D.FYLAKTOS
  1. This is a photo before the modification from the mechanic, i had some silicone for aquarium on trying to reinforce the waterproofing. Later some extra cables must pass so i removed the grommet and the mechanic made things much better than me (proper materials as glues for plastic,windshield glue etc).
  2. The link ask for access. You don't pull the whole thing inside, just the lower part. A gently heating from a heat-gun would help.
  3. It's the Front door Grommet modified. Here it is ready to use. https://www.sinatec.com/en/electrical/wiring-harness-repair-kits/skoda/favorit-forman-felicia/wiring-harness-repair-kit-tailgate-skoda-1pc/a12861?c=737 Also make a search for 6U0971840 for example: https://www.autopotreby-liska.cz/?2705,pruchodka-kabelu-5dveri-favorit-felicia
  4. I had the same problem, i couldn't find in the local market that part even as Used so i thought that i could make a patent. I bought one from the front door which is a little bit longer and my mechanic shorten it. I know does not look like the factory but it's not easily visible by everybody. No problem with water, tested multiple times in purpose with garden hose plus many heavy rains in winter.
  5. I though i was the only one with problem with this part. You can make a patent with the one which is the doors, it's a little bit longer but you can manage to make it work, on the other hand one from a french car i think Peuegot fitls like a charm. I have photos to post in my pc, wait untill tomorrow to see mine.
  6. All i was trying to show is even when someone boughts a brand-new radiator fan can face a serious problem (as i did) Even a mechanic which was present in the parts sore insisted ''it's plug and play'' when i was explaining to the employee what happened to the previous one, i look at him in the eyes and i said ''don't be so sure''.
  7. The shipping from www.skoda-parts.com is very high because it uses couriers and not Post Office which means lot of money, sometimes more that the value of the part itself ! He wrote it crystal clear. Plus it does not sends to all the countries: https://www.skoda-parts.com/delivery.html
  8. No, i had in the past Bosch with 4 ''pins'' like these: Not something great.
  9. My Felicia didn't liked at all the Denso, the NGK worked very good but due to the wrong lambda sensor caused my a higher fuel consumption. I had iridium for many months in a small motorcycle but i had to remove them because i had a problem in the carburetor and turn them to ''black'' and i had rough idling etc.
  10. I don't know https://www.denso.com/global/en/products-and-services/automotive-service-parts-and-accessories/plug/pdf/standardlist.pdf https://carshop.com.gr/denso-ik16-871.html "Compared to normal plugs, a 0.5ps (1.4%) improvement is seen in output at 110km/h. Improved Acceleration Increased response and acceleration performance" 😁
  11. Many years back i had installed these spark plugs, those days were ''before the forum'' or ''before the internet'' as we say here which means i trusted the seller and his guide book. Indeed the reference from Platinum Champion RC89PYC to Iridium were these Denso, https://gr.sparkplug-crossreference.com/convert/DENSO_PN/IK16 https://www.auto-mall.gr/index.php?dispatch=products.view&product_id=665 i bought them install them after few months the problems began. I have explain those problems here and here ,today when i was cleaning a locker with some old parts i have found one of this damned Denso. As for educational purposes an you tell your opinion about them?
  12. Does not work, only if you click up and right (Old Version) you can see the catalogue. https://skoda.7zap.com/en/cz/
  13. The do some repair-refurbish work here: https://autoturbo.gr/δραστηριοτητεσ/επισκευη-βεντιλατερ/ https://youtu.be/eJHoGMzlXlA https://m.facebook.com/Αργυρόπουλος-ηλεκτρολογείο-αυτοκινήτων-1645084089070105/videos/επισκευή-αιρκοντίσιον-και-βεντιλατερ/1933228546922323/
  14. This make me nervous because may ruined my calculations for fuel consumption but since it warm here and i don't use the car often now i have to wait. As for Cold Starts, i think i have to give up the fight. In motorcycles i have used plain-drilled-grooved-floated discs and as for brake pads the factory-soft-hard, for brake fluids DOT4 and DOT5.1, factory brake hoses and metallic etc but now are many more companies in the market, new models etc so ''i have lost episodes'' as we say here.
