MK2 fabia tappets/lifters tapping noise on idle
Hi my Fabia has the 1.4 BXW 63kw engine
I got it last July and I've noticed there's a clicking/tapping noise at idle, it seems to tap to a different rhythm.
Had anybody had the same issue with this engine.
Could it be the tappets/lifters
Thanks for any help
If it's different to engine speed then look for something loose like exhaust heat shielding.
Thanks I've had a good look around today for any loose parts and I took the exhaust shield off today while I changed the oil.
I'm going to take the aux belt off and let the engine run for a couple of minutes to see if it's a slack pulley or bearing.
This is the video of the noise it makes
