My Tesla Model 3 - so far
35 minutes ago, john999boy said:
It's just as easy to get 3ph to a new build as single phase. Future proofing.......:thumbup:
SPEN are famously difficult about these things though
  • Replies 65
  • Views 10k
  • So an update on the Tesla Model 3 Standard Range plus experience. Several software updates later they have fixed some niggles, broken a few things along the way and then fixed the things they broke. T
  • @ColinD  do you think it would wind up Tesla fanboys if I put a Briskoda stiker on the model 3?   :-)
  • tesla make clear that the cruise and autopilot are only to be used on motorway or dual carriageway so no way it should be in use on the roads Bjorn video shows :-)   Mine did it again on the
i had a brisky sticker on the back window of my Insignia ;)
not quite the same as a tesla in terms of fanbois but still, may have confused a few people :D
15 hours ago, domhnall said:
do you think it would wind up Tesla fanboys if I put a Briskoda sticker on the model 3?   :-)
They've been spotted on an Aston Martin and a Peugeot Seadrive previously and they're an even more exclusive club! :thumbup:
On 04/09/2020 at 12:43, domhnall said:
they tend to all be the same but the power will be determined by your supply, 7 kW for single phase 22 for three phase. Other than the zoe though no other cars can currently draw 22. The Tesla can do 11, leaf 6.
The advantage of the 22Kw three phase supply might show if you have one of the EV friendly energy tariffs which give ultra low cost per Kw/h from about 1am-5am.  I think a few of the coming EV's can do 11KW also.  So whilst you might not benefit from the full 22KW you might benefit from the extra few KW at the cheaper rate.  Then of course there's the powerwall option and buying power cheap and selling back to the grid when it's dear, plus powering your home on the cheap stuff pulled in overnight.
So to me if the differential cost to install 3 phase to the property is negligible it could give you better options longer term
On 04/09/2020 at 12:42, domhnall said:
no, you can't do anything like that, this is the coolant for the battery, so normally a sealed system that should not need to be topped up.
I'd keep hold of any correspondence about that particular delivery defect with the coolant level.  I believe Tesla have recently reduced the warranty on their battery packs, but having the "Well you damaged it early in it's life by not putting coolant in it" argument might prove useful if you start to lose range just outside the warranty period.
Plus it makes you wonder how many others Tesla has shipped with insufficient coolant that people have either a) never noticed because it had slightly more than yours so not making the same amount of noise, or b) they've never had an EV before and thought that the noise was normal for an EV.
If you really want to wind them up how about adding another small modification to it. https://www.chevrolet.com/performance-parts/crate-engines/lt/lt4-wet-sump
650hp 6.2Litre small block V8, stuffed into a Tesla should have Fanboi Fatwa's :bandit: issued against you. :@
it's not been an issue for me as 1) this Summer hasn't been hot enough to make the battery too hot 2) I haven't been using the Tesla superchargers so again the battery's not got hot 3) only long trip was over to Northern Ireland and their infrastructure is so die I was only charging at 11 kW so again heat not an issue.
Yea, but you don't need to tell them that. ;)
All that matters is that due to a QC issue in manufacturing your vehicle was delivered with insufficient battery coolant, and they have a record of that, and of having to do an "urgent" repair on it.  So if you have any battery problems bring it up, like most companies they will try to avoid doing free repairs unless you have them over a barrel.
Apologies to @domhnall for this ever so slightly OT post but I was visiting the council tip recycling centre at the weekend and a Tesla pulled up nearby.
Two people got out of the car and I had a double look as I thought the lad had got a familiar face. It didn't click until after I'd left but it is this guy who (amongst other things) happens to vlog about Teslas and actually lives in the same town - something which I wasn't aware of!
Edited by john999boy
Grammar
Trust me, I'm a lawyer, it's all on record ;-)
Two people got out of the car and I had a double look as I thought the lad had got a familiar face. It didn't click until after I'd left but it is this guy who (amongst other things) happens to vlog about Teslas and lives actually in the same town - something which I wasn't aware of!
from memory he's paying for the tesla with his youtube earnings or something like that. Nice work if you can get it
One update on the Tesla with a couple of things I hadn't realised / forgot to mention. There is no spare tyre and the puncture repair kit is an £80 optional extra. Breakdown cover only covers you if you are within 50 miles of a tesla service centre so it is recommended that you also pay for your own breakdown cover. Neither is major but when you're paying a minimum of £40k for a car it just feels a bit....cheap.
