Dipped headlight adjustment
mjp99
Recommended Posts
I feel the headlights on my 2019 Karoq are set too high on dip. I am a little confused as to whether I can adjust them or if I have to fork out a fortune to have the 'levelling' setting adjusted?
Link to comment
Share on other sites
Not a scooby, not least because you've not seen fit to actually tell us which headlights you have.
  • Like 1
Link to comment
Posted (edited)
Dear Scooby - thank you for your helpful reply. I am not aware of the different choices - could you tell me and I might be able to help you?
The car is a 1.5 Petrol 'SEL'
Edited by mjp99
Link to comment
You can adjust any headlight. If it's LED self-levelling I believe the adjustment sensors are on the suspension arms, if they're the older bulb type headlamps there should be two plastic adjust screws on top.
I was told my car would have failed it's MOT due to headlights being too low - the MOT examiner adjusted them FOC for it to pass. ( the full MOT cost me £25 ) So when you say fork out a fortune ?  It's a 5min job for those who're doing it all the time.
Edited by kodiaqsportline
Link to comment
Many thanks, K. I read somewhere that the levelling system has to be set up with specialist (and hence costly) equipment. A 'DIY' option would be very good.
How can I see an image of the 'suspension arms' - I could not see anything obvious when I last looked? Is there a diagram/pic in any of the manuals carried on here?
Link to comment
It's just something I picked up but never really had a look. I no longer have the Karoq but just checked my Kodiaq - bloody hell, no wonder it was free of charge :D
There are two hex screws on top of the headlight assembly - I presume one is for full beam, one for dipped. Just turn it !  Of course that's the easy part, the hard part being how far do you turn it ( and what direction do you turn it ? ) without them becoming illegal? I'm sure if you look at YouTube there will be all sorts of tips on how to align them - trick is making sure your car is level.
It may well have been true in the older days of self-level lights that you had to seek the help of a specialist that cost £££'s.
On 18/03/2024 at 16:22, agedbriar said:
On my 2019 I can set the halogen lights' height on the infotainment:
Car > Settings > Lights
Would only work if someone else had reset them from factory.
With all the potholes and bumps on the road designed to slow you down ( some which are crazy aggresive ), it's easier than ever to knock the lights off factory setting. If that's what's happened with OP then even if there was a setting ( pointless on self-levelling lights ? ) the beams would still have to be manually set back to factory default.
Link to comment
3 hours ago, mjp99 said:
Well, back again to see if anyone might know the answer, but, amazingly, no? However, back to the top in case
Can you lift the bonnet and post a close up picture of a headllight unit.
Link to comment
On 18/03/2024 at 17:26, mjp99 said:
That would have been nice, but no. I see two yellow collared ?screws? on each unit. Are these what I need?
Should be, we have those and I use them to adjust the headlamps down when travelling in France to prevent dazzle. Three full turns of the appropriate screw does the job.
  • Thanks 1
Link to comment
Did it pass its last MOT with the headlights set as they currently are?
Link to comment
Posted (edited)
Were? Or perhaps they were not? Are you certain? Have they moved? History is useful but not definitive. Or, to put it in simple terms, because something 'was' does not mean it 'is'?
Edited by mjp99
Link to comment
I’m sure you’re local MOT station would be more than happy to check the alignment properly (presuming you don’t want to do it the old fashioned way at night against a wall)
Link to comment
Posted (edited)
For sportline and sussmb, pics of offside unit. Any idea which is up and down? Do the yellow bits have to come out before adjustment or are they just 'restrictors' or possibly the actual adjusters looking at the allen key shape?
Thank you to winston for reminding us of the 'Harvey wallbanger'
Edited by mjp99
Link to comment
Looking at the image posted, the yellow caps stay in place - you will need a correct hex. key (allen key) to adjust - I'd suggest a 'T' handled one for this.
Link to comment
 Bear in mind that only one of those adjusts level. The other adjusts left and right. Many cars have a level switch which allows you to adjust the level depending on load, don't know if any Karoqs have this. Mine doesn't as it has LED headlights., but all of my other recent cars have had it. Lastly, it isn't always necessary to lower the lights for travel to Europe. My car has an adjustment in the menus to change from driving on the left to driving on the right. Again this may not apply to all Karoqs but it is worth a look.
  • Like 1
Link to comment
Thanks so far to all who have helped. I have had a 'tweak' on the headlights and I will see if the adjustment remains as set. I am confused in the manuals as to whether the 'automatic levelling' will reset to its original setting! Hopefully I won't get 'flashed' so much now.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
