Amundsen MIB2 Firmware Update
I read that BOSE may not work after the update and it must be parameterized using VCP or ODIS. What is the truth?
  • Replies 4.7k
  • Views 898.8k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
I don't think the VAG would release an update that could break their own radios, could be wrong.
I can send the file and you can do more research to see if you need to muck about with parameter files.
I would like to ask you to send an update. Thank you.
I already did this, look top right for private message system
Salve, c'è
qualche aggiornamento per questa unità? Grazie in anticipo .
30 minutes ago, marco-1968 said:
Salve, c'è
Update sent via PM
Hi!
I've recently got a Karoq, 2018 model and I was wondering if there's an update for the infotainment system.
Installed SW train version: MST2_EU_SK_ZR_P0472T
Installed SW MU version: 0472
Part number: 5Q0035874C
Software version: H29.319.51_STD2Nav_EU
Hardware: H41
Software: 0472
Navigation database: 5L0051236AH  1030  ECE1 2018/19
SHIELD: SHIELD 2016-44 (build 309) 4104.0.0.0
Bluetooth version: C300
SmartLink: 4101.438.1.5
Radio database version: 1.9.4
USB surfstick version: 4101.438.1.4
Thanks!
41 minutes ago, MrSecretPotato said:
Hi!
Hardware: H41
Software: 0472
Thanks!
I will send you link to download 0480 version.
Even if you don't use, you can update maps here... https://www.briskoda.net/forums/topic/512842-amundsen-mib2-map-updates-2024/
That way you have a backup to Google maps/Waze etc
On 04/05/2023 at 10:38, varooom said:
They are OK AFAIK.
But the site is slow like ancient dialup Internet.
I successfully upgraded from 472 to 480 without any troubles ! Installed mib2toolbox and have patched the CID Lock. Now I'm able to use any SD Card for the navigation system !
Hi,
Is there any update available for this?
Also - I'm planning to see if I can unlock Android Auto - any one with any advice would be appreciated :)
Thank you! :D
1 hour ago, theandywaite said:
Hi,
Thank you! :D
There is update to 0253 version
As for unlocking features, you have 2x choices, one you can contact a dealer or independant and get a code to unlock (kerrching)
Or you can get the radio modified via a "toolkit" which is best discussed in PM.
Dear @varooom,
I have the following system. Is there a software update available? I would very much appreciate if you could help me.
Regards
2 hours ago, petercheco said:
Dear @varooom,
Regards
I can send you update to 8755 version
Dear @varooom,
Could you please help me with FW upgrade?
I have the following system, see picture bellow.
Spoiler
Regards
Tomas
1 hour ago, TomasF said:
Dear @varooom,
  Hide contents
Regards
Tomas
I can send you link to 0480
@varooom
Could I impose upon you for help with a firmware upgrade please?
Image attached with current version.
Thanks in advance.
40 minutes ago, Figment said:
@varooom
Thanks in advance.
Sure, will send you a link now, that is correct page for update too.
can you send me this update MST2_EU_SK_ZR_P0253T
I can yes, Private Message on the way
Hi @varooom Could you pls send me link too :)
Since there are many firmwares, you will need to provide me a Software Train
Hold down the Menu/Setup button and look for this screen.
You required ''MST2_EU_SK_ZR_P0363T'' information isn't it ? :)
Updated version looks this
Correct, I will now send you update to 0369 version.
Thanks u very much 👌
Hi, I've just got my Octavia and it looks like I might need a firmware update too if you can help?
Also, would I be able to install the mic-std2 toolbox on this unit?
