Amundsen MIB2 Firmware Update
Hello Pab567, good evening to all.
First, sorry for my english.
Is there any update for my device? :
MST2_EU_SK_ZR_P0359T
ref 5Q0035864B
SW version : H28.28.133_STD2Nav_EU
Thank you for your help and availability. You are always here to answer.
Thanks !
ref 5Q0035864B
Thanks !
And Please, Anyone have a tutorial explaining the firmware update? Thanks in advance.
Good evening, I packed the file and downloaded it to a USB stick. Then I put it in the car radio and it also indicates that there is an update on the stick. But when I want to apply it via the menu, it always shows an error that he can't find any of it. Do you have to install the update via SD card?
Hello @pab567 this is my mistake. Can you help me please?
I packed the file and copied it to SD card and USB stick. It doesn't work for both.
Hello all, my first post on forum.
Question about mib2 update, does it fix that 'autodimm 10 seconds' feature which allways needs to be reset after startup. Thats pretty much only fix that Im looking for.
And other thing, thank you all for the quality of conversations. Real pleasure to read 👍👍
Guy who knows @pab567
@pab567
Shure, I assume you know that function that Im referring to. If I select that automatic dimming (or is it screen off) after 10 seconds. It will work perfectly until I poweroff the radio. Setting resets to default (unselected) in every power on.
ref 5Q0035864B
Thanks !
On 09/02/2022 at 23:16, seanbrady49 said:
Hi @pab567
MIB 2 ADMUNSDEN
device 5q0035874a
hw H24
SW 0252
Is there an update for me? and will it wipe any adjustments made via OBD eleven/
TIA
Hi @pab567would is there an update for the device above?
