Amundsen MIB2 Firmware Update
Hello dear Skoda enthusiasts,
may I please ask you to take a look at my Amundsen version and eventually provide me an update?
Thank you very much in advance!
  • Replies 4.7k
  • Views 900.4k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
@alibetI can send 0480 update
@vintage-thI can send 0369 update
14 minutes ago, fuzzyduck said:
According to:
Latest official firmware: MST2_EU_SK_ZR_P0253T (MU: 0253, details).
Latest possible firmware: MST2_EU_SK_ZR_P0480T (MU: 0480, details).
It this true? And any benefits to update to 480T.
It's both true, and dangerous also.
Officially if you have 01xx firmware, 02xx, 03xx or 04xx then you should stick in that series.
You can update to new versions, but can also brick unit.  Personally I don't recommend it.  You cannot just load 0480 easily either, there's a process to it.  Someone might explain it, but I won't.
Hi, is it possible to load MIB 2.5 on MIB 2? Or does the unit need to be replaced? 5Q0035864C.  Thank you. 😊
@pab567 Seems more like a hardware question, over to you please 🤝
The question is what do you mean by MIB2 and MIB2.5. My definition of MIB2.5 - Columbus 5650350xx units, with 9.2" display (touch buttons, no knobs). Yours in MIB2 Amundsen so you will need to chnage both glove box and display units.
I see. Thanks. I guess I understand now. I have an Amundsen, so it would have to be changed to a Columbus and then possibly an update... I currently have a unit in my car: 5Q0035864C
@YENDYS - What are you actually trying to do or enable.
For a reference, plenty of folk call the Amundsen fitted from around MY18 with software 04xx a MIB2.5.
Rear camera and parking sensors, the background around the sensors is no longer dark and is clear.  When the seat heating is turned on with the button, the level of steering wheel heating can be changed on the screen, this was not possible before.  Colorful menu icons.  Loading picture albums and their previews works better... I guess.  I don't have the experience right now, as I don't have the 2.5 in the car :) so there are certainly other things that are not immediately visible.
Well yes. I have the last 480. Thanks to you here..
On 13/02/2023 at 09:50, pab567 said:
Hi
found you here also 😁
But I have ''Bolero 5Q0035840c '' and you said need some soldering job to be patched
Hi everyone! I have the issue that Android Auto occasionally only functions after a Soft-reboot of the HeadUnit (Pressing the Power Button till the Skoda Logo appears). I have tried several cables, but nothing seems to work.
Might this be fixed by a software update?
Could someone please provide me the most recent version?
My Current Version is: MST2_EU_SK_ZR_P0472T
Part-Number: 5Q0035864C
Software-Version: H29.319.51_STD2Nav_EU
@Scaleo You have PM for 0480 version, you will have to try and see if it works for you.
Picked up a 2019 Octavia Estate at the weekend. From a brief read, it looks like I can update to 480 (not sure what extra that gives me?).
Thanks in advance
David
Thanks in advance
David
You have a PM, and it's bug fixes... and VAG do not provide a changelog of those either.
Hi everyone,
Does anyone have MST2_EU_SK_ZR_p0253T firmware? I have unit with P0245T and I want to update to latest version. I googled it and found out that 253 is the latest version. Anyone has this firmware? Thanks in advance.
1 hour ago, YH7888 said:
Hi everyone,
I can send you a link by PM
I would appreciated it, thanks
Can you send to me also
You have 0480 version, so you won't want to load 0253!
Hello any updates for this head unit? and what is its name
5Q0035840C
hardware h41
software 0472
medie codec 4101. 0.0.0
5Q0035840C
hardware h41
software 0472
Yes to 0480 version
Hello everyone, does anyone happen to have an update for this?
I will send you 0480 version
