Update To Infotainment Version 1985 - Download Link and Guide
On 29/11/2024 at 22:18, Djadjo78 said:
Ho avuto uno scenario di schermata nera dal nulla durante la guida con iPhone CarPlay collegato su sw 1941.
Ma il mio e il tuo problema lo metterei tra quelli previsti, non a causa del nuovo sw, ma come "normale" possibilità del 10% di avere qualche strano problema perché il sistema stesso è tutt'altro che perfetto e stabile. Nel 1985 ho sperimentato nessun logo radio per alcune radio che avevano il logo e due volte durante l'avvio dell'auto ha detto per due secondi Scegli utente/profilo principale, ma è solo un utente principale in ogni caso e anche se appare questo messaggio, la configurazione dell'infotaiment era il layout corretto per l'utente principale.
Fratello
I have the sw 1941 (g-tec 2021) and it keeps turning off and on again, when I turn it on it always asks me to choose the main user/profile.
I have an appointment at the garage on December 16th to see what can be done
  • Replies 160
  • Views 60.6k
  • As a point of reference, I have just done a 300 mile round trip and version 1985 was solid and stable on my Octavia.  Obviously that doesn’t necessarily translate to another vehicle as other factors a
  • I was told by a VAG software specialist that you can apply the update with the engine running...    Regardless, thanks for the info. I have the file, but as a new Octavia owner (less than a
  • Well just did a factory reset which came with another OTA update so will see how this goes...
I did update according to instructions, beside that I did it on working engine. Everything was fine, didn't get any errors. It took around 20 min.
I got Octavia iv 2021 phev, so this work on it too.
My softare is now 1941 so can i jump on this 1985?
And i live in finland.
Edited by tonzu
Yes you can make the move from 1941 to 1985.
I downloaded the file and try copy it on usb-c memory card but it say some files is invalid name or too long??
I would rather wait for the OTA, if I were you, instead of trying to update it yourself. There can be some differences in hardware versions, which may (or may not) play a role if your system can support 1985. Is there no OTA for you available?
Unzip solved that invalid name problem.
No in finland we dont got OTA for this skoda.
You mean this version not suitable for finland cars?
It's an EU version so it fits. The firmware checks before updating.
Thanks.
We do get 1985 as OTA update in Finland. I already got it last week. My car is 2024 Octavia PHEV and Infotainment was in version 1969 (my dealer did that update because of bugs).
I have a dumb question. USB-C just in front of the gear knob right, where we hook up the cables for our phones?
Yes, because other two usb c are just power and for back seats
19 minutes ago, Djadjo78 said:
Edited by spcdust
Will this software work for all octavia models? I have octavia 2021 PHEV RS model. Is this software for this model as well?
Yes, but it would depend on your current software version to whether you could update to this version right away or not...
Update:
I upgraded the software from version 1941 and all went well. I upgraded because I experienced light flickering in the instrument and infotainment panel which was super annoying. I haven't driven far but as of yet I didn't experience any flickering yet, lets hope the new software solved this issue.
I’ve had my 2022 PHEV model for just over a month. It has the following config:
Hardware: H58
Software: 1889
Display unit hardware: H47
Display unit software: 2103
Nav DB: 24.10
I’ve never updated the software on a car before. From looking through the posts, 1889 is pretty old now. Is there a recommended upgrade path from 1889?
Hardware: H58
Software: 1889
Nav DB: 24.10
I updated from 1896 straight to 1985, but only after seeking advice from a professional. No idea if you can do so from 1889 but hopefully someone who does know will see your post and be able to help
I have updated from 1803 to 1941 in one go firts, and then from 1941 to 1985, everything is OK, no worries about the old versions :)
Hi. Thank you for the link to download update 1985. I updated today, it went fine and I already have version 1985. Update time about 19min. It's freezing outside so I preferred to leave the battery connected to the charger during the update. Everything is fine, we'll see how the system behaves. ver 1969 wasn't bad in 1, I only had to restart 2 times but otherwise fine. We'll see what version 1985 is like. At first glance, no changes, just the system started up faster. If anyone is interested and needs a previous update, I have the previous updates 1941 and 1969 saved on my PC. Just write it down and I won't share it anywhere.
Congrats, however, it's an urban myth that you can't update with the engine running, I did and everything went fine, countless others have too. I was told by a VAG software specialist that it was fine to do so and it is. Just for anyone else reading who thinks they may have to hook up to a charger or something similar...
44 minutes ago, scotthugh3s said:
Gratuluji, nicméně je to městský mýtus, který nelze aktualizovat při běžícím motoru, já to udělal a vše proběhlo v pořádku, bezpočet dalších také. Bylo mi řečeno softwarovým specialistou VAG, že to bylo v pořádku a je to tak. Jen pro každého, kdo si přečte, kdo si myslí, že se možná bude muset připojit k nabíječce nebo něčemu podobnému...
Why unnecessarily let the engine run for 20 minutes when it is easier for me to connect the charger. Of course, those who do not have the opportunity to connect the charger can leave it started. For me, the charger was easier when I have a socket right next to it. And in addition, if it is -2 outside, it is gentle on the battery, which decreases its capacity, it showed only 11.9V after turning on the ignition and if I want to finish the update, I have to use the charger or start it. In the summer, I updated 1941 to 1969 and because it was warm, there was no need to start anything or use the charger when the voltage was 13V
On 18. 12. 2024 at 13:26, tonzu said:
Stáhl jsem soubor a zkusil jsem jej zkopírovat na paměťovou kartu usb-c, ale některé soubory mají neplatný název nebo jsou příliš dlouhé?
You need to format the USB drive to "exFAT". Then unzip the zip and move the two folders to the USB.
Yep that's fine for you in your situation, whereas I have no access to a power point where I park my car and don't own a charger. Whatever works best for each individual is obviously the easiest way to do it.
My comment was merely to highlight the fact that you can do it without a charger and with the engine running, as in the main post and explanation it suggests you need to have the engine switched off, which isn't true. Just for those of us like me where following the process you used would be impractical 👍🏼🙂
Just updated my first edition Octavia to 1985 no issues.  First time I’ve done it with the engine running again absolutely fine:)
