Amundsen MIB2 Firmware Update
Hi @pab567 im looking for firmware update for my newly purchased used VW Passat , the software details are as below
Installed SW train Version: MST2_EU_VW_PQ_PO4497
Installed SW MU Version : 0449
Part No: 5k7035200L
SW version: H29.204.28.1_STD2plusPQ_EU
I would appreciate your help, All i want is to use carplay but my android phone says that since this is the old version of Android auto it will not connect. Appreciate your help on this!!!!!
  • Replies 4.7k
  • Views 900k
I sent you link to MST2_EU_VW_PQ_P0480T in PM
Installed SW train Version: MST2_EU_SK_ZR_P0478T
Installed SW MU Version : 0478
Part No: 5Q0035840C
SW version: H29.319.93_STD2Plus_EU
Can I have an updated firmware?
Thanks in advance
Hello,
Can I update the software of my media.
Thanks in advance!
@pab567
Good day, are there any firmware updates for mine? I did the maps update myself after this photo was taken.
Check your PMs for download link
Hello @pab567 and all users , I hope you have a great day. I would really appreciate if you or someone else can send me too the update for Skoda MST2_EU_SK_ZR_P0480T. Thank you in advance! :)
Hi @pab567 , can you send me a file for this version?
Or did you need more or other data/details?
Skoda Yeti Year 2015
This Amundsen from my mothers Yeti has current the time error, is it possible to fix that with newer software Version?
I'm afraid this will not work, it requires update to SW 04xx but unfortunately there is no such software for SKODA so the procedure is much more complicated:
  1. load MIB STD2 Toolbox
  2. patch swdownload with MIB STD2 Toolbox
  3. load VW firmware MST2_EU_VW_PQ_P0480T
  4. load modified SKODA HMI from firmware MST2_EU_SK_ZR_P0480T
  5. apply patch with MIB STD2 Toolbox to enable features controlled with FEC/SWaP codes
18 minutes ago, pab567 said:
  1. load VW firmware MST2_EU_VW_PQ_P0480T
  2. load modified SKODA HMI from firmware MST2_EU_SK_ZR_P0480T
Okay, can you send me links for this both software files?
Or did you have more detailed Informations for the how to?
B rgds
Edited by C@MP3R
Send in PM
24 minutes ago, pab567 said:
Send in PM
Thank you, I'll take a look at how to proceed.
On 23/05/2025 at 02:32, pab567 said:
No, this is xml file that parametrizes different features. You can NOT load it with VCDS
Thanks @pab567 . Upgraded to 0480 with your file, thanks!
Notes after upgrade:
  • No dataset patch needed for external amp
  • No DTC 1555 / B201A error
Great!
Hi all,
My Škoda Superb 2017, started having “Emergency call restricted, visit Workshop” pop up. SOS light is always green and calls through to emergency without issue.
There doesn’t seem to be any apparent fault yet this warning comes up on every start.
Hoping a firmware update will fix it, I am on MHI2_ER_SKG13_P4514.
Are there any updates?
Hi @pab567,
If you have date firmware for me let me know, and do I also need to update RadioStationDataBase?
If there are more updates to check or to do let me know.
Thanks a lot
Hi folks, wondering if there is an update for my rig.
Thanks for any info.
Good morning, are there any firmware updates for mine?
if possible, could you please provide me the link (instructions) for my Skoda Octavia III from 2018?
Current system version is shown in the picture.
Thank you!
Hello @pab567
I saw in the thread above you are helping with firmware upgrades. Could you please help me with
I want to upgrade MST2_EU_SK_ZR_P0471T to latest firmware
Could you please send me MST2_EU_SK_ZR_P0480T
@pab567
Hey Pab, sorry to bother but would you have an update file for my headunit at all? The details hould be in the photos down below and any help would be appreciated
No, you are already on the most recent firmware.
All others check your PMs.
The recommended way to make the firmware upgrade:
1. format SD (best max 32GB) under FAT32
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
Hello,
I have this navigation with the sw displayed on it, can i update it to a recent one?
@pab567 can you help me please with my above navigation? Thanks!
