Amundsen MIB2 Firmware Update
I've never pulled one apart like this before, I am still wondering what was reason yours was pulled apart.  So I can only assume you was trying to do something?
  • Replies 4.7k
  • Views 897k
hi.  do you also have updates to my version?  Thank you in advance.
28 minutes ago, varooom said:
Yes there's update to 0253, I will send in 15 minutes roughly
Thank you.
Believe me or not but nothing. No reason to lie. I was on a way to home and stopped for a lunch. An 1h later returned to car turned on ignition connect phone to start navi but it didn't boot correctly anymore.
In my opinion it can be connected somehow with mobile phone or something installed in the phone. Recently i installed waze navi instead of google maps i had used before.
There are some similar topics in the internet
https://support.google.com/androidauto/thread/18210685/skoda-head-unit-is-crashing-often-with-new-android-auto-while-music-playback?hl=en
https://www.vwvortex.com/threads/mib-ii-stuck-in-boot-loop.7478545/
Hi @varooom
I tried emergency update with the file you have sent to me unpacked to sd card but unfortunately it didn't helped
Do yo maybe have different firmware for this unit ? Maybe i could try with stock one ?
Thanks,
12 minutes ago, sykora said:
Hi @varooom
Thanks,
Firmware is stock, just 0480 version, you might have been running 0472 version as seen in last few seconds of your video.
But the firmware 0472 or 0480 both contain emergency recovery.
Was the files unpacked to root folder of SD Card?
Maybe @pab567you have seen these errors before?  Perhaps he needs to post off for a fix to you?
Edited by varooom
There can be several reasons:
- make sure your SD card is formatted under FAT32. (use 4096 bytes for cluster size when formatting, it helps sometimes)
- unit is NOT SOP4 (originally installed firmware was 02xx or 03xx, SOP4 firmware, i.e. 04xx, can be pushed only to SOP4 units), in such case use eith SOP2 (02xx) or SOP3 (03xx) firmware, depending what SOP the unit is
- EMMC is broken
- memory controller built in iMX6 is faulty
- EMMC is broken
Here is screengrab from his video if this helps, thanks once again for your input.
SOP4
Yes, files unpacked to root directory, sd card formatted with Fat 32. Tried tow different sd cards 32 and 64 Gb but no success
Below once again how the unit got crashed
The message was
dspstarter: Faild to open dsp image file: /net/imx6/tsd/dsp/tsd.mibstd2.system.main.j5.dsp.bs
dspstarter: Error while loading image! terminating...
And logs from update below. After screenshot
\-- -He---|<----------wP---     -----i--
--J--1----l--s---@--Ti-z~--@--"- ---@- 1-@-0-Q-@-(-$---
-x --p
Boot stopped.
Enter:
        1 - continue boot
        2 - Emergency Update
        3 - Unlock JTAG
        4 - reset Emergency Counter
        5 - disable Watchdog
        6 - enable Watchdog
        7 - enable imx6 USB and release imx6 from reset
Boot stopped.
Enter:
        1 - continue boot
        3 - Unlock JTAG
        6 - enable Watchdog
Boot stopped.
Enter:
        1 - continue boot
        3 - Unlock JTAG
        6 - enable Watchdog
Enter:
        1 - continue boot
        3 - Unlock JTAG
        6 - enable Watchdog
                        -Welcome to TechniBoot-
SVN Rev: 626459
Loading Emergency updater...
J5e.imx6.start: 0x00744813
J5e.imx6.start: 0x01D43D29
J5e.M30.LoadImage.ready: 0x03D92023
J5e.QNX.LoadImage.ready: 0x0CDB44E5
CPU0: L1 Icache: 512x64
CPU0: L1 Dcache: 512x64 WB
CPU0: L2 Dcache: 4096x64 WB
CPU0: VFP-d32 FPSID=410330c3
CPU0: NEON MVFR0=11110222 MVFR1=00011111
CPU0: 413fc082: Cortex A8 rev 2 600MHz NOALIGN
Loading IFS...decompressing...done
System page at phys:832d5000 user:fc404000 kern:fc404000
Starting next program at vfe05060c
cpu_startnext: cpu0 -> fe05060c
VFPv3: fpsid=410330c3
coproc_attach(10): replacing fe080d90 with fe08054c
coproc_attach(11): replacing fe080d90 with fe08054c
!!!Emergency!!! - Welcome to QNX Neutrino on the Texas Instruments J5 ECO MIBSTD2_MAIN (ARMv7 Cortex-A8 Core)
J5e.QNX.init.ready
Thu Jan 01 00:01:04 UTC 1970
add net default: gateway 10.200.1.2
Starting tsd.mibstd2.main.root...
