Message added by mac11irl,
Please do not post VIN or email addresses in your replies on this or similar threads. Doing so triggers the auto hide mechanism on the site and circumventing the rule may result in moderator action against your account
Data like this can be used for fraudulent activity across the internet and the real world.
Only send this type of information via the personal message section to trusted members only.
If you cannot yet send a pm as a new member, simply tag the person you wish to contact in a post and ask them to start a private conversation.
Thanks and safe browsing,
Briskoda Admin Team.
Kamiq MY20 MIB3 Update
On 17/02/2024 at 18:28, r0bb10 said:
PS: btw, proof that i'm on 330 now :) i also connected the car to my wifi in the garage and perfomed an online update for the maps, i'm now on 23.6 database and not on 20.11 like the photo sais).
IMG_8022.HEIC
Edited by SSalvo
I want delete
  • Replies 179
  • Views 70.9k
  • So a little update: EVERYTHING WORKS.   Let's start a "Journey Diary - Guide" so that everyone that wants to do it can follow the steps and update. First of all, the previously mega link pos
  • Dear @r0bb10 and @Lennart, I want to thank you for sharing your update stories !   Thanks to you I finally took the plunge and did the update tonight. I have a Kamiq MY21 that came
  • Yes with the help of @Lennart i found everything to bring the sw to the 0324 release, here is a mega link where you can get the archives of the old cumulative versions until 0308, you can download 032
IMG_8022.HEIC
On 18/03/2024 at 16:15, r0bb10 said:
Yeah you need other files before the 308, if you upack the 308 file there is a file inside called manifest.xml iirc, you can open it with notepad (or notepad++) and look on which version it can be applied, like this example:
 "Manifest": "1.0.0",
 "PackageName": "MOI3_EU_SKMQB_P30800P",
 "PackageType": "main",
 "PackageVersion": "308.0.1",
 "Release": "MOI3_EU_SKMQB_P30800P",
 "MuVersion": "0308",
 "SupportedTrains": [
  "*_?268*",
  "*_?270*",
  "*_?272*",
  "*_?274*",
  "*_?276*",
  "*_?278*",
  "*_?300*",
  "*_?302*",
  "*_?304*",
  "*_?306*",
  "*_?308*"
the EU version of 308 can only be flashed if your current version is at least 268 on newer on on 308 itself, you have to trace back evey version but i assume that RW it's very similar if not identical as the EU.
finding older versions is difficult i know, i have the olders one for EU only because @Lennart shared them, i dont really know where to look for them, surely somewhere in the VAG flashdaten.
sorry for not being more helpfull 😞
I've had a look through the Skoda file list on VAG Flashinfo and identified these two files:
  • 5FMIB3OISW278RDW.zip 30.06.2022
  • 5FMIB3OISW278SOP1RDW.zip
But I can't find them anywhere online. I checked Erwin for a relevant TPI and the only document referring to software updates is for version SW324 and the TPI presumes the oldest version is 270 which doesn't help me stuck on 156.
To make things worse the RW 308 software file hosted on MIBSolution is corrupt.
This is really frustrating!
Hi all, @r0bb10 and @vegarz, after a long break, I'm back and determined to finally do this update from 0156 as it has started to be more and more laggy. Progress I've had since last time is I bought a VCDS from RossTech, so I can do some other adaptations as well. Anyway, checked my OCU version and is 88, I know it was mentioned previously that its important. I quickly had a look with VCDS in Telematics 75 with the adaptations, and from the dropdown I couldn't find anything that resembles this Crash Signal menu indicated on the TPIs and in Rob's post.
Really appreciate any guidance here.
Many thanks in advance!!
@pkk11 I've recently updated my OCU from 0035 to 0143 (started with unit 5WA035284B and now 5WA035284G). I have ordered a VCDS device to update the Crash Signal as I don't know if it has been done already on my car. I will let you know if I find out how to do this adaptation. I have a feeling though if you have version 0088 already then this adaptation may already be applied.
