Software Update available for Bolero?
thenyou need tu update to SW0469 and then to SW0741+sw0742
  • Replies 773
  • Views 224.6k
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
Hey everyone, I've been trying to stay on top of the updates for my 2020 Skoda Scala G-TEC with Bolero, and I've come across information suggesting that version 0469 might be the latest one. Can anyone confirm this for me? It seems like there's a lot of information floating around, but when I check in my local community, it appears that 0469 is the most recent update available.
Just to give you some context, I currently have the MEN3_EU_SK370_9494P version installed with 0464. Now, I've been experiencing some issues like the Bolero display not turning on correctly, sometimes getting stuck with the Skoda logo. To resolve this, I usually have to turn the system off and on again. Another problem involves the GPS signal loss on my iPhone when connected via CarPlay, which usually gets fixed by disconnecting the smartphone. Occasionally, I've also had the reverse screen persisting during regular driving.
Any insights or experiences you can share on these issues or the latest update would be greatly appreciated! Thanks a lot.
latest is 741 + 742
I went to the dealer and they made an update from the version in the photo below(0469) to 0742. They did not say that there were any newer version for this media unit.
Does anyone know if 0742 is the dead end for me or can I proceed to updating myself to 1800?
0-02-05-bcd6ffa95e7936aa292cd11afca5d04d668aa6069e8af41b8c289edea4aebd2f_a161f7ddfc634fcc.jpg
742 is the latest for your MIB
1800 is for other versions , not yours
Thank you for clearing that up for me. Do we know if this MIB suffers from the same issues as the others that needed version 1800 in order to connect some Samsung, Xiaomi and other phones?
Currently I am using a bit older Xiaomi 11T and it is still on Android 13, so can't really know if I will have issues when I upgrade my phone.
you need to try other phones, but nobody complaint about conectivity.
only newer MIB, with SW 17xx, had problems with Samsung S23 Android Auto.  But these are other hw units
there is someone here on forum that tried 1800 on his older unit with 469 and it didn.t finished the update corect.
4 hours ago, andreiro221 said:
latest is 741 + 742
Sorry, but how do I figure out which is the latest update suitable for my case? Is there an official summary? Because I read that some with my same MIB3_V1 are advised to update to later versions. While you tell me that the final version for my Bolero is 741 + 742. Sorry, it's not a lack of trust, it's just really confusing... 😦
I'd like to ask another thing while I'm at it. Once the update is done, is there anything else I need to do? Because I heard it's necessary to perform an activation via the Internet to align the car with the Skoda central system. But is that true?
And if I happen to encounter an issue with the update, is it possible to revert to the old version?
I take this opportunity to ask another thing. It seems like it's impossible to find a changelog for every version of the updates. Why is that? For those who may not know, in the realm of computing, a changelog is a list of all the changes made with the discussed update. It's usually a lengthy list of fixes.
if you are not sure, just take a trip to the dealer and pay for update 😇
for older scala/kamiq, 741+ 742 is the latest version curently available, you can ask the dealer.
you cannot restore older SW
469 chagelog :
Problems with rear camera view: The camera will either not start or - on the contrary - will not switch off while driving forward or even at higher speed.
The digitizer of the display of the control and display unit does not work.
The infotainment system is sporadically spontaneously switched on after parking and locking the vehicle.
Failure of ABT display (black screen).
MIB without sound or sound cannot be controlled; faulty voice control.
MIB is sporadically switched off
741+ 742 changelog
Problems with the reverse parking camera display: it either does not start at all or does not switch off when driving forward or at higher speeds.
The digitizer of the display and control unit does not work.
After parking and locking the car, the infotainment system switches on spontaneously/sporadically.
ABT display blackouts (black screen).
MIB is without sound or sound cannot be controlled; faulty voice control.
Fault B104914 is stored in the OCU control unit
Edited by andreiro221
I've already tried going down this route, but they bombarded me with nonsense. Stuff like insisting I need to go there in person to understand what kind of update I can install. Even though I sent them all the necessary screenshots, ridiculous!
Anyway, thanks a bunch for the specs. Highly appreciated!
Can you tell me if there's anything else to do after the update? Are there any drawbacks? Will the connection with the dealership still work? And, will the software keep functioning in my language?
for some special updates, some procedures must be taken with ODIS.
But not for those udpates, they are normal updates
once you finish updating, you need to confirm the installation change to erase an error. BUt it.s not mandatory. It doesn not affect in any way
https://mib-helper.com/im-so-xory/
Do you happen to know where I can find these two updates?
i will try to post them here the next days...
https://we.tl/t-RS6zfImWj5
unpack every zip in the root of usb stick.
Use usb C native Usb stick and a charger connected to the car battery. Engine off, ignition on
Can I leave the car running during the process? Just to avoid dealing with the external charge hassle.
it is not recommended .
Hello
witch Firmware Update ist for me the right one ?
I have many Wireless Connection Problem with this actually Firmware
IMG_20231028_135950.thumb.jpg.67e4163bf42642b0067830ecea8c807b.jpgIMG_20230723_175637.thumb.jpg.43f0469eab95e9992837b8451803e801.jpgIMG_20230106_162635.thumb.jpg.d1cfa75e8e34f0173c0ace5c23df4038.jpg
the same i posted ealier.
469 + 741 + 742
Hey guys! Am I able to update this to that 1800? Might fix my AA problems with some phones I've had over a year..
I have Kamiq 2021.
I have Kamiq 2021.
Adding this extra info
Hi again! I'm answering my own question here. So, I can confirm, that after updating to 1800 AA, after over a year, now FINALLY works on cable normally! I'm opening a beer now! Thanks for this forum! 😎 👍🏻
6 hours ago, andreiro221 said:
das Gleiche, was ich früher gepostet habe.
469 + 741 + 742
I want install newest Version than i need only 742 on Stick? Or need Update step by step First 469 / 741 than 742 ?
Big ty !
first 469, then 741, then 742
Hi i try install 469, than 741 all ok but on 742 come i mean error 28 aftert this my bolero dont do anything
i try hard reset , fuse of the infotainment but dont start, have any a idea how i can reset/start bolero if have no reaction ?
