Is this the perfect spec Superb?
Ha I havenโt added that much! No not wanting to change. Just browsing and daydreaming!
What have you done to your Kodiaq today?
I also replaced the original battery on my ex Superb Estate Mk3. Same coding with 11111111111... ๐
@Binx1310 With all what you've added to yours. Is there any Mk3 more specced than yours... ๐ Already want to change?
2012 to 2019 Superb Refresh
Hi, IMHO, all these things were standard spec on L&K, except surround camera and heated steering wheel. I used to be a Superb Mk3 Estate TDI190 L&K 4x4 DSG6 (MY2018) for 7.5 ish years and 136500km (coming from a Superb Estate Mk2 TDI140). I had water ingress problems with the panroof on the Mk2 (sunroof frame cracked ๐ฑ). As I bought my Mk3 while it was already on the assembly line, I did not chose any options. I took it as it had been specced, i.e.: with a panroof. No need to say, it was a bit of stress... Fortunately, I had no water ingress issue with it. BUT I used it as less as possible, and I was really careful with speed bumps and sidewalks so that panroof chassis had to face very smooth stresses variations. The only issue I had with the panroof, is the seal of the rear glass panel, which cracked after 6 years (probably because my Mk3 slept outside for its entire life). It was probably burnt by the sun. I nevertheless treated seal with silicone spray before each winter. No panroof was one of my criteria when I looked for my current Kodiaq Mk1. I perfectly live w/o panroof, It has been 19 months last week, but I stilI hold strong. ๐ Additionally, I had 2 issues: Waterpump failed at 62000km, a known issue. Skoda France granted me an extra warranty though the normal warranty had already expired. I only had to pay 10%. Front shock absorbers started leaking at 95000km, also a known issue. The dealer made a 15% bargain though warranty was well over... This being said, I liked my Mk3 though.
- Wiper blades for 2022 Karoq
The passenger side seemed too fat to fit & I didnโt want to bend the wiper arm, Iโll try again tomorrow with the bonnet up to see if I can get more leverage
Very strange brake feedback - Kodiaq SE
I found a mHev Ford suv we hired in New Zealand to be quite frustrating to drive. The small battery soon filled so the retardation recuperation would suddenly end partway down a hill and the braking characteristics changed without warning.
AndriiB12 joined the community
True! Think I will stick with the one Iโve seen. Deffo didnโt want a pan roof due to previous experience with a U boat Audi. Never again.
The trouble with later facelift is you then get MIB3 infotainment which tends to be buggy, and also ADAS becomes more intrusive.
Iโve seen both of those, good specs on both, but early facelift with Gen 3B, not a deal breaker for the right price I suppose. No similar car, private sale.
Is the facelift one youโre going to look at a 280? Quattrotech in Cambridge have a facelift and pre facelift 280 for sale currently.
I do two trips to the borders and two trips to the French Alps a year, everything else is short trips max 40 mins Oh now @travs threw a spanner in the works with the gen 4 888 ๐
Hi According to the Bosch website those are the correct ones, I have just changed the ones on mine , they were tight but did fit, only the rear one is different on newer vehicles https://app.boschwiperblades.com/-/en-gb/478dafb54dab9771f6adabf9705fe54dd0d454ee/period_4269_1705_07_2017_03_2023/SKODA_Karoq_2017-2023
RSM15 joined the community
I have a 190PS diesel. It will spin the wheels through a couple of gears easily. Would love it to be 4x4. Certainly the fastest and punchiest car Iโve ever driven, especially accelerating from 50mph plus on motorway. Plenty fast enough acceleration to get you in to trouble! Diesel vs petrol all depends on your travel distances. When I got the car I was commuting 45 mins each way 5 days a week. Now Iโm wfh mostly and do lots of short trips and the occasional 4-5 hr each way work trip a couple of times a month. Enough to blow the cobwebs out hopefully. If I was buying now Iโd probably go petrol as all the long trips I do are on expenses so cost isnโt so much of an issue.