Edited by scottie1010
I couldn't find anything resembling the "Crash signal" parameter either on VCDS for the OCU. Does anyone know how to go about this?
  • 3 months later...
thanks for this thread it helped me a lot!
So here is my feedback following the update of my skoda Kamiq 2021.
I had a very annoying issue when driving from time to time the digital cockpit starts rebooting so I decided to do something about it 😉
I was in software version 0156 with 00071C00 FEC already installed.
my upgrade path 0156 -> 0238 + 0268 + 0278 (~60min) -> 0308 (10min) -> 0324 (10min)
I just bought a usbc3 key, copied the files and voilà 😁
the FEC code is still activated and navigation system is doing fine.
BTW does anynone know how to get the OCU version with carscanner ?
Hi @m_symon Can you please or someone else help me ? I have the 0156 version, Im looking for someone to guide me  through this to keep everything working.
Thank you !
On 23/10/2024 at 11:07, m_symon said:
Yes:  Open " ECU identifiers" and select controller 75 (Emergency Call....) or all and read, .... You see the version
Edited by GiscoYeti
On 30/04/2024 at 11:35, aaaaplay said:
Edited by Rainesh
Wrong
Anybody
Do you know of any reason why my vehicle would not be reading the USB pen for the MIB3 update?
I can't get out of 0156 version and the manufactures want £75 per hour overnight to update.
I have tried USB pen via OTG connector and SD card via type c card reader. None of them work.
I have tried putting the content onto the root of the drives with exfat and fat32 formatting.
Smallest allocation to biggest. Nothing it appearing in the engineering menu for update. No source is being read.
Do you know where I am going wrong?
1 minute ago, botty67 said:
Anybody
Which version are you trying
To be honest, I was going with _P27800P until I sat down and actually read 5WA035284OCU143 comes first.
I hoped that would be the end of it but then I got nowhere fast with that either.
Everything I have tried always has the Data and Meta folders so they should atleast show up? No?
Hi I recently made the switch on a friend of mine's Kamiq MY20 from SW 0156 to SW 0330 (156>>> 0238+0268+0278>>>0308>>>0330) after checking OCU from ver 088 updated to 0143. Thanks to this thread, it helped me a lot! We used a 32GB USB C formatted strictly in FAT 32 and dezipped files with 7Z.
The only thing I can think of is, I didn't use 7z to extract it. That's can't be it though.
There was a tracker in it, going through the obd port. I removed it and there was a split wire. I connected it up but if faulty... That wouldnt cause this mess would it ..
Hello, I just wanted to ask if the software update to version 0330 (currently I have 0324) will cause any issues with the functionality of the coded features on the 2020 Kamiq model.
Currently, I have map data from 23.12, even though I downloaded the latest version from the Škoda server a week ago. For some reason, the update via USB stopped working. As a test, I paid for the infotainment online service about 3 days ago, but the map data still hasn't updated. That's why I'm wondering if a software update might help.
Many thanks 🙂
The current map version from the Skoda website is June 2024, supposedly only updated once a year.
I received the 330 online and so far my maps have been updated online
I have never received any software update via OTA! 😞 I know that maps updates are sent once or twice a year. I currently have the last update of maps on USB, and I also have infotainment online paid, but I still have maps 23.12 and software version 0324. According to what key do they send software updates via OTA...?
Today I got new maps database via OTA. Now I have 24.10 so paid service infotainment online does work.
There were 24.6...7....8....9....10 then there was nothing more....
There is a new software for the MIB 3, Version 0332, but it has probably not yet been delivered
Hello everyone,
I need SK RW 308 fw to update from 306, I can't use EU variant.
Does anyone have this file?
Thank you.
On 23/01/2025 at 07:51, ersincakir said:
Hi friend,
Thank you, but I need RW firmware instead EU :) I will be appreciated if it is available :)
Best regards
there is a one now available on mibsolition. Although I've tried it and it seems to be broken
New map update online available 25.1
Edited by User_