00:01:04.324     [Info] [mcp]   [FREQ:20000000]
00:01:04.327     [Info] [mcp]   [PERF:0x55649e8:IO1] J5e.MCP.init.start
00:01:04.341     [Info] [mcproot]       CM is restricted
Start Com-Client (MAINROOT)
Start Com2M30
shm mapped to 28010000
Start Network
Create Thread
00:01:04.374     [Info] [cmsg.thread]   Init
00:01:04.379    [Error] [tsd.communication.serializer]  Serializer already registered for event 0x8ff0556
00:01:04.383     [Info] [m3xlogger.thread]      Init
00:01:04.391    [Error] [tsd.communication.serializer]  Serializer already registered for event 0x70a0067
00:01:04.392    [Error] [tsd.communication.serializer]  Serializer already registered for event 0x70a0068
shm mapped to 28020008
00:01:04.393     [Info] [cmsg.thread]   Start
00:01:04.396     [Info] [mcproot]       Registered to MCPClient User Event ServiceStateInfo: 335544324
00:01:04.397     [Info] [mcproot]       Registered to event: 336658434
00:01:04.398     [Info] [mcproot]       Registered to event: 336723969
00:01:04.401     [Info] [mcproot]       Current Application Watchdog Settings: (0,0,-1,-1)!
00:01:04.405     [Info] [mcp]   [PERF:0x56e4af5:IO0] J5e.MCP.init.ready
00:01:04.406     [Info] [mcproot]       Entering MCP main loop...
00:01:04.407     [Info] [mcproot]       starting service J5e.Persistence.Master autostart
00:01:04.408     [Info] [mcproot]       starting service J5e.Police autostart
00:01:04.409     [Info] [mcproot]       starting service J5e.SwDL autostart
00:01:04.412     [Info] [tsd.common.watchdog]   WatchDog mcp.mainloop, WarnTime=2500, ExpireTime= 25000 [milli seconds]).
00:01:04.413     [Info] [tsd.common.watchdog]   WatchDog mcp.mainexecute, WarnTime=2000, ExpireTime= 20000 [milli seconds]).
00:01:04.414     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:04  utpime is: 0 days 00:00:04
00:01:04.415     [Info] [tsd.common.watchdog]   WatchDog WatchDogManager, WarnTime=15000, ExpireTime= 30000 [milli seconds]).
00:01:04.418     [Info] [cmsg.thread]   IPC SWDL State: 1
00:01:04.421     [Info] [m3xlogger.thread]      Start
00:01:04.428     [Info] [mcproot]       creating process /tsd/emergency/tsd.mibstd2.persistence.master with Priority 0 and scheduling default
00:01:04.430     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaFM1.setState(): antenna switched on
00:01:04.433     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:04.434     [Info] [cmsg.m30]      persist: LastStateMode sent. p1: 0 p2: 0 p3: 0
00:01:04.437     [Info] [cmsg.m30]      persist: EEPROM write for SECURE addr (p1), length (p2). p1: a p2: 8 p3: 0
00:01:04.439     [Info] [cmsg.m30]      persist: EmergencyState sent. p1: 0 p2: 0 p3: 0
00:01:04.441    [Error] [cmsg.m30]      persist: (p1:p2) configuration failed status (p3). p1: 0 p2: 0 p3: 8
00:01:04.444     [Info] [cmsg.m30]      persist: (p1:p2) load failed status (p3). p1: 80000002 p2: a p3: 5
00:01:04.447    [Error] [cmsg.m30]      isotp: EEPROM failure maybe corrupt data (job, key, status) p1: 0 p2: a p3: 5
00:01:04.449     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaFM1.setState(): antenna switched on
00:01:04.450     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaFM2.setState(): antenna switched on
00:01:04.451     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:04.452     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:04.453     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:04.449     [Info] [mcp]   [PERF:0x57bba01:IO0] J5e.Persistence.Master.start
00:01:04.460     [Info] [diagnosis.dtc] Error memory: setBlockade = 0
