Activating SmartLink on Swing 3
Hello gentlemen, where do you get the software for unlocking Smart Link? Are there any websites with procedures? Thanks 🫡
  • Replies 200
  • Views 50.2k
  • DOWNLOAD needed software
  • Worked perfectly but it was to hard to get it readed the clap is tricky i Have unsoldred and soldred back
  • You Guys are amazing! Thank You for all. Everything Works perfect! Keep up the good work
Hello friend, thank you for the link. I am interested in the general software release for SmartLink. For all units (VW, Škoda, Seat, Audi, Cupra), for all cars. I am happy to pay the software provider for support and the software itself. Wishing you a wonderful day.
I have Skoda Kodiaq with version MEN2_EU_SKGPx_P9160L version 8742
Will it work for me?
Probably, it will work.
Hello,
I am trying to activate Smarlink for my Octavia 3 (code MEN2_EU_SKGPX_P9160L). I bought the kit with the clamp and also the sop8-150mil tool to have a better contact. The main problem for me is that when I push normally the sop on the cip, the red light from ch341a turns off. I managed to get some reads and even writes by pushing the sop on the cip just a little bit but it has a very tiny spot when it works.
So, did anybody encounter the problem when the red light from the programmer turns off when connecting to the cip? I also tried USB 2.0, USB 3.0, all the positions on the board.
The tools bought:https://share.temu.com/6hTNo5D4bkB (sop8-150mil)
https://a.aliexpress.com/_EHsA0iE
Thank you in advance!
Did multiple devices with this method, never get this problem. There was people which had this problem, solved with desoldering eeprom chip, or desoldering atleast vcc leg.
Before desoldering double check did you connected everything ok, try with and without 1.8v adapter, if everything fails, I would try to unsolder vcc leg.
Thank you @Zlatko580 but I will not desolder, it is too much for me.
Posted in wrong thread
Edited by BionicJohn
29 minutes ago, BionicJohn said:
I downloaded the necessary software (about £40) for my 2016 Octavia from here: https://www.visioncoding.co.uk/collections/skoda
You then need an OBDEleven to make Android Auto and Apple Car Play active via the USB port. (Vision coding supply the exact settings.)
I then bought a very cheap (£19.99) Android Auto only wireless adapter.
I installed it all over 2 years ago and it works really well, connecting quickly as I enter the car with my phone in my pocket.
Compatibility
Compatibility
Compatible with Skoda vehicles manufactured 2015-2020 with MIB2 headunits.
Attention
Do you have a Skoda from 2020-2025? You need our MIB3 activation service here.
Step 1
Check your headunit software version as follows:
  1. Hold the MENU button for 3 seconds
  2. Select Software update/versions
  3. Installed SW Train Version
Step 2
Make a note of your Installed SW Train Version. Examples below, but not limited to:
  • MST2_EU_SK_ZR_P0245T
  • MST2_EU_SK_PQ_P0359T
Step 3
If your headunit begins with MST2 and has 2 SD card slots labelled SD1 and SD2, it's compatible!
Step 4
For software versions ending with P02xxT (where x is any digit), an extra programming step is required which needs a separate device to fully enable Apple CarPlay and Android Auto. It essentially becomes a 2-step activation process - use our software first then use an OBD2 programming tool such as OBDEleven to complete the 2nd part.
This is topic for swing, aka MEN2 units, so this is offtopic and should be removed.
Edited by Zlatko580
Greetings from Chile.
I have a 2021 Fabia 3 with the following radioIMG_20260530_115224.jpgIMG_20260530_115201.jpgWill this method work for my car?
It will work.
On 12/06/2026 at 00:12, Zlatko580 said:
It will work.
I did it today, worked like a charm.
Had some trouble disconnecting the antenna cable from the radio but otherwise it was really simple.
I used the clamp with the voltage regulator board and could read the chip from the first try.
Total cost was 9 USD including the ch341a and the radio keys both from AliExpress.
Thanks for the information
Hi ALL or Zlatko
try anybody read EEPROM, by OBD eleven with android tablet/phone?
here is this possibility. but if is possible read EEprom correctly and do this steps by another way.
what do you means?
1 hour ago, RAMMPA said:
Hi ALL or Zlatko
what do you means?
Hi, didn't tried that way. I belive it cannot be done so easy...
Hi All Or Zlatko
Create anybody Video for this Solution?
First of all: thank you for the brilliant hack - it really works and will save your summer road trip!
This is exactly the kind of weekend project that hits my sweet spot—part grease monkey, part code monkey. Unlocking Smartlink (Apple CarPlay/Android Auto) on the Skoda Fabia III (Swing 3, MEN2) by directly flashing the M95256 EEPROM is a brilliant hack, but as noted in many of the comments, the original guide can be a bit of a maze.
If you've got a Fabia III and want to tackle this without bricking your head unit or losing your mind, here is the streamlined, battle-tested notes based on real-world trial and error. Read this as supplement to the original guide.
Hardware & Teardown Notes
Getting the head unit out and prepped is half the battle. Don't force things, but be prepared for a little stubbornness from the VAG-group hardware.
  • The Right Removal Tool: The "VAG Radio removal tool" isn't universal. While the original guide might point you to different keys, for the Skoda Fabia III, you strictly need the No. 1 removal tool. Don't bother with the No. 2 keys; they won't seat properly in the Swing 3 chassis. I suggest getting a kit – better quality and you will not cut your fingers on cheap e-bay tools.
