Amundsen MIB2 Firmware Update
PM
  • Replies 4.6k
  • Views 780.4k
I have this attached, is there update available for me as well?
Mk3 2017 Octavia
Thanks guys!
I'll be dang but I found it :) next step after installing I want to find ODB11 to enable GEM and try to activate smartlink, not workng now.
I have found the following for my system using mib-helper.com (Software Train:MST2_EU_SK_ZR_P0369T) and I have hardware H30. Would there be any advantages to installing the P0480T firmware, and could it cause any problems as it is not the official firmware?
Many Thanks
John
Firmware version: P0369T (MU: 0369)
Firmware type: Production
Hardware vendor: Technisat/Preh
2. Latest available firmware updates:
Latest official firmware update: MST2_EU_SK_ZR_P0369T (MU: 0369, details).
Latest possible firmware update: MST2_EU_SK_ZR_P0480T (MU: 0480, details).
Hey @pab567. Is it possible to get update for my infotainment system ? Ty kindly
Edited by Lexyy
Weird pic format
It will not work for you as you have unit without navigation (Bolero).
Many Thanks
John
The question is if you have unit with built-in OEM sat nav (Amundsen) or without (Bolero) - this can be done in both but in Bolero it requires unit to be open, soldered and some files modified in EMMC.
PM
Hey @pab567 Could you tell me what is available for this please . I need to do the touch screen repair as well !
Edited by UKMILK
image not showing
PM
Thank you, will report back when updated
I am trying to download the following firmware: MST2_EU_SK_ZR_P0480T
but https://mibsolution.one/ seems to be down.. could a friendly soul send it to me? 🙏
I tried too and I could not download. I need version MST2_EU_SK_ZR_P0480T too. Any help please?
Hi @pab567 and/or @varooom,
After my Octavia, I just bought a Kodiaq from 2020. Would you be so kind to PM me the latest for MST2_EU_SK_ZR_P0478T. Is that still the 480 or is there something more recent?
Unfortunately mibsolution is down, so I hope you can help me.
Super thanks in advance!
PvD
All check your PMs
Hi All,
Is there a newer version for the radio below:
Device: 5Q0035874B
Hardware: H30
Software: 0359
Thanks in advance!
Hello everyone,
MIB Helper is down and im looking for update MST2_EU_SK_ZR_P0480T. Could anyone send it across?
Thanks in advance!
Hi everyone,
Can anyone (maybe @pab567, who seems to be a gem on these forums) help me out with my infotainment screen on my 2014 5E Octavia?
I recently bought one used and just registered on these forums, too. I'd love to firstly see if there is an update available (if so, what changes would it make to apply the update) and secondly, what would be the cheapest option to go for Apple Carplay? I wouldn't be using CD/DVD streaming, DAB, NAV or any other feature. Just Carplay and native Skoda "CAR" section and settings.
Please see the photos attached. I tried to insert them in the post, but won't work - maybe because I signed up here only today. Thanks a lot!
IMG_4791.HEIC
IMG_4793.HEIC
IMG_4800.HEIC
EDIT: In case you don't want to open the photos for some reason:
Device part number: 5E0035819A
Hardware: 040
Software: 0409
Media codec: N/A
Installed SW Train Version: MSTD_EU_SK_P6230
Installed SW MU Version: 0490
Software version: 15.12.19_H15.10.139_STD_EU
Edited by Giorgi
So now you have Bolero MIB1, with Bluetooth, without DAB, part number 5E0035819A and fortunately you don't have CANTON sound system (as your Bolero has no MOST).
You can install one of four different OEM glove box units:
- MIB2 Bolero
- MIB2 Amundsen
- MIB2 Columbus
- MIB2.5 Columbus
You also need to replace display unit:
- for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N
- for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M
- for MIB2.5 Columbus the only display unit that works is 5E0919606D
If you woulkd like to use Apple CarPlay then you also have to replace USB port (if you have Media In interface instead of USB then it must be replaced with USB anyway).
The question is what is your budget and which of listed below features are "must have":
- Video playback from DVD, USB, SD
- CD playback
- OEM navigation
- displaying OEM maps in Virtual Cluster (Active Info Display).
All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them:
- MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB
- MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
- MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster)
- MIB2.5 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
@pab567, thank you so much for the swift reply!
To reflect on the query regarding the must haves, I do not need video playback, CD playback, OEM navigation, or OEM maps either, as I do not have the virtual cockpit. The cheapest way to obtain Carplay would be the way to go on this one.
As I understand, to get Carplay, I would need: A screen, the glovebox unit and a USB port. I've read somewhere that also CP removal is required. Could you please tell me more about that? Will someone with an OBD11 be able to do it, or will I have to go to a dealer?
Also, I wouldn't mind having Mirrorlink instead of Carplay either, as I think that would also allow me to display Google Maps. Would you say that'd be a cheaper route than going with Carplay?
EDIT: I think I figured through the MIB website that there is no firmware update for my current setup?
Edited by Giorgi
New unit must be patched (hacked) to have new features activated.
MirrorLink is already dead and it worked ONLY with very few Android based phoYes, you already have the latest version MSTD_EU_SK_P6230 (0490)
Edited by pab567
Hello, is it possible to update software in my car?
Superb mk3 2018
Device number: 5Q0035864C
Hardware: H41
Software: 0472
On 11.11.2024 at 23:10, d00mo said:
Aşağıdaki aygıt yazılımını indirmeye çalışıyorum: MST2_EU_SK_ZR_P0480T
ama  https://mibsolution.one/  kapalı görünüyor.. dost canlısı biri bana gönderebilir mi?  🙏
https://sendgb.com/2pGH3lnboT1
can someone help me install toolbox on a unit with a single sd card?
code: 840A
software version: 253T
On 2023. 06. 15. at 17:15, varooom said:
A MIB megoldás rettenetesen lassú, mint a betárcsázós internetes napok.
Jobb, ha megvárod, amíg valaki a fájl birtokában elküldi.
Ha nem, használja a „Free Download Manager” szolgáltatást több adatfolyam megnyitásához a webhelyükön.
Honnan lehet letolteni a fájt mert nem tudok a mib be belepni
On 2023. 06. 17. at 18:04, varooom said:
Igen, privát üzenet, már úton van hozzád.
Honnan tudom letolteni nekem is elkuldod letszives
Recently Browsing 1
