Activating SmartLink on Swing 3
Thank you for the feedback. I would also like to add that MEN2_EU_VWGPx_P0180L on a VW Polo 2021 is also not working.
  • Replies 209
  • Views 54.3k
  • DOWNLOAD needed software
  • Worked perfectly but it was to hard to get it readed the clap is tricky i Have unsoldred and soldred back
  • You Guys are amazing! Thank You for all. Everything Works perfect! Keep up the good work
Hello all,
I've managed to activate smartlink, thanks for sharing all the steps.
Now I have another problem, maybe someone else has a solution.
connecting the phone with cable, all good, androind auto is working, no problems there. when I try to connect a wireless adapter in the car's USB port, connects with the infotainment, but when I pair the adapter with my phone via bluetooth, the infotainment gives a USB error end keeps resetting. It could be that the cars's USB port is low on amperage and keeps getting errors?
Any advice or suggestions would be greatly appreciated.
Try this one:
https://a.aliexpress.com/_EI8bplo
Mini Ultra 2.
On some it works lika a charm, rarely on some units not work.
Edited by Zlatko580
Hello, I have tried but with no luck, I can not connect programmer to read the chip as the pins 3 and 4 (HOLD and VSS) are shorted together. Any ideas why?
Everything is the same, both hardware and firmware versions as Yours.
Maybe the IC is locked somehow (via software or hardware).
Any helps is appreciated.
You can try to desolder vcc...
On 26/10/2026 at 13:08, ovidex said:
Hello all,
Same issue here, with a cheap Ottocast it does not work. It is, as far as I can see, a compatibility issue. I updated the Ottocast firmware with no solution. My conclusion is VAG MIB units have deep hardware incompatibilities with certain multi-protocol conversion chips. Dedicated single-protocol adapters like AAWireless (which has specific VAG compatibility toggles in its app) could be the solution. For now I choose to use the cable solution as AAWireless is a bit expensive. But xmas is coming...
Edited by bigwhale42
@Zlatko580 Hi,
Could you summarize exactly which train versions this solution is compatible with?
Thanks in advance 👍🏽🙂
It should work on any MEN2 unit. In my experience it only didn't worked on VW Polo 2021. At first it was odd that 2021 car have MIB2 (MEN2) unit at all...
On this topic you can find different situations people had, I cannot be sure about those situations as they could be caused by many factors, possible not bx patch itself.
Okay, thanks for the feedback 🙂
1.8V adapter helped. All works well now. Thank Your for the tutorial !!!!