  15. I like the turns and not travelling in boring national roads with steady speed for long time looking far away in a straight line. I like to drive in mountain roads full of turns like these: https://i.imgur.com/hHXX5DV.png https://imgur.com/8hgxPdO https://imgur.com/ZQ3v2pZ https://imgur.com/zLt5RSj In the past i was driver with 2 stroke 250cc and 4 stroke 400cc motorcycles and i have an 30 years experience (in this style of roads) in brake pads, brake discs designs, brake hoses, suspension adjustment, coolant types, octane gasoline experiments, weight balance and ''racing'' between other drivers in mountain roads (yes, i admit it sometimes was wrong). I am a persist driver (not a Kamikaze style) and many times i have beat other cars higher HP than me because many times those drivers think that everything is like a straight line-press the pedal-lot of HP-i pass in front but when comes the time for consecutive turns often the ''lose it'' especially with braking. PS: before all these i was an armoured vehicle driver in the Army.
  16. My car was parked in a place where the sun has hit it hard, cold start less than a minute. I parked the car in a place under a shadow from a block of flats, cold start 3:40 I don't know what to say, the German electronics will drive me crazy! On the other hand, i discovered a fuel leak few days ago. 😲 Starting the car inside the underground parking i smell gasoline but few minutes later in the road this disappeared, this happened again some times but the mechanic said were the fumes from the exhaust. I decide to take action, i opened the hood and i notice on the air intake manifold a brown spot, i turn the key to the 1st scale and i searched with my fingers the 2 pipes which go to the fuel pressure and i discovered fuel drops! Although i was at work immediately run to a tool store and i bought 2 hose clamps and i fix it, since then no smell and no fuel drops. How much fuel i have lost? I don't know because this may started days ago slowly and later get worst and this may affected more or less the fuel consumption.
  17. I saw this yesterday, it's not for Skoda but is very interesting. How come the front grill is 90% closed right at the air entrance? https://www.mustang6g.com/forums/threads/how-come-the-front-grill-is-90-closed-right-at-the-air-entrance.52146/ and a relative video for Front grille and not only:
  18. Due to the hot climate here i am using my small motorcycle for the home->work->home routine and not the car. Meanwhile i manage to make 79Km in city traffic-mountain road (low-medium rpm only) and the results were very good but i have to wait till complete at least 100 Km so i can make a Gas Pump Station test. As for Cold Starts thing are one click betetr than Winter time but the external temperature is much higher and this helps a lot. it's too soon for an Iridium spark plug test, first i have to finish all the tests with the Platinum + NGK lambda and IF the results are very good then i will ''give them a try'' for few months just to have to say a thorough opinion about them.
  19. Here is a ''specific answer'', some techicians can do a refurbish job here but due to the low payment now the new guys usually say ''No, buy a new one''. The same happens for altenators, engine starters, solenoids etc, back in the Good Old Times the mechanic was giving a ''specific answer'' as ''I can do it, the cost is this but won't last for many years as a new one''. The ''specific answer'' from the driver (if he didn't had enough money) usually was ''Ok do it, i will take the risk'' or if he wanted to keep the car for long time and had the money to spend the ''specific answer'' in was ''Ok do you sell new ones?''.
  20. You are right, i never had the thought to touch this, i believed that there will be some kind of incoming air turbulence so i let it as it was. Many times i wanted to cut those plastics and replace everything down there with plastic mesh but i wonder there would be some kind or ''gain'' from this procedure or these 2 help ''pushing" the incoming air to hit the radiator in a straight line rather than swirling around.
  21. Aliexpress? Some stores offer Free shipping. On the other hand we have almost stopped to buy from Ebay.com (US stores) because the shipping many times is more than the value of the item!
  22. Many years back i had the idea to go to a guy (painting and repairing plastics for cars) and cut those grilles from the lower part and replace them with hard plastic mesh. He said it's not good for the reduced resistance of the bumper in crashes so i abandoned the idea. The cool air goes down and i thought that more air will ''hit'' the radiator but... You mean this plastic cover?
  23. Can not find one in local market? The shipping rate is too high from a European country?
