2008 Octavia 2 2.0 TDI RS - Starts and instantly stalls, oil pressure light comes on.
Give us a chance by providing full vehicle details.
27 minutes ago, actuallyitschris said:
Pretty much described my issue in the title
Well, your video tells me that the charge light and oil pressure light are working normally. I have a suspicion that the immobiliser is stopping the car running, but need details to be certain.
It's Skoda Octavia 2 Combi RS 2.0 TDI 170HP Common Rail Engine with a DPF, would you like anything else as far as details go?
Wouldn't that make the immobiliser light illuminate? Also why would low oil pressure come on?
Anyhow I'm going to try my spare key in a second and let you know the results.
  1. Only if there is a separate immobiliser light on your car.
  2. Big hint; the oil pressure light comes on when the engine isn't running.
Confirmed with the second key, it's not a fault of the immobiliser also checked, yes there is a separate light for it.
I know it lights up during start up normally, but in this particular model the oil pressure light never lit up with the ignition on before, or after stalling and definitely not with an obnoxious sound like demonstrated.
Based on the video, it looks like the engine stalls well before the oil-pressure light comes on........ If it was an engine shut-down commanded due to the low oil-pressure, I would've expected the low oil pressure to illuminate sooner.
I would start by scanning fault codes with VCDS (or similar). Then you can also check if the immobiliser system is detecting the key.
I know you tried your spare key, but it could also be that the reader on the car has failed, rather than the key.
