Skoda Fabia MK1 End of life??
Ah yes maybe it's a lifter.. is this something easy to replace at the same time? Damn it's making hell of a racket, is it ok to drive for the next 2 weeks untill I've got days off work to fix all this ? I will post a video tomorrow of the noise, I'm gonna try put a new spark plug in the dodgy one see if it's runs any better at idle, it's definitely still miss firing.
  • Replies 239
  • Views 32.9k
  • Head bolts are various different lengths and some have washers and some don't. They have to be positioned into the right holes. Here's the info you need....     Tightening/positio
  • Mine is a bit rattly after doing timing chain but it's coming from the gearbox which I think is the input Shaft bearing but don't think it's bad enough to worry about at this stage. Car has only done
  • You can get the lifters out using one of those telescopic magnets, Halfrauds sell one in a set with an inspection mirror for a fiver, well worth having.
Can't even seem to find any online not on euro or carparts4less either :/
  • Sponsor
Can't possibly be the right part. Says it fits every engine in the world.  Avoid.
Yeah it doesn't look right does it ;/ umm..
I'll try phoning my local auto stores tomorrow see what there saying.
Edited by MinkyMike
They just pull out of their bores. They can be awkward to get hold of to pull them out though.
On a different note, do you have access to a compressor and blow gun? I only ask because the cavities in my cylinder head were absolutely full of swarf after I got it back from skimming. Looked like it only had the most cursory clean by the machine shop.
Edited by TMB
The Mrs mom as a compressor I could go across and use if it looked like I needed to , but I was hoping to ask the guys nicely to do that for me, as I will struggle to get there with no transport.. ah thanks wino for that. Thanks all. What an head ache I have lol
Yeah, the whole thing is a pain in the arse but it can be sorted. Mine runs very sweetly now. Don't give up on it :)
You could use a vacuum cleaner to try and get any remaining swarf out of the head.
If you look at this video at about 18:08, he manages to pull one of the lifters out by just using one of the pushrods...
Vacuum yes that's a good idea !
Ah I see right very helpful, there all the way down there are they, umm. It sounds like the sound im having it coming from the top of the engine.. unless this noise travels from vibration, I'll get a screw driver on a few parts tomorrow and try taking the belt off again.. see if it's definitely the engine. See if I can pinpoint where about it's coming from , I guess I could sort of put the screw driver at the front of the engine .. similar to where there located .
Edited by MinkyMike
A faulty lifter can cause the tappet it controls to become noisy.
I've found them, (thanks wino) this is the cheapest I can find as well, some places are selling them for well over £20 pounds Each!!
https://www.ebay.co.uk/itm/8x-Valve-Tappet-Hydraulic-Tappet-ZH0083-Skoda-1-4-VW-Seat-1-0-047109309/264748328721?epid=712271955&hash=item3da43ae711:g:FZEAAOSwlWRdAgl3#shpCntId
Gonna order them and hope this sorts it. do them at same time I do the head.
Edited by MinkyMike
Would it of been cheaper to buy a different car, maybe but there again you don't know what problems the car will have your buying, and I'm already pretty invested in this :/ bah humbug! :P
Merry Christmas ay :)
Edited by MinkyMike
I've guessing I wont need to let them bleed out when doing initial setup now as they will be empty? / oil free
Just hope it drives for the next 10 days until I can do the work!
Literally only using it to get to work now, 11 miles away.
Edited by MinkyMike
Here's a short video of the noise it's making, had to take it round the block for it to start today, normally its right away, and you can see it did stop towards the end of the video, its intermittent, but usually does it more so then not,
after chaining the cam chain and water pump, I didn't experience any noise at all, it was lovely and quiet, this just started happening about a week ago.
https://youtu.be/6mfzWIvhdDE
Sounds like an old black cab! How many miles has the car done? Hope you get it sorted mate. I was planning to crack on with mine today but hasn't stopped lagging it down all day. Supposed to not rain tomoz so hopefully can get the new wings installed and bumper back on. My lounge looks like a salvage yard 😁
Haha yeah sounds terrible, 122k mate.
I know what you mean about the weather, couldn't happen in summer could it !
I've got no choice other then use it to get to work for the next ten days, just hoping it holds out and doesn't cause any further damage..
Edited by MinkyMike
Those are from Germany, Mike, so you might have to wait a while for them.
My head gasket went at about the same time of year too. Bloody cars :D
Yeah, I would think you are correct there, new ones should adjust without the need to wait.
Yes it's saying it should be here by the 10th at the latest so hopefully in time, can't find them anywhere in the UK ! Lol
That's definitely a tappet.
