- Activating SmartLink on Swing 3
vagfranko started following Activating SmartLink on Swing 3
- The state of early mk4's in 2026?
Jaguar, will it survive?
This is interesting. Maybe Jaguar does have a plan after all? It is a shame if traditional buyers are effectively frozen out by this divisive design, but as I said many times before, nobody was buying Jaguars. I'm also taking this article with a pinch of salt, but there's no smoke without fire, I reckon... https://www.motor1.com/news/811711/jaguar-ev-50000-people-interested/
- skoda superb 2.0tdi not reaching operating temprature
- Yesterday
Hello at last!
Hi JN12 Need to find a fabulous independent myself. Sounds like you are a problem solver. Useful asset to all
Hortiguy started following Hello at last!
Head Unit not starting up
My head unit (central screen) is completely black and not responding at all. The screen between dials on instrument panel is however, fine. Have I bricked the head unit, or does it just need a re-code? I did take it out, as needed to clean the space behind it. Not wanting it to dangle, I did disconnect it. Recently changed the battery, but that was weeks ago, and didn't cause any problems. I've found that the cabin filter only has foam on two sides, not four, so dirt was taking the easy route instead of going *through* the filter 🙄 I have ODBII, or would i need VCDS?
zeta_91 started following Head Unit not starting up
Any difference between diesel and petrol airbox on mk3 vrs?
It does indeed replacing the factory intake system. On the TDI. The EA288 and EA888 are totally different engines. The actual intake duct is probably very similar, but the airboxes themselves are not. You can, from what I've seen, potentially modify the TSI intake to fit the TDI, although I've no idea why you wouldn't just get a TSI intake to begin with. There's no shortage of Racingline/Forge examples.
OccyVRS started following My car's in a bad way , Any difference between diesel and petrol airbox on mk3 vrs? and Axle stand location
Axle stand location
Just to add - the jacking point on the sill is actually only for emergency use. The car isn't designed to be lifted here, if at all possible. Absolutely get a decent jack pad.
Well, this thread was a bit of a rollercoaster. I've given my car all it needs, and more, yet it keeps throwing up issues. I've now got an issue with the steering system (probably the rack, unless the drop links have decided to suddenly go), and having just spent over £800 getting some jacking point damage on the sills fixed, it''s pretty gutting. What are you thinking of next?
- My car's in a bad way
Car Shudders Various Lights Come On Goes Into Limp Mode
Fingers crossed. Interesting - on old BMW E36 forums it used to be: Car idling rough - camshaft position sensor Car idling rough and stalling - crankshaft position sensor.
Axle stand location
Hi, the below shows what you described and with a nice chunk of wood to ensure you won’t damage anything I would say this seems fine.
Cyco started following Axle stand location
AutoKULTUR joined the community
2011 Octavia 2.0TDI 140 CFHC Fuel Filter Confusion
Cheers Pete
P176F00 "Clutch 2 closes unintentionally", returns after clearing. Sensor or mechatronic?
And what do you expect after 65,000 miles without an oil and filter change? The manufacturer claims 80,000 miles without service—lol, that’s advice for the gullible. As a rule, transmission fluid in these models should be changed every 60,000 km (35,000 miles). Sure, the service schedule says engine oil gets changed every two years... lol. Of course, the engine will last as long as the warranty holds, but afterwards—you'll be left wondering, "What was I thinking?" For RS models—and especially TDI models—the engine oil should be changed every 10,000 km, and the transmission is a whole other story. RS models are driven much harder and pushed to the limit—you really need to change the transmission fluid every 35,000 miles.
Long life servicing
all true
Use my part number in ebay with word genuine, and you get item number 277634634997 New genuine at about half price compared with dealership if you use the coupon.
maonus joined the community
John202020 joined the community
Brochure download
so do you have myskoda app? when you register you have all the brochures there .
I had 2 rs tsi 2021 and 2022 year. the problem is not so much in the software, as the problem is in the mib, those devices were assembled with old processors where procurement was in chaos due to covid. there were no chips, so they used old chips. only octaves from November 2023 use new chips and a stronger processor. that with old models is a lottery.
KESSY issue since update to 1985
Does it mostly happen when it's wet outside?
Thanks for the help chaps. But wow why on earth is getting the right fuel filter so blooming complicated Trouble is the previous owner old boy said he replaced the fuel filter a couple of years back but didn’t log the service or the part used hence yes I could see what filter is currently fitted by removing it but I don’t really know if he’s fitted the correct filter anyway as there’s so many choices even some only 1mm different on height etc.
Skoda app auxiliary heater not showing
Good afternoon Gent's, Need a bit of advice. I have a Octavia iV 2021. I have installed the My Skoda app, i activate the 3 months free subscription for Care Connect and Infotainment Online, but i can't find all the options from those sections. For example the auxiliary heater, or charging location, not showing at all on the home page. Any advice helps. Thank you in advance
Estate vRS 2.0 TSI 245 PS DSG - fluid change or not
https://www.facebook.com/reel/2854277254907176 Here you can see a short video showing the condition of the transmission fluid in a Peugeot—a vehicle for which the manufacturer claims the fluid never needs changing. Lol, they’re just waiting for you to have to replace the mechatronics unit—and a repair like that costs between €1,800 and €6,000 here in Croatia. Bon appétit!
lol..By all means, stick to what the dealers tell you. Any competent automatic transmission specialist will tell you when the fluid and filter need changing. You could change the fluid at 80,000 miles for the DQ381, but you can't see the actual condition of the fluid inside the transmission. It is madness to change the fluid without changing the filter; such fluid will likely damage the mechatronics unit, causing the transmission to jerk and making gear shifts unsmooth. The transmission normally shifts up after 1,800 RPM; if it is shifting at 1,900 or 2,000 RPM, you have likely already reached the 60,000-mile mark. This device changes the oil in 40 minutes; the housing allows you to see the oil change process and the condition of the oil being replaced. You buy a £30,000 car, yet you can't change the oil after four years.😇
I remember there being a short and a longer housing and filters. Suggest measuring the housing length/dimensions to help you get the right part.