00:01:04.471     [Info] [mcproot]       creating process /tsd/emergency/trustedservices/tsd.mibstd2.system.trustedservices with Priority 0 and scheduling default
00:01:04.482     [Info] [mcp]   [PERF:0x585aa87:IO0] J5e.Police.start
00:01:04.486     [Info] [mcproot]       starting service J5e.Persistence.Master because it is a dependency of J5e.SwDL
00:01:04.490     [Info] [mcproot]       starting service J5e.Police because it is a dependency of J5e.SwDL
00:01:04.495     [Info] [cmsg.m30]      watchdog: Watchdog State: Running/Active/GActive:  p1: 21a p2: 21a p3: fff
00:01:04.510     [Info] [cmsg.m30]      watchdog: Watchdog State2: System/ReceiverProbs:  p1: 44028 p2: 0 p3: 0
00:01:04.541     [Info] [cmsg.m30]      persist: (p1:p2) load failed status (p3). p1: 80000001 p2: 4 p3: 8
persistence.master: 00:01:04.611         [Info] [J5e.Persistence.Master.tsd.mibstd2.persistence.master] PersMap ready, starting from scratch after reset
persistence.master: 00:01:04.628         [Info] [J5e.Persistence.Master.tsd.mibstd2.persistence.master] connection to M3 established
persistence.master: 00:01:04.633         [Info] [J5e.Persistence.Master.mcp.client]     Found enviroment variable TSD_MCP_CLIENT_SERVICE_ID: 4
persistence.master: 00:01:04.635         [Info] [J5e.Persistence.Master.mcp.client]     Found enviroment variable TSD_MCP_CLIENT_SERVICE_ROOT: 1048576
persistence.master: 00:01:04.636         [Info] [J5e.Persistence.Master.mcp.client]     Registered to event: 336658433
00:01:04.643     [Info] [mcp]   [PERF:0x5b6c4e4:IO0] J5e.Persistence.Master.ready
persistence.master: 00:01:04.634         [Info] [J5e.Persistence.Master.tsd.common.watchdog]    WatchDog WatchDogManager, WarnTime=15000, ExpireTime= 30000 [milli seconds]).
persistence.master: 00:01:04.640         [Info] [J5e.Persistence.Master.mcp.client]     Sending alive reply event to mcp: 1
police: 00:01:04.889     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices]        initializing TheftProtectionServices
00:01:04.892     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:04  utpime is: 0 days 00:00:05
police: 00:01:04.894     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050000
police: 00:01:04.895     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050002
police: 00:01:04.896     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050004
police: 00:01:04.896     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050010
police: 00:01:04.897     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050008
police: 00:01:04.897     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050006
police: 00:01:04.898     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x705000a
police: 00:01:04.899     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x705000e
police: 00:01:04.899     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x705000c
police: 00:01:04.900     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050012
police: 00:01:04.900     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050014
police: 00:01:04.901     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices.proxy]  will handle event 0x7050016
police: 00:01:04.905     [Info] [J5e.Police.mcp.client] Found enviroment variable TSD_MCP_CLIENT_SERVICE_ID: 5
police: 00:01:04.907     [Info] [J5e.Police.mcp.client] Found enviroment variable TSD_MCP_CLIENT_SERVICE_ROOT: 1048576
police: 00:01:04.907     [Info] [J5e.Police.mcp.client] Registered to event: 336658433
police: 00:01:04.907     [Info] [J5e.Police.tsd.common.watchdog]        WatchDog WatchDogManager, WarnTime=15000, ExpireTime= 30000 [milli seconds]).