Binx1310 started following 2012 to 2019 Superb Refresh
Skoda fobia 1.2 2016
I have I idel in my Skoda fobia Monte Carlo 2016 1.2. I have changed the throttle body and spark plugs but, still ideling and the car goes to lump mood. I'm getting the sign for EPC traction sign. Sometimes engine sign. Can someone help me please
qais started following Skoda fobia 1.2 2016
Rubber boot mat - anyone after one!
Recently purchased a mk3 superb Upon a detail came across a kodiaq rubber boot mat This doesnโt fit the superb And also itโs something I donโt want Anyone local to south wales interested in it? Looks like this But can get a photo when I remember
RogueWagon started following Rubber boot mat - anyone after one!
Correction 21 plate ( canโt find how to Edit post)
qais joined the community
pamparam joined the community
Service naming conventions vs independent garages
You donโt state what engine and gearbox you have and if 4x4 as that will all impact whatโs included. E.g petrol will need spark plugs, DSG and haldex for 4x4 have servicing requirements. I have a copy of the Skoda service manual that lists whatโs included in each level. Itโs more than 20MB so I canโt share it here but I will send you a link to download it from as a PM. As others have said, out of warranty I wouldnโt use main dealers. I find them very regimented in what they look at and I have had Indy garages pick up on things dealers havenโt. Theyโre also horrendously expensive. The best option is a VAG specialist Indy that uses parts from TPS (genuine parts).
Binx1310 started following Service naming conventions vs independent garages
Mรฉdia display
This may help To dim the infotainment display for night driving in a 2025 ล koda Superb, use the quick-access control center or display settings: โข Swipe down from the top of the infotainment screen to open the control center, where you can adjust the brightness slider directly. โข Switch to Dark Mode by going into the display or vehicle settings and selecting the dark/night theme so the interface colors invert and reduce glare. โข Adjust map settings separately if you are using Apple CarPlay or Android Auto, as navigation apps often manage day/night themes independently under their own internal app or phone settings.
Depending on where you live the prices are higher than Iโd expect. You need to check what work and when it was carried out. If the Brake fluid is 3 years old or more then itโs needed. A โfullโ service by an Indy should include the rest including filters. Ask to see hte old filters to give you an idea of how long since the last change. Many dealers charge and donโt change (some indies as well of course). I always use the same Indy as repeat business (3 cars from the family) normally insures good service and reasonable prices. Iโve been using my indi for 9 years now since we last moved house. I can roll up and he will top up my oil if the lights comes on for freeโฆ.. I havenโt needed to do that with my previous Passat or current Superb. His prices are at least 15% below the dealers
Tbh those prices are mental... Over ยฃ70 for a pollen filter that probably costs a tenner and takes 5 mins to fit... Likewise an air filter??? At 7 years old is use an independent and just ask for this elements the dealer has advised if you want them. Otherwise just ask for a full service which at an independent would probably include more anyway for less cost.
Yes itโs strange. I think it just needs to see a different number in the serial number field so it knows itโs a different battery. Interesting yours was set to all 1s as thatโs what mine was when I changed it and it definitely wasnโt OEM battery. Perhaps it had never been coded properly at the last change ๐ค
I bought Bosch A864S wipers ( aero twin) from Amazon for the front of my 22 plate karoq sportline 1.5 tsi after inputting my reg it said they fitted, but after trying to fit them, the driver side was a little tight, but fitted, but the passenger side will not fit at all, has anyone had this issue & found the correct blades without having to go to Skoda & getting my eyes taken out
batemansxxxb started following Wiper blades for 2022 Karoq
Hi, New battery installed and recoded. Battery S/N is really bullsh*t. OEM coding was JCB (for a Varta one) and S/N did not match the BEM code stiker on the OEM battery, simply 11111111111. I then simply set VAO for my Varta and then 11111111112. Done.
Fuse 7 lack of power steering
OK, with those 14 way connectors unmated use meter set on dc volts to work out which half of the connector has pin11 at 12V when ignition is on. I'd imagine it will be the side with female contacts rather than pins. Then put that connector aside and on the other half measure resistance from pin 11 to battery negative. See if it looks like a dead short. Then unplug MAF, PAS 4-way connector and oil level sensor if found and see if that short is gone. If it has gone, reconnect those items one by one to see which is causing trouble.
