Volume keeps turning up??
5 hours ago, anenezic said:
After reading all of the comments, I also decided to elaborate on the topic, and to see if there is some kind of update regarding this issue with Octavia MK4 model.
Basically, after buying as used car sometime in September 2024, car started increasing volume, restarting Infotainment system, and one day after work my wife could not start the car (some people from work told her that car was playing music on max volume for quite a while, so this is how we found out that it started Multimedia on its own). Battey drained completely so it needed to be changed. I got to a authorized service and they gave me replacement MMI, “which didn’t have that issue”, to test it some days. After no issues for 9-10 days, they ordered new MMI.
Infotainment display was changed sometime in December 2024 and I had no issues until 2 months ago, when after washing my car, volume started increasing again on its own. It was random, like previous time, but this time I didn’t have issue with MMI restarts nor starting MMI while car engine is not running - only volume up issue. Volume bar below the display was not changed at all.
Since I was still in warranty period of previous replacement, I contacted Skoda and they ordered a new Infotainment display - only asked for video as proof to factory. I sent it, and no additional questions asked (kuddos for that). Month later, new MMI came and I got a call to get it replaced (in the meantime, I didn’t experience any issue for a month! Nevertheless, I got it changed, and moved on as usual.
Couple of days ago, I went for a short vacation and left the car at the airport parking lot - and you imagine the stress of car not recognizing the key… Then, I thought it was the battery. But the key was giving a red light when pressing the buttons.
Anyway, 2 hours later, found somebody to start my car with cables and it got me going (Start/Stop option was not available, and bunch of yellow signs, but could be driven - 3 hours ride, no sign of volume, or any similar thing).
Since it’s weekend, I still didn’t have a chance to get it diagnosed in the Skoda service, however I wanted to write the post for all, due to the fact that my new MMI is actually H49, praised by some of you. I hoped it was not H49 - as this seemed like light at the end of the tunnel, but after checking, my new Infotainment replaced a month ago is H49 (picture attached).
Are there any news or developments, or any device that some of you might have?
PS. I suppose I will need to change the battery, but I managed to start the car with the same battery 3-4 times this morning.
The last issue you had sounds more like a bad/old battery problem. I'am still holding on H49 no problems so far (1yr since replacement).
Keep monitoring the issue.
  • Replies 126
  • Views 45.7k
  • Hello, after reading this thread, I decided to share the information I’ve gathered so far. I started experiencing the same symptoms as others described here: randomly increasing volume, key press sou
  • mertpolat
    mertpolat
    @omeromeryigit Thanks for the information you shared. I followed the steps in the post one by one, and in the end my volume increasing issue was fixed. I solved the problem by cleaning the unit that
  • I have now been driving for four weeks after I cleaned the inside of the touchbar and have not had any issue with the volume turning up by it self. Take it apart and carefully clean it with isopropyl
My System started acting up on the volume/power sensor as well today when i went to work.
Fun ride to work constantly fighting the screen turning itself off and on again the entire trip. When i came back home everything was normal...
I might have to disassemble it to clean with isopropyl alcohol soon
Edited by Jack_Dangerous
Hello, I advise you to use a glasses cleaning cloth to avoid leaving any residue.
I did, with cotton swabs for the edges, i already reassembled everything and it seems to be working fine, i have to keep checking at night as well when it gets colder. I did turn on the AC with the car running on full cold and it didn't do any ghost touches like it did before.
It was a fun day though, was going out for lunch and the car wouldn't start because the battery was low on charge, jumped started the car with my dad's car, the battery charged fine, held charge fine, went to a car shop 30 minutes away, they diagnosed the battery and said the report came out completely fine, so i'm pretty sure it was the infotainment turning on and off during the night and day while the car was parked with the AC and everything. It has to be this because i've noticed that since the power button started acting up, the car wouldn't auto-unlock when i put my hand on the door handle when it was parked for a day.
Today was pretty eventful but i hope the problems are over... Kinda wild how it took 5 years for the power button to start going crazy, must have been humidity from the severe winter rains we had
@omeromeryigit
Hi Omer,
I have exactly the same issue. I took the car to the dealer and they told me the screen needs to be replaced. Unfortunately my car is a 2023 model and the warranty has already expired, so I don’t think they’ll cover it.
I’d like to try cleaning the touch bar with IPA myself before spending money on a new screen, but I’ve never taken one of these apart before.
I tried sending you a PM, but the forum won’t let me because I don’t have enough posts yet. Is there any way I could contact you? Either through PM or any other channel you prefer.
Edited by mertpolat
Edited by omeromeryigit
My car's a 2021 model with the H44 head unit and I've had the same problem recently, which started during the high temperatures the other week. It started with the head unit rebooting itself as if someone was pressing the power button, and then the volume started turning itself up. From then on the head unit would just constantly reboot itself, making clicking sounds as if someone was pressing the buttons. It’s quite distracting and arguably a safety issue, with the volume suddenly blasting out and the screen flickering on and off while driving
I tried cleaning the underside of the volume bar, but this didn't fix the issue. I've had to unplug the volume bar from the head unit, as others have suggested, which of course "fixes" the problem, but it's obviously not a perfect solution.