police: 00:01:04.913     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices]        authenticity check of root key was successful
police: 00:01:04.914     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices]        root key length: 256
police: 00:01:04.925     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices]        result of verify was 1
police: 00:01:04.926     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices]        reading from SPI flash was successful
police: 00:01:04.927     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices]        starting TheftProtectionServices
00:01:04.929     [Info] [mcp]   [PERF:0x60e3edc:IO0] J5e.Police.ready
00:01:04.936     [Info] [mcproot]       creating process /tsd/emergency/tsd.mibstd2.system.swdownload with Priority 0 and scheduling default
00:01:04.939     [Info] [mcp]   [PERF:0x6113bee:IO0] J5e.SwDL.start
police: 00:01:04.927     [Info] [J5e.Police.tsd.mibstd2.theftprotectionservices]        TheftProtectionServices are up and running
police: 00:01:04.928     [Info] [J5e.Police.mcp.client] Sending alive reply event to mcp: 1
00:01:05.200     [Info] [diagnosis.dtc] DTC-ID = 139: Disqualification timer expired -> error not active and qualified
00:01:05.201     [Info] [diagnosis.dtc] DTC-ID = 138: Disqualification timer expired -> error not active and qualified
00:01:05.202     [Info] [diagnosis.dtc] DTC-ID = 137: Disqualification timer expired -> error not active and qualified
00:01:05.280     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:05.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:05.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:05.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:05.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:05.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:06.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:06.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:06.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:06.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:06.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:06.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:06.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:06  utpime is: 0 days 00:00:06
00:01:07.280     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:07.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:07.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:07.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:07.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:07.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:07.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:07  utpime is: 0 days 00:00:07
00:01:07.669     [Info] [cmsg.m30]      persist: EEPROM write for SECURE addr (p1), length (p2). p1: 149 p2: 14 p3: 0
00:01:07.672     [Info] [cmsg.m30]      persist: EEPROM write for SECURE addr (p1), length (p2). p1: 9a49 p2: 14 p3: 0
00:01:07.676     [Info] [cmsg.m30]      persist: EEPROM write for SECURE addr (p1), length (p2). p1: f3c9 p2: 14 p3: 0
00:01:08.142     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaFM1.setState(): antenna switched on
00:01:08.143     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaFM2.setState(): antenna switched on
00:01:08.144     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:08.145     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:08.145     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:08.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:08.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:08.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:08.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:08.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:08.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:08.400     [Warn] [diagnosis.dtc] LVDS disconnection detected and qualified
00:01:08.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:08  utpime is: 0 days 00:00:08
ListenServer: creating new worker thread
00:01:09.225     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:09  utpime is: 0 days 00:00:09
00:01:09.239     [Info] [mcproot]       starting service J5e.Persistence.Master remote called start
00:01:09.241     [Info] [mcproot]       starting service J5e.Police remote called start
00:01:09.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:09.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:09.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:09.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:09.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:09.285     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:09.287    [Error] [cmsg.m30]      isotp: Reading data from EEPROM finished with errors, eepResult is:  p1: 101 p2: 0 p3: 0
00:01:09.289     [Info] [cmsg.m30]      persist: MotorState: normal, voltage (p1), temperature (p2), speed (p3) p1: 81 p2: 10 p3: 0
00:01:09.400     [Info] [diagnosis.dtc] DTC-ID = 1: Disqualification timer expired -> error not active and qualified
00:01:09.401     [Info] [diagnosis.dtc] DTC-ID = 0: Disqualification timer expired -> error not active and qualified
00:01:09.488     [Info] [cmsg.m30]      watchdog: Watchdog State: Running/Active/GActive:  p1: 21a p2: 21a p3: fff
00:01:09.490     [Info] [cmsg.m30]      watchdog: Watchdog State2: System/ReceiverProbs:  p1: 44020 p2: 0 p3: 0
00:01:09.591     [Info] [diagnosis.dtc] LVDS connection detected
00:01:10.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:10.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:10.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:10.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:10.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:10.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:10.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:10  utpime is: 0 days 00:00:10
00:01:11.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:11.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:11.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:11.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:11.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:11.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:11.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:11  utpime is: 0 days 00:00:11
00:01:12.228     [Warn] [mcproot]       Invalid i.MX watchdog response: 1659028 (expected 16839)
00:01:12.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:12.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:12.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:12.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:12.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:12.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:12.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:12  utpime is: 0 days 00:00:12
00:01:13.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:13.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:13.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:13.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:13.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:13.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:13.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:13  utpime is: 0 days 00:00:13
