device is:
Bolero
MiB ST2 ZR +/NAV
5Q0035840C
SW 042
HW H41
Hi all,
I have  P0480T on my MIB2 at the moment.  I updated via this very helpful thread some months back. Below is my old 475T image to aid ident.  Is this still the latest (P0480T I Mean)?
Am I correct that, even though it has WiFi and AA that Wireless AA will "never be a thing" via any FW Upgrade?
Thanks in advance
Paul
Edited by smipx
@sykora & @smipx I shall send you firmware in a few moments.
@varooomThank you for your support
Do you think that those firmware you have sent will be possible to install in emergency mode ?
My device currently does not boot at all as you may have seen on video.
Not sure what you have done yet, but in theory it has a recovery process.  It happens when the SD Card is corrupted, it ends in red emergency screen.
Till now I've just manage to connect to the device with terminal. I haven't done anything more yet as shown on video i pasted. The device is now in kind of boot loop. Keeps restarts. It crashed suddenly during normal usage. Just ignition on and connect Android Auto phone with USB cable. And it crashed
Error log on the terminal shows:
Unable to open dsp image file: /net/imx6/tsd/dsp/tsd.mibstd2.system.main.j5.dsp.bs
Full procedure of emergency recovery is described on this video. Do you think it will work with files you have sent to me ?
One again thanks for help
Sory for post one after another but i cannot edit posts.
The same procedure described in English
r
