Just now, RachelH said:
Im hoping you can help in anyway at all.
My daughter started learning to drive last summer (2023) so I brought her a car. A 2006 Skoda Fabia ….
FABIA HATCHBACK - 1.4 16V Elegance 5dr Auto 75hp
(She passed her test in January 🎉 - no more a mum taxi!)
The car was all working fine in the first few months of getting it…. And then the winter weather hit! Major damp issues in the back footwells (which my brother has now fixed 🤞) , and the electric windows have stopped working. My brother is fairly good with cars etc, he tested the volts in the motor etc and it was all still ‘live’ but nothing he has tried (fuses etc) has fixed the issue.
when my daughter got home yesterday she said it was so hot in her car and it was not great that she couldn’t open the windows…. and we aren’t even into the hotter weather yet.
Will you be able to help in anyway? I’m (we’re) desperate.
I forgot to say, we have tried a new motor with module ( 6Y2959802 - SK240DDRS) that didn’t make a difference.
  • Replies 204
  • Views 60.3k
  • Pete's service is highly recommended!   Our 2007 Roomster suffered from intermittent windows for approx. 2 years. Dealers could not find the problem. It's not easy to diagnose the fault
  • If anyone is being put off the idea of using this service due to the 'downtime' or inconvenience of having to visit the car twice, once to remove the module, once a few days later to refit the repaire
  • belvedere72
    belvedere72
    I would just like to add my comments and recommendation to Pete’s window motor repair service offer. I am a new member on this Forum and was surprised and delighted by the incredibly fast response I r
Hello Rachel, I'd be glad to try to help. I'll send you a Private Message in a few minutes.
On 16/03/2024 at 06:28, paulypaul said:
Morning
Have just emailed regarding motor exchange
Cheers
Have I replied to that email? Been a bit deluged recently and have lost track a bit.
I just wanted to say a big ‘Thank You’ to Pete for your help. We now have working windows.
100% recommended.
On 30/08/2021 at 13:20, Breezy_Pete said:
Hello Briskodians,
I would like to offer a repair service for some types of electric window motor module as fitted to a few Skoda models, as well as one or two VWs.
At this stage it applies only to two specific, exact part numbers fitted to the driver's side front door, as follows:
6Y2959802  Fitted to later Mk1 Fabia, from around October 2004.
6Y1959801  Fitted to Very early Mk2 Fabia and Roomster until end of October 2007; as well as 9N3 Polo and a few Transporters. (And some late 9N Polos I have learned).
Private Message me a VIN if you'd like me to check whether your car has this part number fitted.
(As described a few posts below, either of the above part numbers + suffix A on the end can also be repaired.  Also happy to try with units of the subsequent generation, with part numbers 6Q1959801F, G, H, or J.)
Note that both of these are driver's side units, the difference in part numbering is due to the orientation/positioning of the motor module on the panels they mount to.
These parts suffer a type of intermittent, progressive failure where they 'sometimes work fine, sometimes don't work at all'.  This is what I can fix for you.
I will test your faulty unit, confirm the problem, repair it to full working order and post it back to you for £59, total.
You'd post it to me (less than 1Kg so can be sent as a 1st class small parcel for just £3.69 using online postage at present, or £4.89 signed-for).  I would aim to turn it round within 2 days of receipt, and send it back 1st class signed-for.
This is the what the part looks like:
Central locking via remote will still work in the absence of the window module, so you will be able to secure the car as normal while it is away.
Obviously you'll want to ensure that both front windows are fully shut, as in the absence of the driver's side module the passenger side one will not operate.
New units are around £200 from Skoda/VW, and ebay 2nd hand ones with these part numbers tend to go for nearly £100.
I will charge you just £59 including return postage.
Cheers,
Pete
Hi
I would just like to say thanks to Pete for sorting this repair on the Polo window motor.
This is a brilliant service all done and returned within a couple of days. Excellent!
Hi Pete,
I need your help if you’re still offering this service for my T5? I replaced this 2 years ago with a brand new part from VW and it’s broken again,  I may have the old one kicking around if you needed stock. It’s VW705DDRS. I hope you can help me!
Edited by MichaelVWT5
Hello Michael, thanks for getting in touch. I'll be glad to help with this, and will send you a Private Message in a minute. 👍
Hi Pete!
please tell me your still doing this repair service? I got 2 Fabia motors and a polo 9n3 motor that needs repairing if you can do it :) what’s the best way to contact you?
Hello Josh, I've just sent you a Private Message with my number in it. 👍
Hi Pete
im looking for a repair on my window motor… 6y2959802. Please can you let me know where I can post and pay etc.
thanks Mike
Hello Mike, yes of course.
I will reply to your private message shortly,  just got to do the washing up first. 😆
Hi I got a faulty driver's window motor on a 2007 Fabia,  neither driver or passenger front window works, wires in the door are ok, can you have a look at it for me ?
No problem, I'll send you some contact details via private message. 👍
Hi Pete,
I'm looking to repair the window motor for my T5 transporter, the part number is 6Y1959801. Please let me know if you are able to help?
Best Wishes
Mark
Hello Mark, I'll be glad to help.  I'll send you a private message in a sec, with a contact number for whatsapp etc.
Cheers,
Pete
Hello, Yes, will email you shortly. :thumbup:
Do you still do this ? Ive sent you a message :) Need help with 6y2959802A SK250D4DLS
Edited by nystromer
Yes, message received.
Working on my own car just now,will reply a bit later today.
:thumbup:
hi looking to have my 2007 skoda fabia estate window motor repaired thanks
Message sent. :thumbup:
Can anybody confirm if the window motor module from a 4 door Ibiza/Polo (6Y1959801 i think?) with two front electric windows and two manual rear windows, will work on my Fabia with the same two front electric two rear manual windows. Part number for my Fabia is 6Y2959802
Hello @Gondard, no that won't fit, it's a mirror image of 6Y2959802,  look at online pics of the two.
You need an exact match to that part number, for it to fit and work correctly in mk1 Fabia. In addition, the bottom line of the part number label, SK240DDRS, needs to be matched for a RHD mk1.
Hi Breezy_Pete, thanks for the response.
Could installing it anyway not work? I'm sure that the wires will reach for the connectors to fit in.
I'm sure the rotation direction of the motor output sprocket will be the same for Fabia and polo too?
Would there be another reason why it would not work?
You won't be able to physically mount  6Y1959801 from a RHD car on a RHD mk1 Fabia.
Only thing you could try is to transplant the circuit board across into the 6Y2959802.
Not at all sure that rotation directions will be correct if you do though, but that can be changed by rotating the motor housing 180 relative to the brush-holder (circuitboard out first to avoid damage).
Pic of 6Y2959802 from mk1 Fabia above a 6Y1959801 from a T5. (Both RHD):
The mounting orientation is different between mk1 Fabia and all others, so the handedness is opposite.
This shot shows approx orientation when mounted on door in each:
Edited by Breezy_Pete