00:01:14.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:14.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:14.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:14.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:14.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:14.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:14.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:14  utpime is: 0 days 00:00:14
00:01:14.488     [Info] [cmsg.m30]      watchdog: Watchdog State: Running/Active/GActive:  p1: 21a p2: 21a p3: fff
00:01:14.489     [Info] [cmsg.m30]      watchdog: Watchdog State2: System/ReceiverProbs:  p1: 44020 p2: 0 p3: 0
00:01:14.545     [Info] [cmsg.m30]      performance:            M30 Task           |Prio|Load|Stack usage
00:01:14.547     [Info] [cmsg.m30]      performance: ------------------------------+----+----+-----------
00:01:14.548     [Info] [cmsg.m30]      performance: tsd.common.ipc.Timer          |  13|  8%|  580/32768
00:01:14.549     [Info] [cmsg.m30]      performance: Analysis_M30                  |   1|  0%|  600/ 4096
00:01:14.550     [Info] [cmsg.m30]      performance: WatchdogTaskSS                |   8|  1%| 1348/ 4096
00:01:14.551     [Info] [cmsg.m30]      performance: PersistTask                   |   9|  1%| 2096/ 8192
00:01:14.552     [Info] [cmsg.m30]      performance: DiagAppTask                   |   8|  5%|10928/24576
00:01:14.553     [Info] [cmsg.m30]      performance: ISOTPAppTask                  |   9|  4%| 1700/ 8192
00:01:14.553     [Info] [cmsg.m30]      performance: SystemTask                    |   8|  4%| 1032/ 8192
00:01:14.554     [Info] [cmsg.m30]      performance: NetworkTask                   |  11| 10%| 1200/ 8192
00:01:14.555     [Info] [cmsg.m30]      performance: SpiTask                       |   9|  1%| 1352/ 8192
00:01:14.557     [Info] [cmsg.m30]      performance: ComServerM30                  |  11|  0%| 1352/16384
00:01:14.558     [Info] [cmsg.m30]      performance: DucatiShmServer               |  12|  0%|  672/ 8192
00:01:14.559     [Info] [cmsg.m30]      performance: MailboxShmServer              |  11|  1%|  800/16384
00:01:14.562     [Info] [cmsg.m30]      performance: tsd.common.ipc.ProxyThread@One|  12|  0%|  768/32768
00:01:14.563     [Info] [cmsg.m30]      performance: hndl:0x80004FB0 fxn:0x8042C46D|  15|  0%| 1160/16384
00:01:14.564     [Info] [cmsg.m30]      performance: hndl:0x8051AB1C fxn:0x8043AD21|   0| 63%|  384/16384
00:01:14.565     [Info] [cmsg.m30]      performance: Heap usage M30: 2713232/3145728 largest free: 2709224
00:01:15.229     [Warn] [mcproot]       Invalid i.MX watchdog response: 1659028 (expected 16839)
00:01:15.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:15.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:15.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:15.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:15.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:15.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:15.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:15  utpime is: 0 days 00:00:15
00:01:16.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:16.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:16.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:16.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:16.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:16.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:16.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:16  utpime is: 0 days 00:00:16
00:01:17.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:17.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:17.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:17.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:17.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:17.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:17.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:17  utpime is: 0 days 00:00:17
00:01:18.229     [Warn] [mcproot]       Invalid i.MX watchdog response: 1659028 (expected 16839)
00:01:18.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:18.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:18.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:18.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:18.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:18.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:18.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:18  utpime is: 0 days 00:00:18
00:01:19.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:19.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:19.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:19.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:19.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:19.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:19.286     [Info] [cmsg.m30]      persist: MotorState: normal, voltage (p1), temperature (p2), speed (p3) p1: 85 p2: 10 p3: 0
00:01:19.488     [Info] [cmsg.m30]      watchdog: Watchdog State: Running/Active/GActive:  p1: 21a p2: 21a p3: fff
00:01:19.489     [Info] [cmsg.m30]      watchdog: Watchdog State2: System/ReceiverProbs:  p1: 44020 p2: 0 p3: 0
00:01:20.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:20.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:20.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:20.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:20.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:20.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:21.229     [Warn] [mcproot]       Invalid i.MX watchdog response: 1659028 (expected 16839)
00:01:21.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:21.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:21.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:21.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:21.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:21.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:22.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:22.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:22.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:22.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:22.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:22.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:23.281     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:23.282     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:23.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched on
00:01:23.283     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaDAB/Sirius.setState(): antenna switched off
00:01:23.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched on
00:01:23.284     [Info] [cmsg.m30]      hwc: tsd.carcom.hwcontrol: AntennaGPS.setState(): antenna switched off
00:01:23.411     [Info] [mcproot]       Current UTC is: 1.1.1970 at: 00:01:23  utpime is: 0 days 00:00:23
Can you show screenshot of SD Card files and folders.
From what I can see you are doing it correctly, quadlock out, USB communication thing plugged in, and RX is connected to TX to enable two way Comms.
Then you short out the two pads on motherboard and push in quadlock, and in the terminal screen you select 2 for emergency recovery.  Then remove quadlock.
With SD Card in slot one only, you then insert quadlock and see the red EM screen, that then fails with above screenshot?
I have only one SD slot so no way to make mistake.
Everything else correct, exactly as you described.
