gumdrop
Everything posted by gumdrop
  1. Can the MP3 be changed, perhaps to FLAC or evened out for volume?
  2. Is it a problem that can be overcome? I use Mediamonkey v4.2
  3. gumdrop posted a topic in Škoda Kamiq
    I was reading a thread on coolant problems and there were recommendations to use only VW 13 anti freeze and distilled water. Ok so looking online for 1litre of VW group antifreeze there are VW evo12 with a date of 17 02 20 The date on the bottle is this a use by date or a production date
  4. All MP3 (over 100) only problem I have is variations in volume between tracks.
  5. gumdrop replied to EJB's topic in Škoda Kamiq
    I know there is an airbag in the drivers side pillar.
  6. Computer with a cruddy heatsink can cause overheating and faulty operation.
  7. The OBD plug is fine it only has two or three pins, pin4 for ground, pin5 for signal,pin16 for power supply it affects nothing else.
  8. Its like everything, you must do what you are comfortable with.
  9. One particular manouver is the accelerating to warp speed down the On ramp and cutting across all three lanes. Extra view provided with an extra mirror could save you from a nasty collision.
  10. Thank you PoloPaul and Stewarttv, I usually put the car (ever since I have had Stop Start) on charge every 3-4 weeks, especially if I am only doing short journeys.
  11. Oh Sugar! I had an SOS error this afternoon, I didn't have time to read it properly. I got home and parked up then had to reverse slightly, turning the ignition back on cleared the ( ! sos) reminder. Now what? I think I will put it on charge.
  12. I am sorry, I have called it Rearguard which is wrong. It is the Rearmaster Switchable universal OBD cable CHECK that the usb plug is suitable for your brand of Dash Cam, for instance my cam is mini usb. From Amazon, it may be available from other retailers.
  13. Cars on motorways often accelerate past anything on the inside lane when joining the motorway from the down ramps.
  14. I only went on the information supplied by the manufacturer, on Amazon. The cable I used was called Rear Guard, I had a problem with my first cable but there was no bother they refunded straight away . I ran the dash cam updates and bought the same make of ODB cable again and it worked! Dash Cam is a Nextbase 312GW
  15. I had a few problems with low battery charge, and stuff apparently being turned off to save electrickery. C-tek charger on over the weekend battery ok but the radio had a fault (another story)
  16. Yes I can change between the screens but I don't think I have mood lighting. But then I have never had the lights on except for the running lights 😃
  17. As I said the dials on my screen are red, I was mistaken they have red circles inner and outer.
  18. I like this all black screen, mine is predominately red and looks cheap
  19. I had a single tough leaf in my heater fan that made a din like that
  20. I used an OBD cable it switches on/off with the ignition and has a parking switch module that monitors battery charge and auto-turns off to save flattening the battery. Rearguard from Amazon Does it have the latest software update? my new nextbase needed 2 updates.
  21. I watch for the radiator grill and continue to overtake until I have counted five then look signal and pull in. But we are more concerned with seeing who is overtaking us! especially on the inside but moving out to overtake on a 3 lane motorway can find you involved with a car from the third lane moving back into lane two. That is what the extra mirrors are all about.
  22. I rather liked the Goodyear Efficient Grip but my Yeti were both Front Wheel Drive
  23. gumdrop replied to Yety's topic in Skoda Yeti
    It is designed for a quick cabin warm up, as it carries a lot of warm moist air which will "steam" up the colder window glass. I use air con. and balance it with the heater to make it comfortable and as mist free as possible.
  24. gumdrop replied to Yety's topic in Skoda Yeti
    I use aircon to clear the car, never recirc. it doesn't take the moisture out of the air and the car fugs up.
  25. Original Poster, you could use Google Translate; How do I make a monte carlo startup logo with obdeleven on a skoda kamiq bolero radio?
