Software Update available for Bolero?
On 15/03/2023 at 15:32, varooom said:
There are these updates, but not sure if the higher number will apply to your system.
MEN3_EU_SK370_P0113P_0469
MEN3_EU_SK370_P2135P_0742
MEN3_EU_SK370_P1185L_1760
MEN3_EU_SK370_P2345L_1790
The only one I would suggest is 0742 to try (it won't load if it's not compatible)
If it doesn't load, then 0469 is your current version and the end of the line.
is it possible to have 0113p_0469 ?
im breaking my head on getting it
  • Replies 769
  • Views 217k
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
Hello. My 2019 Skoda Scala appears to have a version that is older than any mentioned so far in this thread.
SW Train: MEN3_EU_SK370_P9155P
MU SW: 0451
Does anyone know if it is possible to go from 0451 to 0464? My end goal would be to follow the path of 0464 => 0469 => 0741 => 1800. Is that a reasonable goal?
MU SW: 0451
Try 464. It's possible it will be ok. Is it something wrong with your system ? Maybe you don't need to do the update?
Gents can you please send me the link to update my BOLERO _p9305p / mu sw 0463. Thank you all!
Please info is there an SW update available for my SW train Scala 2019 plate.
Tnx
Hi, I'm new around here. Does anyone have an update for this? Android Auto isn't working and I've seen that maybe version 1800 fix that. But I can't find any download link anywhere. Thanks for the help!
Hi. have you read this topic ? All answers are in. Here you have link to the firmwares. The newest is 1800.
https://disk.yandex.ru/d/1V1uBTc8ssc3zA
hello, I tried to update my system. I did two versions and the last one gave me an error. I tried to reinstall it but it didn't work and I canceled the installation. However, the version changed but unfortunately I have a problem with the sound, you can hear a slight noise in the background. When I want to upload another version that fixes this problem, instead of files, there is an error like in the picture.
Try to reset system, hold power/volume wheel, and try update again. Are you do it with all sugesstions ? Engine off, ignition on, charger at battery, native pendrive directly to usb port, firmware files unpacked correctly to storage ?
yes, I do everything properly. I have already done two updates and with the third one these errors popped up and now instead of files on the pendrive you see such errors. depending on the number of files you see so many duplicate errors.
you tried to update a SW that is not for your unit.
your 2019 Scala has maximum SW742
you were warned not to update to 17XX/1800 because there is no way to recover if something goes wrong
Edited by andreiro221
As I see adjorek had 1790 fw so he should update to 1800 with no errors.
But I updated to 1790 and errors popped up during this update.
Edited by adjorek
because 17xx is NOT for your unit.
You should have stopped at SW742
we've already established that. should i turn back time? i asked if there's any way to turn back/fix it.
On 24/04/2023 at 21:55, tatutee said:
I also have 1310 update. Where can i get the 1790 update?
Update successful, thanks! Will try AA now 🤞
3 hours ago, Sweden24 said:
As far I know 1790 won't fix AA issue. 1800 does.
22 hours ago, rakchendoor said:
hi
i have skoda kamiq MIB3 MEN3_EU_SK370_P2295L so can i update to MEN3_EU_SK370_P3355L_1800??
and if there is anyone who tried to tell me if there is any problem and does that solve the androidauto problem i hace samsung s23+
thank you
1bff39c4-7058-4e31-a2ba-5aab0bce477f.jfif 96.18 kB · 3 downloads c5ec722a-8594-4d83-9ed7-df4fe1550c44.jfif 188.22 kB · 0 downloads
Hi, have you read this topic ? I wrote about update to 1800 fw, and yes that fixed android auto problem with samsung galaxy s23/s23+/s23ultra.
THANK YOU @radoszczak
CAN I DO an UPDATE directly from version 1780 to 1800 OR 1780-1790-1798-1800?
MU SW: 0451
Is the update path possible? How did it go? According to mib-helper.com, the latest possible FW is 1760.
My Scala originally came with 0451 and the previous owner updated directly to 0469.
Edited by xayep
