Amundsen MIB2 Firmware Update
7 minutes ago, Pantersen said:
Hi there,
Any update for my beauty here? Thanks a lot in advance and cheers :)
Device: 5Q0035864A
HW version: H24
SW version: 0245
Nav: 5L0051236H
f0HUhEpOvpcg-XU8yTe89qXUhn-P9VqbzjO-Ka9Lg24hvNbcx_C2UKkpQCTwxoDxC_DY5rj8ZCCM2yrt0857qmSwZTpJFVW_-ZepzCQhvZyRIIiFrJR9G6bWmuhhI_bkkgHk5GdvXGw8iT97DZCoOM3WHWZ_LcgUJzfGK3otJB-O-H3zHw2-5K1hYi9slagechgi6r8Wf-DDriZbQbAmqlP0XasZF_b5m7iBKwM0fUVSbesRBVCwCUfNw3l34JMSZrYVXPrSnaI_auEkXyTGCp_UDtCyT1VtHt4CRzmaQBzs5XUU2mRwpUgYR0-DSym-sowp2GkCzt3zLSncsldjuiBRr-dGMS4a5rhcoIDbg5xLtK5oV8npF45bNiAYWkOFmpA1fBtGWnFAYPUhuGqHTcM0yzjFez7UJGg0aXoE1xWGXtjPme3PGjf4Ld0RjZjFB601lhneFGeeKlcvmgZxMHYYoxzOxcarw_addeY1FJjl0GkDWfrDwIkZucVvUafPELVGUrXuUTfXWP1k-n7zrSCctkNLc37yklhYq9y1RD9437zl1jEonL5BNJlo0ejGBmg7fvMAxInsvO9RHifuyEo3tchhApOT5IbBjzZrIRlAXf0HNWDF2OW7MZ2l1ezEOYguLwEA1c5kE-rrHg42I7X7sy4zrrzb-dUz9T5FBBxR1flSaWWxYxuJ1qqCetjePCX2r916IH4qaZ9hQ4mPD-Yray2k5Xi0tVy09K7ignEC-r-AWBxECSzmFZaB7UyqDnRhiJ1U8JGpRAoIpFhkhBoHZpHAZyUgNVTRDLkEHF1ICNGXABiRLMEV9gUHZFJX39X3g3AHWatil9Vy4zxfROa0dFTurX9mo7dU2-4EKlUaQgZcuUuBOSmxL6Sr6cRK-JIEoqDf_M-3KI2am8nuYOHq4eJzMz6j6BiKgHJdjbbvG31itfuyAlcFZNIhghZjBNumnDMi1KZFI5dctvPD=w1257-h707-s-no?authuser=0
Odds are high on getting update to 0253 version, press and hold down your Menu/Setup button for about 10 seconds to enter the engineering menu, then you can see Software Train
  • Replies 4.6k
  • Views 774k
On 28/03/2023 at 17:29, Pipe84 said:
Hi again.
The 480 version is the last version?
Is there version major?
The android auto fail sometine yet.
Thanks.
I think the new update to android auto has messed up a lot...mines now not working just showing me the phone that is available
Yes, I can see a menu with two options, one of which is "Software update/versions"  and there under "Update" I have an option to select a source "SD card". Is that we should be looking for or you need any other version number - there are so many in this menu :)
MST2_EU_SK_ZR_P02xxT
Is this what your SW Train reads like, or with PQ in that location?
It's ZR, I believe.
3 hours ago, Pantersen said:
It's ZR, I believe.
Very good, I will send you update now.
This is also the screen you need to use for updating.
Update went on like a charm for about 15-20 minutes. Only thing which worries me is that I started getting this error via VCDS.
This will be because the car was not able to talk to the factory to verify the update (you may remember the screen asking for diagnostic connection test)
It's a stored "non" fault, it doesn't affect operation.
Hello, could someone please send me updated firmware for my 2018 Octavia?
MST2_EU_SK_ZR_P0472T
0472
5Q0035874C
Android Auto keeps disconnecting.
Thanks!
After the firmware update i have the following erori on obdeleven, yet the navigation seems to work ok. Is there any conflict with the New firmware?
On 24/03/2023 at 01:27, Madalin said:
Evening any update for this version?
If yes where to download the update?
The 2nd fault code is the very common one that occurs when you do not have online connection to factory.
Easily fixed, https://forums.ross-tech.com/index.php?threads/18798/
The 1st fault code might sadly need you to go online to make a possible new coding of the unit (though so far no one has complained of loosing function!)
So you maybe wise to test all things on the system to check out each function is intact, and maybe no physical errors are seen, so you can then ignore the coding change.
Hello everyone,
I'm having multiple issues with my unit (not) connecting to the iPhone at all, or apps freezing. I suppose my software version is quite old.
Where can I get a firmware update? What is the latest firmware version?
Hardware H30
Firmware 0363
Hi there,
Can anyone send me the update for my 2017 Superb?
Hello,
Please, is there a newer FW in this SW Train? I heard some rumor about 0481 :)
thanks, Dan.
36 minutes ago, DanielMikel said:
Hello,
thanks, Dan.
News to me... only seen 0480 so far.
@krisopl @omide Sorry I missed your posts, did you still need firmware updates?
Yes, thank you
Hello, I have a Skoda Yeti with a Amundsen
Software Train is MST2EU_SK_PQ_P0245T Part 5L0035680C Hardware H22
I updated to  253T (got the link from this Thread).
After some Weeks i got problems with the Touchscreen, maybe its Hardware fault.
But i would try to go back to old Firmware 245T
can someone provide me a download link?
41 minutes ago, omide said:
Yes, thank you
I will send you PM
I do not have 0245 version, only 0252
@pab567 Do you have any older version saved MST2_EU_SK_PQ_P0245T?
Hardware errors are typical for touch issues in MIB STD2 PQ units. Pls write me PM and I will check in th evening  if I have older firmware - just keep in mind it's definitely not recommended to downgrade firmware. Moreover, it can be done via Manual SWDL only which requires developer mode to be activated first.
Hi I have 5q0035874c h41 0472 what is latest update and is there any problems with updating?
Hello guys. just bought a 2020/11 kodiak. next week i go to official service for checks. as i saw there is an update for my vin number (navigation 2022/45). problem is that i don't have any sd slots in the unit in glove box compartment...? i have unit with knobs so probably it is amudsen. i have 3V0035820B, H22 and 0270 software unit if that helps what i have. i am not planning to update here (i dont even know how :). are these firmware updates just thing for home hacks or guys in the service shop also do that during check?
just to know, is there an update for my unit?
thanks.
