DSG arrow
Hello,
I anticipate this question has never been asked because I'm a bit of a newbie to cars etc and people probably already know the answer.
At the risk of making myself look stupid....
But can somebody tell me what does the downward pointing arrow mean on my DSG gear lever below "drive" (see below picture) And what does it do? I'm scared to try it out without knowing 😬
As I say, I'm new, so apologies if that's a eye roller of a question!
Cheers,
Pulling the lever down swaps between normal and sport modes. Moving it to the left allows manual gear changing.
 Ahh brill. Thanks!!
I knew about the knocking to the left allowing manual mode.
But didn't know about the sport being accessible from down!
Cheers for your reply!
...and once you done that, perversely you need to pull it back to change back to 'normal'!
Thanks for your reply!
It all makes sense now!!
If you don't know it is not a stupid question :thumbup:
I work in a pretty technical job where I train people on unique equipment. The rule is theres no stupid questions, and if you have to ask you're probably not on your own! It isn't self explanatory to be fair!
  • 6 years later...
I have driven two varieties of this lever arrangement;
  • pull to alternate between drive and sport. Lever returns to D/S position
  • two positions D and S. Lever stays in selected position
My current DSG has (I think) four modes: Economy, Drive, Sport and User defined which offers steering and A/C settings too 🤪
The Lever can only select between two of these, the others need an advanced degree in menu navigation.
I use mine to switch between slightly annoying burble mode, and a mildly terrifying growl. 😬
Those are not DSG modes they are vehicle modes, which is why they include settings for steering weight, AC mode, etc.
The DSG only has Eco (earlier shift points and coasting on trailing throttle), Drive ("normal") and Sport (later shift points).
Edited by PetrolDave
Although you can only change between D and S (and manual, of course), as the coasting and such is part of the Eco setting for the whole car.
I drive long journeys in eco sometimes, although my car has the coasting mapped out.
I stopped using Eco mode as the lack of engine braking when coasting meant I was using the brakes more - it made no measurable difference to mpg but used more brakes, so it seems to me like Eco mode will increase running costs without decreasing emissions?
I've done the same. With the engine braking effect I feel more in control.