  • Wrestling the Connections: Once the unit is loose, detaching the back wiring can be a pain. The yellow connector comes off easily, but watch out for the white dual-Fakra antenna plugs. They are notoriously sticky. I actually broke the plastic housing on mine trying to get it off. Pro tip: Even if the plastic clip snaps, they are single plugs underneath and will still attach securely when you reassemble, so don't panic if it cracks.
The EEPROM Programmer Setup (CH341A)
We are targeting the 95256RT EEPROM chip on the board. You need a CH341A USB programmer, a 1.8V adapter, and an SOIC8 test clip.
  • Assembly: Assemble the stack exactly as shown in the setup: Programmer base -> 1.8V Adapter -> SOIC8 Clip. Make sure to align pin 1. The 1.8V adapter is non-negotiable for this chip; The ”Red Light” power issue (see below) happens when supplying 3.3V or 5V or not enough power.
  • The "Red Light" Power Issue: When you attach the clamp to the chip on the PCB, keep an eye on the programmer's red power LED. If it immediately goes out or dims drastically, you have a power delivery issue, not a dead chip.
  • USB 3.0 is Your Friend: To fix the power drop, plug the programmer directly into a high-powered USB 3.0 port on your motherboard, not a cheap hub.
  • Patience with the Clamp: The SOIC8 clip is finicky. It took me about 10 tries of gently seating, unseating, and wiggling the clamp before the pins made solid contact and the software recognized the chip. Keep at it. What does success look like? Data in the Hex editor window and not zero 00 everywhere!
Software, Flashing, & Security (The Linux Way)
All due respect to the original poster, but as a rule of thumb: never download and run random executables from forum users. You don't need their .exe files. You only need the raw Python script (MEN2SwingPatch.py).
Because of this, Linux is by far the superior environment for this hack. If you're on Windows, just install WSL (Windows Subsystem for Linux)—there are plenty of simple guides out there—and do it safely.
Here is the Debian/Ubuntu Linux workflow using IMSProg:
1. Install the Flashing Tool:
Forget hunting for sketchy Windows drivers. Just open your terminal and run:
sudo apt update
sudo apt install imsprog
2. The Read & Patch Workflow:
  1. Open IMSProg. Make sure it says Connected (green box at the bottom) and set the Chip Type to 95_EEPROM, Manufacture to ST, and Name to M95256 (32K size, 1.8V).
  2. Hit Read. This pulls the original firmware off your radio.
  3. Save this file as 1.bin. (Keep a backup of this safe somewhere!)
  4. Open your terminal in the directory where you saved it and run the patcher script:
    python3 MEN2SwingPatch.py 1.bin
    This will generate a new file named
    1.bin_patched.bin.
3. Flashing the Patched File:
  1. Go back to IMSProg.
  2. Under Auto Options, make sure the following are checked: Erase, Check erase, Program, and Verify.
  3. Load your newly created 1.bin_patched.bin into the hex editor.
  4. Hit Go! The software will wipe the chip, verify it's blank, write the patched Smartlink-enabled hex data, and do a final checksum verification. Once that passes, unclamp the chip, reinstall the head unit in your Fabia, and enjoy your unlocked Smartlink!
Hi all and thanks for the awesome guide. I have quite a weird problem. After following everything step by step, all went well, i mananged to write the chip, it booted up. The weird thing is, i have only android auto enabled. Swing 3 of a skoda rapid 2019
Reset to factory settings, only smartlink or whole unit.
Thanks on the quick response. I did that and worked like a charm. Thank you !
If someone has problems getting valid input from the EEPROM chip via the clamper, as @bigwhale42 mentioned, you need to try using a 1.8V adapter, it worked great for me, since I had a lot of stability issues on input from the clamper when using the 3.3V. With the 1.8V adapter it worked flawlessly.
To avoid bricking the device, always make sure to check 4 or 5 times reading the EEPROM and check the CRC32 before getting your backup. Then another sanity check is the MEN2SwingPatch.py output for device numbers, for example:
Train: MEN2_EU_SEGPx_P8010L
FAZIT: WG8-LGM20.03.1900010083
VCRN: D0478DEFB4
I also needed to factory reset Full Link for Carplay to appear (only Android Auto was visible), as @Zlatko580 mentioned.
Guys, also congratulations to everyone contributing to this solution it worked great and it was a very enjoyable "project" for people in electrical or computer engineering. Special thanks to the people that managed to reverse engineer the memory seems kinda crazy to me, even with some experience on embedded systems security.
Fabia Mk3, MEN2_EU_SKGPx_P0460L, ver. 8780 - Success! It worked like a freaking charm.
Huge thank you @Zlatko580! And thanks @bigwhale42 for a Linux version (did mine on Mint) ) Also, photos were really helpful!
In my case I didn't need to do factory reset, CarPlay, Android Auto, MirrorLink everything worked from first run after plugging unit back.
Edited by androot
Hello, did you have to load VCNR first before flashing because your mib 2 has the code P0460L and I read on a Russian forum that it is necessary to read VCRN before flashing the bin file if the first number is 0
Nope, I just followed the instructions and script took care of everything including VCRN read. I did no additional steps. Attaching photo of terminal after executing script on dumped binary, you can see VCRN is loaded there. So basically your work is just a monkey job to dump the binary, patch it and save back to chip :)
Edited by androot