Edited by domhnall
I was looking at one today and it had Michelin Pilot Sport 4S tyres (which I am led to believe are quite good) - does yours?
just had to go check, yes it does. Only driven 2800 miles so far though. Wwas tempted to fit cross climates but honestly don't know how long I will keep this once the Enyaq is out
  • 2 months later...
i like your honesty about it.
it is very easy to only report on how brilliant a thing as expensive and allegedly fantastic as a Tesla is day to day, and gloss over the quality problems.
it's easily the most powerful and efficient EV on the market, but the rest of the tech is way behind most other cars. The cruise apparently doesn't use radar like every other car, instead it uses cameras and the camera tries to interpret what it is seeing - it's just not as good yet
mmm wonder is that from people getting the traffic related captchas wrong... :D
People say Tesla are around 5 years ahead of any competition with its powertrain. But why doesn't other company just license the tech? A Mercedes C-class car with Model 3 powertrain would be excellent.
Thanks for the update. Reads like even if you didn't stay overnight, you can still get around without any hindrance due to driving an EV beyond its home range.
10 hours ago, domhnall said:
Tesla owners often report a phenomenon known as phantom braking, typically this is described as the car hesitating as it overtakes trucks, or gets spoked by bridge shadows. I experienced nothing worse than a gentle slowing down as I passed trucks, easily overriden by pressing the accelarator. Bu then it got dark. Once night fell the car freaked out for no obvious reason - on 6 separate occasions it jammed the brakes on, a full on emergency stop would have happened if I'd not stamped on the power. Not a very comfortable driving experience so I switched off cruise and just drove manually.
This would concern me with a Tesla very much. The adaptive cruise on my Karoq is brilliant on the motorway but does do the phantom braking if a car is turning left into a side road on a normal road. Having seen videos of the next level predictive cruise control  VAG is using, that looks even better on non-motorway roads.
Thank you for your honest 'normal bloke' view of the Tesla, it is putting its capabilities into perspective.
TeslaBjorn has also identified a fairly repeatable case of phantom braking in Tesla vehicles.  On narrower single carriageway roads it get's scared if a large truck is coming the other way.  The extra width means the lorry rides closer to the dividing line than a normal oncoming car would, so the tesla gets scared and brakes thinking it's about to get  hit.
Perhaps this is partly due to the software having been developed & mainly trained on wider US roads, and may improve when they focus more on narrower European roads.
Mine did it again on the M6 last week, I was driving in lane 2 at 70mph and then bam, I was at 40 mph and a Mercedes Sprinter van had to swerve to avoid me. He was obviously a Tesla fan though as he was waving in a very excited manner as he went past me.
  • Sponsor
:D
Do you have the full/expensive self driving abilities or the free ones?
I raised this as a fault with tesla but after they scanned the car they said thwere was nothing wrong and this behaviour is a "feature" of the current software and they say it will get better as they develop it over time.
So much as with my previous report, it's a bafflimg mix of the brilliant (range, power and efficiency) and the downright lousy (auto headlights  and wipers seem to have a mind of their own and the cruise control is quite possibly possessed).
Our Countryman has on a few occasion thrown a total wobbler in town thinking we were about to hit a stationary car (can't remember the name of the feature). I'm not sure if it hit the brakes or me coz of the flashing red light and loud alarm but there was nothing, absolutely nothing in front of the car.
Auto wipers are universally crap, I've never had a car that could do it well. the best was my hated 2003 Renault Clio. It had full manual options for wipers as well as auto. And tbh the auto was probably the best of any car I've had.
autolight have always worked ok, but the principle falls down in rain and fog and people are lazy idiots. You need to swicth to manual then. I had to explain this to my SO who is not daft at all, but she still trusted that "auto lights " meant auto lights , in all circumstances. The RR auto lights are probably the best and clverest I've ever seen. They do partial full beam and you can see the bean tracking around cars in front of you.
It's interesting to hear how well you are getting on with it.
