2.0 PD140 vs 2.0 PD170
Shall I turn the lights off on the way out??:D
  • Replies 59
  • Views 9.7k
Presumeably the PD140 has the same box, as such, that too is limited to the same extent?
Out of interest, what is the standard PD130 6-speeder rated to if anyone knows?
Allegedly its quite durable... (think it was JBS who said its related to the RS4 and good for 450lb/ft) but i know mine is coping with 340lb/ft quite well :D
  • 2 years later...
As I understand there are three PD140 used in Octy mk II: (Wikipedia)
2,0-16V - 136ps/320nm - AZV - 04-08
2,0-16V - 140ps/320nm - BKD - 04-08
2,0-8V - 140ps/320nm - BMM - 07->
I suspect the latter is the single-cam...;)
But do any of you know which have DPF?
Olit
Read through the service training book about the 170 (125kW)
Main differences between 170 and 140 are from what i see
170 has
only 4 crankshaft counterweights as opposed to 8
has a balancer shaft module mounted in the oil pan beneath the crankshaft
cylinder head has been adapted for 125Kw output
water jacket has been completley re-engineered to take the higher strain
valves sit flush with the cylinder head so the valve pocket have been omitted
re-engineered head gasket incorporating rear land support and vertically profiled combustion chamber stoppers
Swirl flaps on the intake manifold
larger exhaust gas cooler
turbo has optimised travel feedback
different length and screw in thread ceramic glow plugs (not 100% sure on the this one)
Only the BKD engine has ever been used in the octavia, the 8V engine is used in the passat only.
As for DPF, only the Scout and 4x4 version of the PD140 have a DPF. the standard 2WD versions do not have a DPF.
I have a BMN engine ?
I tired to upload the service training manual about the main differences between the 140 & 170 but the file was too large. :o
A bit of a thread revival this one - nearly 3 years!!
So what happened to the OP - Walkie.
Last seen heading towards Blackpool - or some of the posher parts of town - is he still there?
Thread revival indeed! Thought he was back around these parts for a minute, when I saw the thread...
Steve
  • 6 months later...
Greetings ;)
