Activating SmartLink on Swing 3
Thanks!!!
  • Replies 193
  • Views 45.2k
  • Worked perfectly but it was to hard to get it readed the clap is tricky i Have unsoldred and soldred back
  • You Guys are amazing! Thank You for all. Everything Works perfect! Keep up the good work
  • DOWNLOAD needed software
Is this wiring good?
I don't want to brick it :D
On 06/08/2026 at 13:51, pocem said:
Nvm, I got it. Thanks for sharing :)
Hi
Is it possible that I've disabled the USB read function?
At first, I thought I was using the wrong USB cable after the activation process, and I tried about 10 of them and two phones - neither the radio recognized the phones nor the phone recognized the radio.
I dug into the USB port and checked its number: 5Q0 035 726 M (black port) - it should support Android Auto.
Then I decided to connect a USB flash drive - the radio doesn't recognize it :/
It worked before - I changed the station logos to color ones.
Skoda Rapid 2017
Radio number: 5JA 035 871 C
MIB: MEN2_EU_SKGPX_P7130L
24 minutes ago, yolewap said:
Hi
Skoda Rapid 2017
It is not common problem, try hard reset of multimedia with long press power button until logo show up. If still not working, try reset to factory settings whole unit.
And last step would be to check with diagnostic tool for faults or posssible wrong coding/adaptations.
All factory settings were restored as a precautionary measure upon first startup after activation.
Hard resetting the unit didn't help.
What diagnostic tools are you talking about?
Maybe I should try uploading the original .bin file back?
ODIS, VCDS, OBDeleven...
You can write original .bin but it would be very very weird if that causes problem with usb. I never heard of that kind of problem after activation fec.
EDIT:
Maybe you just didn't pluged in HSD cable connectotr properly in the unit when you put back unit in car after activation?
Edited by Zlatko580
Sure. Unfortunately, I don't have any of those.
I'll try replacing the USB port with the 5Q0035726E, along with the cables. According to reviews, the M version didn't work with the iPhone. One of the phones also displayed a slow charging warning (Nothing Phone 2A).
If I can't fix it myself, I'll have someone else diagnose it.
I've unplugged and reconnected the entire radio about five times already, so I should get it right at least once :D
Today I tried uploading the original .bin file, and sure enough, the USB port is still not visible. I'm waiting for a new USB port and I'll start replacing it.
Maybe it was damaged earlier, after I used it to change the station logo. I use it to power my dashcam every day.
That's the expected outcome. There's a small possibility that, for some reason, the USB was disabled when you first reset the multimedia to factory settings. Or that the USB got some internal error and stored error code, until you delete error code in 5F module it will be disabled. It's certainly not possible to solve this without diagnostics. Cheapest option would be some Real HEX-V2 VCDS clone (FlyOBD is best) on Ali for 50€, it pay itself very quickly.
Edited by Zlatko580
More details about diag adapter
The error keeps coming back. Now I'm waiting for a new USB port with cables.
I hope you ordered 5Q0 035 726E.
Yes, the green one.
Now I have, Black with M on the end.
Victory!
After replacing the USB port and wiring harness and ereasing the error.
Huge thanks to @Zlatko580 for this guide and the additional help.
Also thanks to @bigwhale42 for the Linux guide. I used WSL and had some pretty good fun...
...although playing with clamp was quite stressful for me :)
Thanks again!
I broke mine and buyed a new one , activate it with the car (to remove lock / componant ) and reactivating smartlink , costs me a looot ... but very satisfying
Hey, link does not work, can you reupload new link please? :)
@Zlatko580
I followed the instructions and smartlink is activated, thank you