It's really not right that all these relatively new cars are failing in the same way. It shouldn't be down to owners to fund repairs for what appears to be a widespread hardware defect.
I have started getting this problem the last two days volume going up by itself
And randomly turning offf and on
2023 VRS
2023 VRS
Hello, Was the car parked in the sun?
There is also an impact due to the heat in the car
No heat here in Scotland maybe 21c max
Okay, we should try to clean it
Still working for me after this cleaning, no problem with the heat from the last days 👍🏻
Same here.
Potential Root Cause(AI generated based on the information and investigation):
Finding that the left corner of the Flexible Printed Circuit (FPC) had delaminated (un-glued) from the plastic front lens perfectly explains the random behavior.
In capacitive touch systems, the sensor relies on a uniform dielectric layer between the copper traces and your finger. When that FPC lifts, it introduces a variable air gap. Because air has a completely different dielectric property than plastic or adhesive, any change in cabin temperature, vehicle vibration, or humidity causes the capacitance to swing wildly, triggering those annoying "ghost touches."
To secure your repair and prevent the FPC from lifting again under the intense heat of a summer dashboard, you need an automotive-grade solution.
The Professional Solution: Kapton (Polyimide) Tape
The best technical solution to overlay and seal the back of that FPC is Kapton Tape (Genuine Polyimide tape).
  • Excellent Temperature Resistance: It easily handles continuous temperatures up to 260°C (and short terms higher). Dashboard components can easily exceed 70°C–80°C in direct sunlight; standard tape will melt, slide, and leave a sticky residue.
  • Low Static / High Dielectric Strength: It is an exceptional electrical insulator and does not build up or retain static charges that could interfere with the capacitive sensing traces underneath.
  • Ultra-Thin Profile: Looking at your layout, the green main PCB with the LEDs sits incredibly close to the black trim piece when clipped back together. Kapton tape is incredibly thin (usually around 0.05mm), meaning it won't add bulk or create mechanical pressure points against the LEDs or components on the green board.
How to apply it:
  1. Cut a piece of Kapton tape wide enough to cover the lifted corner and extend slightly onto the solid plastic frame.
  2. Use a plastic spudger or your thumb to press it down firmly from the center outward to ensure zero air bubbles are trapped between the FPC and the plastic housing.
  3. Seal the outer edges of the FPC completely to prevent future moisture or cleaning sprays from creeping under the circuit.
What to Avoid
  • Standard Office/Packing Tape (Cellophane/BOPP): Do not use this. It degrades quickly under heat, the adhesive dries out rapidly, and the act of unrolling/applying it generates massive static electricity (ESD) which can glitch or permanently damage the sensitive touch controller inputs.
  • Thick Foam Tapes: Avoid thick double-sided foam tapes on the back face. They can compress unevenly and push back against the green PCB, potentially flexing the main board or cracking solder joints over time.
Edited by djmartzian
After a week on the road in the Heat of Italy, still works fine 👍🏻
Edited by Valentin
Hi guys, I have the same issue with my Octavia last few months. The volume keeps going up, making it difficult to drive. I have updated to 1989; same issue. I have also removed the fuse a few times, but it's always the same symptoms.
A few days ago, I deleted the BT connection with my iPhone from the system. Not using Apple Car for 5 days. It is very hot in Belgrade (40c), and the infotainment is working stably. Since then, I have had 0 issues. I will test it for a month to see.....
The problem is in the volume slider. It is a hardware problem.
I agree, but I had an issue every day; now I don't have one, strange.
Also I have the annoying issue with the radio after owning the car for 3 years. Started after one hot warm day in April this year. So now and then the volume keeps increasing (you know..), this now already for some months. Some days more, other days less.
Its my wife’s daily’s car, so I have to come up with something.. Also read topics on the internet, informed the dealer.. Opening the device to clean was my last option.
I have the hardware h56 version (software 1668).
For me, now after 3 weeks of hot sun on vacation it looks solved.
Could the issue with some cars also be static electricity in the device/plastic due to the heat, sun, airco and so on.. (Think most of us don’t use the bar..)
With one hand I touch the touchpad, other hand some mass of the car (underneath seat or something) for approx 10 seconds, and the issue is not appearing anymore.
Hope it stays this way.. 🙃
Edited by R_one
Now that's an interesting fix!
Following as my volume ghost has appeared again
Still no issue, 10 days after CarPlay disconnected, after 3000 km and 40+ temperatures. I am testing further...
Maybe grounding the touchpad housing permanently could be a solution? Can someone less lazy than me try it out? 😁
No issues with infotainment so far with CarPlay disconnected.
Recently Browsing 2
