From Amundsen to Columbus: mission almost accomplished!
Hi there! As many of You know, among the several retrofits I’m doing on my Karoq, there’s the screen update, from Amundsen (8 inches) to Columbus (9,2).
While the rectangular connector fits perfectly (audio works and buttons turn on), the screen remains black due (according to mechanic) to the different Fakra connectors, blue on Amundsen and Black on Columbus) as they have a small tooth in a different position (top on one, bottom on the other).
According to You/Your experience, replacing the cable can solve the problem?
Take a Cutter and cut until it will Plug 😉
You mean the small tooth? And are the inner wires in the correct order?
Did You get my DM about the datasets?
  • 11 months later...
This morning I brought car to Skoda Dealer to replace the factory Amundsen screen with the Columbus one (part n. 565919606D) and factory Amundsen navigation in the glove box with the Columbus one (part n. 3V0035816K); I also replaced the cable what connect the two units.
Of course I brought with me the purchases invoices to witness the parts were regularly purchased from a wreckage shop in order to remove legally the component protection.
One hour ago Skoda contacted me saying they gave up as the screen doesn't turn on: can anybody help me saying me what else can I do?
Why 3V0035816K?
This is kamiq/Scala Not for 9,2" Screen
Edited by Cairus
In Skoda they told me I can get the K or the P, and I found a good deal on the K
If the K unit is really meant for the Kamiq/Scala, that could explain the black screen. I’d double-check the exact compatibility before replacing or modifying anything else.
Now I need only to ask Skoda to remove the old component protection and apply to the new mib
What have you Pay for the sreen?
MIB3? Preh Manufactur? Simple to patch CP Off via USB, but Software dont Higher then 332
I was lucky: got it for 130€ from a totalled car in a wreckage shop with regular invoice
Yes it’s a MIB3; i prefer not to patch as I want to keep all the services connected
My 9,2" Display Display, the same in the kodiaq, 50€ 😂
Edited by Cairus
Luckier than me, indeed
Component protection removed and retrofit done but navigation, smartlink and vocal commands don’t work. But online services via app are on
Looks like the FECs didn’t migrate yet!
Any idea how solve this without patching the unit?
Edited by Benja77
Sorry. Nobody read What i say:
Did you perform the function activation? It probably won't work with ODIS Online, though, because different data is stored on the server.
If IT works, only the Fec's from Factory out are activ.
In my opinion, the online services are completely useless. The MIB3 runs much more stably and reliably without them. So, disable them via coding, patch the unit, and you're done.
But in this case, since the CP has been officially removed, the online service might actually work despite the FEC patch.
Edited by Cairus
But point I’d like to keep on using at least smart link to connect my iPhone as GPS and vocal commands.
However I didn’t patch unit at all; only thing I can do right now will be upgrading the MIB’s firmware to version 324 or 330 (actually is 320)
Edited by Benja77
Personally, I would update to 0330 and then apply the patch; that way, you have 332 as a backup.
Recently Browsing 1
