Superb 3V3 tailgate struts - Beware Autodoc
I'm a newbie Superb owner and felt my tailgate struts are not as efficient as they might be. Having entered Make, Model and Engine size as well as registration into both the AUTODOC site and app, I was presented with a long list of struts, all of which, I was informed, were suitable for the car. (You can see where this is going!). Ordered 2 x Stabilus 301171's which, on arrival, clearly did NOT fit. Challenged Autodoc who said I should have checked the VIN first with them by email - there is no guidance evident to do this and why would you, given the info they had and their site's confirmation of suitability. The upshot is that they reject any responsibility, offering to refund £44 cost but NOT my £9 postage. In addition I am required to spend £25 to return the items to Germany. When I gave them the VIN they advised they don't stock suitable struts as they are factory issue only - so why list umpteen struts as suitable? You'll see from the attached that my VIN details are actually held on the site in the second image and still the recommendations stand. My post is made purely as a warning if you are looking for Superb III struts on this site, do NOT take anything at face value. Highly UN-recommended. Apologies if this is in the wrong section or should not even be raised - I'll understand if Admin removes.
A significant disadvantage of autodoc and its other companies masquerading as UK based with .co.uk addresses. Fine when the right parts are offered and delivered, PITA when not.
Part number is very likely to be printed on your current struts. Use that - exactly, suffixes and all - to attempt to find aftermarket matches, autodoc may also be wrong about non-availability.
Have found the same. Brake disc sizes are entirely random despite the make, model and trim confirmed.
@Breezy_Pete knows his onions so take that as gospel. And tbh I’d just google it and see what comes up. Skoda parts is always an option.
Stabilus 301171 Tailgate Strut (Superb MK3 Hatchback without rear wiper)
3V5827550D
3V5827550E
3V5827550H
3V5827550J
Extension Force 660N
Length 546mm
Stroke 169mm
https://www.autodoc.co.uk/stabilus/9485272
Stabilus 301410 Tailgate Strut (Superb MK3 Hatchback with rear wiper)
3V5827550
3V5827550A
3V5827550B
3V5827550C
3V5827550F
3V5827550G
Extention Force 700N
Length 546mm
Stroke 169mm
https://www.autodoc.co.uk/stabilus/9487445
Stabilus 299976 Tailgate Strut (Superb MK3 Estate)
3V9827550
3V9827550A
3V9827550B
3V9827550C
3V9827550E
Extension Force 600N
Length 598mm
Stroke 191mm
https://www.autodoc.co.uk/stabilus/9445724
Edited by Carlston
Sorry to hear you have had a bad experience with them, I've ordered a few times from Autodoc and have always paid the extra few pounds to allow to return items up to 100 or 200 days after purchase. I purchased the wrong clutch and it was my mistake, sent them pics and they sent me return labels and the necessary paperwork.
Another one for Autodoc - same experience as OP had on two occasions!!! Avoid
Once fooled by Autodoc too. Never ordered again.
Neverminds if I pay a bit more as long as there's no bad surprise.
I have had no problems ... but I never trust their search patterns, for NO dealer/reseller, even those reliable and established ones like Rimmer Bros for my LR.
Always double-check! Yes, is a small hassle yes, but it compensates by doing your own purchases and not paying extra % to a third party ....
It is a classic that lots of parts are grouped/piled up by approximation, and particularly VAG is a nightmare for parts' codification. So always beware ... and don't trust the photos, unless they exactly reflect the item description and codes!
I use this for checking part numbers, so far I have been satisfied:
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851
Yep, another Autodoc never again here, on ATE Ceramic brake pads in my case, but fortunately sold them here to a fellow member.
That sounds really frustrating, especially if the site itself confirmed that the parts were suitable after you entered the car details and registration. I’ve seen quite a few mixed opinions when searching for an autodoc review, so I’d definitely double-check compatibility with the VIN before ordering anything that can have several different versions. The return postage situation is also worth keeping in mind. Hopefully you manage to get the refund sorted without any further hassle.
