system update mib 3
FInally :)
Just updated my Bolero MY21 (H22 0270) with new navigation database (yes, bolero MY21 has it).
Instructions EXACTLY as I've posted above:
1) Download zip.
2) Extract to NTFS flash drive
3) Insert flash drive and keep Bolero on for some time.
No need to click update or somehting similar! Just keep your head unit on!
I was driving around for 1h, using wireless carplay for music and navigation as usual. After 1h I still had 19.11 (factory). After 1h I've performed "hard reset" by holding "on" button on Bolero for 20 seconds. After that I saw 20.7.
(may be 20 minutes is enough, I don't now)
(I'm pretty sure that process took less than 1h, but version in system info updated only after bolero reboot)
That's it :)
Edited by batal
  • Replies 160
  • Views 61.6k
  • FInally     Just updated my Bolero MY21 (H22 0270) with new navigation database (yes, bolero MY21 has it).    Instructions EXACTLY as I've posted above:   1) Download zip
  • This Cubic esim has nothing to do with car`s services. It is only and only to create hotspot in the car. All the other services - map updates, weather, gas prices etc. will reach the car via buil
  • Exactly  Some people reported that update takes more that one our.  But interface is awful. While update you cant understand is it in process or not. You just need to keep head unit on for some time (
Anyone knows what is the last European nav database?
Mine is 20.10, and a friend of mine has 20.11 ( his car his newer than mine).
Edited by Capitanharlock
My nav database is 20.11 it was 20.10 when I got the car and when I looked after an OTA update it had changed.
Well mine has just updated. Following the advice from @batalabove (thanks!), I did a hard reset on my Columbus by holding down the power button and when it restarted the navigation version had gone from 19 11 to 20 10. The update files had been sitting on an NTFS formatted flash drive, plugged into the car, since last year but it's only now after the reboot that they appear to have been recognised.
That's great news! We seem to have discovered something that Skoda UK don't know about!!
Chris
no update for me though, still 'stuck' on 20.7 after ~45min drive with the stick plugged in, with or w/o reseting Columbus
MIB3?
On 30/01/2021 at 18:10, batal said:
https://www.drive2.com/l/577482199679370293/
Was:
now:
here is how we in Russia update maps. You can use google translate :)
Copy-paste:
1. Download the archive
2. Unpack it to a USB flash drive (format in NTFS)
3. Insert the radio from the USB and drive for 20-30 minutes (or leave it running), everything happens automatically)
Batal this is great,
I will definitely try this...which USB port you used! The front C or middle A?
Was:
now:
Copy-paste:
 Kodiaq (MIB3) has only TypeC :) And only 2 of them connected to Headunit (near to DSG shifter).
You need to use any port that your head unit can work with (play music from flash drive connected to it).
Maybe you need more time...
Unfortunately did not work for my MY21 Superb :-( left it on for 2 hours with the USB-C port, maps on the FAT32 USB stick, hard reset after 2 hours but still the same version. I than tried to do the update through the service menu but no luck, showing this error
One thought... batal mentioned using a NTFS formatted USB stick, so perhaps this is vital?
Chris
It's suggested that an NTFS formatted memory stick is used, although I don't see how that can really make a difference. Did you have the map files unzipped? For my Kodiaq there are almost 700 folders named MIB31* on the root of the memory stick.
Ah sorry, yes it was NTFS and the maps were unzipped, withe 3500+ files on hundreds of folders...would you mind to share the zip file you used to do the uodate?
Just a random thought - unit says "signature file not found". Means the package is missing the file.
Switch off all the antivirus programs you have (including native MS Defnder, if you are using Windows. Sometimes it tends to block files it doesn`t recognise.
And download the map files again.
3 minutes ago, Ber31inger said:
maps were unzipped
Here is the answer.
1 minute ago, linni said:
Here is the answer.
I meant that the zip file was unpacked to the USB stick
FWIW, when unzipped my collection of map update files didn't include anything with a .sig extension
Could be hidden file.
3 minutes ago, Blackbat said:
The zip file is specific to the VIN I believe, but the one I downloaded for my MY21 Kodiaq was this:
http://infotainment-cdn.skoda-auto.com/base/maps/OI_P41_EU_202025_Offline_Update.zip
Thank you...I wanted to download the zip file based on my VIN but they must have changed something as now when quoting update through my VIN, it shows there is no update available...last week it was showing there is one
Seems unlikely as hidden items are always displayed on my PC.
Although I've yet to try the install, there's no .sig files on my USB either.
Just wondering what you meant by you...   tried to do the update thru the service menu.   Service Menu - what's that?  Anytime I tried to run update via the option on infotainment, it never said it was looking for a file. How long did you have to wait before the missing .sig file error message appeared?
Edit:  I'm getting so confused with all of this so apologies if I missed it, but where did NTFS come from? My USB drive is setup FAT32.  I thought these systems could only read FAT32?
Edited by Guest
What hardware and software version do you have? Maybe it's differ from ours.
As I know for all Kodiaq\Karoq MY21:
H22 and SW 0270
H22 and SW 0270
Looks like same as yours