Week ago when those crash happened i was almost sure it's a software problem. But now I'm closer to that it is a hardware failure and i will need new device.
SD card content:
SD card content:
/cdn-cgi/mirage/ca74ccc0c958c90dcfb1f2893c53ba68e43e63c06f0ba81c9f9acb2c1959ac8e/1280/https://www.briskoda.net/forums/uploads/monthly_2023_02/image.thumb.png.71e67245ee730c0898ac6d190159bca2.png
I was also beginning to think it's a hardware fault also seeing as you was able to get recovery emergency mode started.
First of all thank you for your support
Secondly I would be grateful if you could still answer few questions
1.  Is there anything else i can check with this hardware or I should look for new unit. I'm lack of further ideas what else can I do with current one
2. Is there anything interesting in logs that suggests the hardware is dead from point of view ? I see some errors but I don't know how serious they are.
3. If I bought another second had unit (new one will be quite expensive i guess) is it a big challenge to adopt it to the car and restore all functionalities of broken one ? I mean privately without passing it do dealer to do it.
BTW: The car is still quite fresh in my opinion (2018 and currently millage around 83kkm) and infotainment is one of the last think that I would expect to break. But.. strange things happens.
However I think dealer will refuse to fix it within guarantee. I removed guarantee label anyway.
Regards,
Edited by sykora
Regards,
I will answer the best I can, I don't deal with the hardware side, just provide firmware updates.
1. As far as I can tell, you have done everything possible to load files from emergency recovery.
2. The fact that it cannot perform recovery, tells me it's a big fault with HW.
3. Dealer price is insane, even with 50% "goodwill" contribution (if lucky!). 2nd hand parts, will have CP, Component Protection, which has to be lifted to code into your car.  If the part is stolen, then it will be refused and you might loose the money.  Best choice is a breaker yard if you take removal keys to find the same 04xx firmware that was on yours.  Then you still might have issues coding at a main dealer, outright refusal.  An independent garage could be more forthcoming if they have ODIS online connection.
EDIT: @pab567Would probably be able to send you a system to plug and go maybe as he can work magic with tools no doubt.
Edited by varooom
Hello! I have  a H30 MIB2 with MST2_EU_SK_ZR_P0367T. !
Can i please have the update
MST2_EU_SK_ZR_P0369T ?
I'm thinking about second hand but legal of course. I mean rather internet auctions. On popular auction services there is easy to get refund in case of problems and seller of illegal parts will be blocked quickly.
I'm rather asking about requirements i should full fill.
1. I understand that has to be 04xx firmware. Or different possibilities ?
2. Have to come from Octavia or can be also Fabia, Superb etc.
3. Can also come from VW, Seat or have to be from Skoda ?
4. Does the OE number matters ? In my case it is 5Q0035840C. Are different numbers possible ?
5, Do you think it is worth to consider more powerful device. My one is called Bolero. In higher models Amundsen or Columbus were installed but i don't know the differences between them. Build in navi is not important for me. Android Auto is good enough for me.
6. What do you mean by "removal keys" those physical one to remove unit ?
7. Is this ODIS online connection relay required to adopt it to the car ?
I'm Sorry for this dozens questions.
Edited by sykora
@sykora I will await the reply to earlier from Pab567, as he deals with the hardware side.  I just help him by sending firmwares, so keeping him free for his work time.
I can anwer some of the above, just prefer to wait on his sage advice.
1. yes, stay with 0480.
2. any
3. well, it can be any but you will not have Skoda HMI
4. possible
5. the question is on your budget and must have features
6. yes
7. to make it official - yes, however the unit can be patched and then ODIS is not required
i need the link plz
2 hours ago, sayedfarhani said:
i need the link plz
That's not enough information.
What is your software train value, hold down Menu/Setup button for about 10 seconds to enter engineering menu and locate.
2. any
4. possible
6. yes
Hi @pab567Thank you for response
    3, I see
    5. Let's say main requirements is to stay with current screen. I would like to avoid replacing it. Are there any other OE numbers that will work with this screen ?
    7. No idea how much dealer will wish for this adaptation. But anyway do you have any step by step tutorials how to adopt such device to the car ?
Hello, now have SW MST2_EU_SK_ZR_P0361T, as far as I understand, the update is officially only for MST2_EU_SK_ZR_P0369T. I would be interested in the possibility of updating to MST2_EU_SK_ZR_P0478T
Does anyone have any advice or instructions on how to do this? Škoda Octavia 3 FL 2017.  Thanks
